Bistormer 60" (A Barnstormer with more ribs)
Danny Fenton
Thanks guys, I am not as comfortable with the polyester film coverings as I am with say Solartex. I seem to be able to cope, but I don't like it. I think the answer to getting it right Nigel is practice. Dave Platt says that no amount of lying on your belly waving your arms about on the living room floor will teach you to swim, you need to get in the water! Filming is the same. I did a demo once and solarfilmed my glasses case, with patience and sometimes a fair bit of pull it can be made to go around some quite impressive curves. You will notice on this cowl it is lined with 64th ply, Iy you were to pull with the amount of force that I used against the balsa edges they would not of survived.
Again I am no expert and there are modellers far better at using the stuff than me, Mr Hooper for one! But I find that I apply some tension, heat the film, apply more tension and while the film is still hot stretch it down over the wood. Stretching it after it is stuck down is not easy.
Swearing doesn't help Nigel, but the iron is flaming hot, so swearing does occur embarrassed
Danny
Well thats just about it, I have a closed loop wire to run to the rudder but the horns are all fitted so wont take long and a spinner backplate to turn on the lathe, then its the cells esc etc and check the C of G. Hopefully the weather will play ball and we can get the maiden out of the way.
I know its a bit plain but I must confess I am flagging a bit. I want to get back to my Apache smile p
Danny
Thanks John I might spice it up a bit with some stripes or something if it goes well. But as you say plain is unusual in this day of the extremely colourful artf wink 2
Just out of interest I stuck the 6s A123 pack in and she balances right on the money, about an inch behind forward cabane. Still got to add a prop and the vacformed spinner, and a couple of feet of nylon coated steel trace, but I doubt they will alter things much.
Danny
Still looks lovely Danny.
I can tell that you don't care much for the electrical, servo and linkage gubbins as you've given little detail. smiley
Now I'll have to use my poor little brain instead of simply copying/borrowing/stealing your techniques and ideas.
Joking aside, that's a fun part of the job - working out how that sort of stuff fits together and how to implement it in a way that suits me and my current level of abilities. There's plenty of info on this part elsewhere so it shouldn't be too difficult.
I'll stop by in your Apache blog later as that looks a great build.
I hope the maiden flight goes well and many thanks for a really detailed and helpful account of the build. I've learnt a lot. yesyes
Nigel
Thanks Nigel, I will show you how I lay out the cells, esc etc if you want, I didn't think it would be of interest? As for the radio and servos its pretty straightforward stuff, but again I will take some pics later for you wink 2
Redex, I have made the pack, many of my cells came from Dewalt tool batt packs from EBay, but that avenue dried up a few years ago. These cells were bought a couple of years ago loose from Hobby King. I still have another half dozen or so left about the place. The first leccy model I built was a Wot4 with this exact same setup, in fact the same motor too, that was back in 2007, that model is still flying with the original pack. The A123 are perfect for certain sized models, they can't compete on performance with the newer LiPo's but for ease of use and no nonsense safe charging I know which I would rather use wink 2
Hi Masher, thanks it doesn't look so great up close disgust But it will do for a bit of pootling about.
Dave Platt is quick to say the paint and film cannot improve a finish, a good finish is the result of whats underneath. A careful eye to what flows and a final tickle with 400 grit helps. This Solarspan is quite thick compared to Solarfilm and has helped hide the covering dings from the iron. I should have used a sock over the iron, but I never could get on with those things It will be interesting to see what the final weight is as i am sure the covering will have a penalty on that score.
Looking forward to the maiden, I have a new camera person, she is looking forward to her first go at filming one of Dads models. Might mean Chris wont have to watch a maiden flight through a viewfinder wink 2
Danny
Thanks BEB, I have a feeling it will be pretty straightforward, and as you say a non-event. The wings point in the right directions wink 2 always a good sign. I need to find a pilot as I have nothing in the scrap box to suit, bit of an odd size as 1/6 is too big. I think perhaps the cockpit is a bit small and should have been enlarged a bit.
Nigel, I took a few pics of the horns, tailwheel and how the aileron clevises ended up, neatly hidden I think?
