Mike Rieder Posted December 22, 2015 Share Posted December 22, 2015 Thought i would share my latest build (felt this was the most appropriate topic to add it too). A charging cupboard made from fire retardant plaster board. Hopefully it should save the rest of the garage if anything goes wrong! Quote Link to comment Share on other sites More sharing options...
Francis Focar Posted July 11, 2016 Share Posted July 11, 2016 What does anyone think about the B6 and using the lilo setting that will charge to 4.1 per cell ?? Quote Link to comment Share on other sites More sharing options...
ARC Posted September 10, 2018 Share Posted September 10, 2018 Has anyone had success in restoring a weak cell by discharging at 0.5amp until all cells are even and then balance charge at 0.5. Have recently tried this and all cells on my 4s 5000 mah 20c are now at 4.20. Not sure on the longevity on this but it appears to work Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted September 10, 2018 Share Posted September 10, 2018 Hi ARC, I will present a variant on this idea in the next issue of the magazine, I think you may be interested! BEB Quote Link to comment Share on other sites More sharing options...
Sam Longley Posted April 6, 2020 Share Posted April 6, 2020 Posted by Tim Mackey on 01/02/2008 12:50:00: Using them cold of course is different - they perform very poorly if cold - very noticeably in EDFS etc, where every little bit helps. I always warm them in the car or my inside pocket before fitting and flying. Edited By Timbo - Moderator on 18/08/2009 19:10:15 I have just read the first part of this old thread. Are you really telling me- as a beginner, as far as electrics are concerned- that I can walk about with these in my inside pocket??? I asked because I watched my (Senior BMFA) instructor place one on a table ( It was fitted to his starter). Someone said " Watch out that is going to blow"-"Nah! it is OK" a few moments later it exploded & burned a hole through the table, before falling to the ground. So what would that do to me? Quote Link to comment Share on other sites More sharing options...
David Holland 2 Posted October 19, 2020 Share Posted October 19, 2020 I have just read, on a model engineering forum, that lithium cells can be “revitalised” by a spell in the freezer. This sounds most unlikely, does anyone know any basis for this. Might just try it on a pack relegated to second line duties. David Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted October 19, 2020 Share Posted October 19, 2020 It surely depends on from what state the LiPo is at and the degree of "revitalisation" expected. A LiPo starts to deteriorate from its date of 'activation' during the manufacturing process. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted October 19, 2020 Share Posted October 19, 2020 "This sounds most unlikely, does anyone know any basis for this." I have never heard in any professional capacity of any mechanism for "revitalising" lipo cell chemistry. All the related effort goes into slowing any deterioration effects. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted October 19, 2020 Share Posted October 19, 2020 I've heard of cells being put in the freezer to reduce the level of inflation once they've gassed but I've never found it to be very effective. A charge or two and they swell again. Preventing long term storage problems is another matter, in theory the lower temperature should reduce any aging effects. Quote Link to comment Share on other sites More sharing options...
MattyB Posted October 19, 2020 Share Posted October 19, 2020 Posted by David Holland 2 on 19/10/2020 09:14:23: I have just read, on a model engineering forum, that lithium cells can be “revitalised” by a spell in the freezer. This sounds most unlikely, does anyone know any basis for this. Might just try it on a pack relegated to second line duties. No, it's complete twaddle. The degradation mechanisms that go on inside the lipo (dendrite formation for example) cannot be reversed by a simple drop in temperature. Not storing at high temperatures and elevated SOC will slow the rate of degradation on the shelf, but there is nothing known at this point that you can do to reverse internal damage to a pack. Quote Link to comment Share on other sites More sharing options...
Chris Walby Posted October 19, 2020 Share Posted October 19, 2020 I though you damaged lipos by storing or using them at low temperatures (below 10 C), only newish pack that I used (stored in car overnight with a frost on it) resulted in a cell failure. Since then keep in garage and use warmer to ensure they are above 15 C before use. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted October 19, 2020 Share Posted October 19, 2020 It is not good to do a high discharge from a very cold lipo. The internal resistance increases sharply below 10deg, so if nothing else you'd get an short and listless motor run. I can't remember offhand what the sensible cutoff for low temp storage is, but, the slowest degradation is seen at around 7 or 10 deg, I believe. Quote Link to comment Share on other sites More sharing options...
cymaz Posted October 20, 2020 Share Posted October 20, 2020 Could someone how lipos are recycled safely? As they have the ability to explode we just can’t leave them lying about. And there’s not an infinite supply of the minerals. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted October 20, 2020 Share Posted October 20, 2020 At our end of things, discharge and then to the council recycling centre. At the other end, who knows. Quote Link to comment Share on other sites More sharing options...
brokenenglish Posted October 20, 2020 Share Posted October 20, 2020 This looks like an appropriate place for my question... I recently crashed on the first take-off of the day, and did visible damage to the Lipo (3S 2200 mAh). The outer plastic is very torn and the actual pack has been bent into an "L" shape. The cells are still intact and I don't think there's any imminent danger. However, the battery is fully charged. Before disposing of the battery, should I discharge it through my charger? Quote Link to comment Share on other sites More sharing options...
Dickw Posted October 20, 2020 Share Posted October 20, 2020 I would dicharge it through your charger followed by discharging to completely flat (0v) with a 12v bulb (I use a car tail light bulb). Just do it some where safe, and treat it like it is about to burst into flames until you have it completely flat. Dick Quote Link to comment Share on other sites More sharing options...
MattyB Posted October 20, 2020 Share Posted October 20, 2020 Posted by cymaz on 20/10/2020 06:04:08: Could someone how lipos are recycled safely? As they have the ability to explode we just can’t leave them lying about. And there’s not an infinite supply of the minerals. As long as you fully discharge them there is essentially zero chance of an explosion. I can find very little online about the processes used to recycle them though - it does make you wonder whether in the end they all end up in landfill anyway, or worse on a beach somewhere in Asia like so much of our "recycling"... Quote Link to comment Share on other sites More sharing options...