Rudder horn is made from glass fibre board, cut with a jewellers saw. The holes for all things clevis wise are 1.6mm The horn is one piece and passes right through the rudder, the holes are in line with the hinges.
The tailwheel is an odd thing I found in the scrap bin, the axle hole was massive so I had to sleeve it with a small section of alloy tube. This spins freely on the piano wire. I soldered a 10ba brass washer both sides of the wheel to retain it and keep it centred. The piano wire runs up a slot in the leading edge of the rudder for about an inche, before a sharp 90 degree bend buried in the leading edge about a quarter inch. This is expied in and the film covering hides everything. Dont put too long a moment arm on the tail wheel as the landing shock load is on the rudder hinges and closed loop wire wink 2
The elevator horn is again a short length of glassboard. It is buried in the tailplane and glued in with 30 minute epoxy. The pushrod exits the fus and terminates in an M2 clevis. Note the locking nut, not really necessary because the pushrod cannot rotate for it to come undone, but it does eliminate any wobble of the clevis on the pushrod thread that you will sometimes find.
The clevis sits just above the aileron lower surface and is nice and unobtrusive, I am glad I revisited this. Much neater smile p
Danny
Edited By Danny Fenton on 08/04/2014 10:34:16
Hi KC no I am not really worried about it to be honest, the fit is close enough that it doesn't rattle, and I doubt the tail will be on the ground for more than a few seconds, the wheel spins on the alloy. Some taxii trials might be prudent though, even with 2.4
Thx for the heads up thumbs up
Hi CS thanks I will put some gloss clear on the spinner if it runs true wink 2 Yes the shorter nose suits it, but it is still close on c of g and could do with the nose being another 1/2 an inch shorter otherwise the cells will be behind the forward cabane bulkhead F3. No interplane struts, they are not on the plan so I wont add them.
I hope It will take off at half throttle and I will not need to find out the full throttle rpm, theoretically 8,500 which is 1500 beyond my own limit, for prop and spinner balancing reasons, not to mention the noise. An electric motor at high rpm does nothing for me.
Anyway I will try and get the last few things sorted for the weekend and we will see. Phil has come up with the great idea of fitting a camera on his Barnstormer for his maiden, I will see if I can get my keyfob camera working and will try something similar wink 2 could be very entertaining
Danny
Right last few jobs getting seen to...
Just for Nigel
For those that have never played with closed loop here is how i do it. I use a plastic coated steel trace, I have no idea the strength because it came from a show in a bag, plenty strong enough for this application anyway. In the kit (Probably from Nexus) you also get 2 x clevis attachment and 2 x the short section of brass tube. The diameter is important to make setting up easy, you can use a larger diameter tube but then it doesn't hold itself taught while you shorten all your loops wink 2 The tubing needs to be only just big enough for three strands to pass through. Through the tube, through the horn, back through the tube, then around the tube and back through. This last loop stops any slippage from causing a failure, the loop tightens on itself.
Once the loops are formed pull it all tight and then crimp. I use a small pair of side cutters, two small crimps, one at either end and one at 90 degrees in the centre. Follow this up with a drop of thin CA and the jobs a good 'un
Nigel said he wanted to see the radio installation, well nothing much to see, the wire coming out the back of the Rx is for current measurement and connects to what Jeti term a MUI.
Not shown but looking at the pics has reminded me, I have not shown a locking nut for the servo end clevises, this is because I haven't set the radio up yet. Note to self do not forget locking nut wink 2
The MUI measure current to the motor, and knowing time can therefore display consumed mAh consumed during the flight.
Just the wiring under the hood and we are ready for a final c of g and mag check smile p
Danny
Edited By Danny Fenton on 10/04/2014 16:53:56
Many thanks Danny.
It's really handy having my own personal Tutor. smiley
Are those servo arms standard with those servos or do you fit your own? Can you adjust the amount of travel much via your transmitter?
I've got a set of Futaba digital thingies that came with my FF7 set. They come with various 'arms' including small circular, slightly larger star and an even larger cross. I remember having fun on my Junior 60 getting three servos side by side to provide enough travel yet not get in each other's way.
