Former Member Posted January 24, 2015 Share Posted January 24, 2015 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted January 25, 2015 Author Share Posted January 25, 2015 Posted by Stephen Jones on 24/01/2015 20:18:38: I am of the opinion that putting servos in the wings will reduce the roll rate , as there is more weight on the wings as opposed to one servo placed in the centre of spin so the ailerons have less weight to lift. I could be wrong of course . Steve I definitely agree.. Take a wing, any wing. Hold it in the middle and rotate as if rolling. Now add a lump of modelling clay out towards the tip and try again. It is harder to startbthe roll and much harder to stop precisely. AS for setting up. WEll, I find it is more complicated building the model for two servos. Still, If you like it it with two servos go ahead. Your choice! I have used both methods and know which I prefer. Quote Link to comment Share on other sites More sharing options...
cymaz Posted January 25, 2015 Share Posted January 25, 2015 Posted by Peter Miller on 25/01/2015 08:31:33: Posted by Stephen Jones on 24/01/2015 20:18:38: I am of the opinion that putting servos in the wings will reduce the roll rate , as there is more weight on the wings as opposed to one servo placed in the centre of spin so the ailerons have less weight to lift. I could be wrong of course . Steve I definitely agree.. Take a wing, any wing. Hold it in the middle and rotate as if rolling. Now add a lump of modelling clay out towards the tip and try again. It is harder to startbthe roll and much harder to stop precisely. AS for setting up. WEll, I find it is more complicated building the model for two servos. Still, If you like it it with two servos go ahead. Your choice! I have used both methods and know which I prefer. If bell cranks run the risk of having too much slop if not done correctly, has anyone built a wing with one central servo and using snakes for the push rods? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted January 25, 2015 Author Share Posted January 25, 2015 I did a kit review many years ago. The model had a foam wing with bowden cable from the servo to the ailerons. I felt that there was far too much friction inthe control run due to the bend in the cable. There is no need for slop on bellcranks. Just drill out the holes with the correct size if drill and if you do not have an exact size of drill, use the actual size of wire that will be going through the hole to ream it out to size Edited By Peter Miller on 25/01/2015 08:55:03 Quote Link to comment Share on other sites More sharing options...
Former Member Posted January 25, 2015 Share Posted January 25, 2015 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted January 25, 2015 Share Posted January 25, 2015 Fuselage mostly done, mostly. Quote Link to comment Share on other sites More sharing options...
cymaz Posted January 25, 2015 Share Posted January 25, 2015 The thought just occurred to me about snakes. I will stick to a servo in each wing Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted January 25, 2015 Author Share Posted January 25, 2015 Looking good Paul. Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted January 30, 2015 Share Posted January 30, 2015 Did quite a bit. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted January 31, 2015 Author Share Posted January 31, 2015 Looking good. How are you going to get the pushrods or servo leads out through the wings? I see no holes. Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted January 31, 2015 Share Posted January 31, 2015 Will put holes in using a thumb drill. Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted January 31, 2015 Share Posted January 31, 2015 Wing almost finished, just needs l/e and the fuz is getting there. Final sand after the filler's dry and can start covering it. Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted February 1, 2015 Share Posted February 1, 2015 Getting there. Put the wind tips on after this photo last night. Final sand down and after fuel proof start covering the fus and wings, then put the engine in. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 1, 2015 Author Share Posted February 1, 2015 WOW! An even faster builder than I am! Quote Link to comment Share on other sites More sharing options...
Former Member Posted February 1, 2015 Share Posted February 1, 2015 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted February 1, 2015 Share Posted February 1, 2015 teed but lost it.damn site, submit Covered it, but was doing numbers the same scheme, but looks rubbish. Going for printed ones insted our s from. I want number 33, it 22. Peter, where did you get y Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 2, 2015 Author Share Posted February 2, 2015 Go on EBay and look for Vinyl letters. My favourite is "Humberstone Signs." Cheap, quick and good. and no, I am not going to answer this thre times Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted February 2, 2015 Share Posted February 2, 2015 The computer kept auto correcting, and moving the curser round the screen, as the mouse was moving.and filling in the text. Also the first submit never worked and had to type it out again, and got annoyed. In the end used the letters I made. Not that happy, but will do for now. Used Solarfilm sticky stuff. Anyway, this is where it's at: Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 2, 2015 Author Share Posted February 2, 2015 Very neat, look forward to hearing how you like the first flight. Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted February 2, 2015 Share Posted February 2, 2015 Posted by Peter Miller on 02/02/2015 18:19:30: Very neat, look forward to hearing how you like the first flight. I second that , I am also interested in building this one , so please do let us know how she flies . Steve Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted February 2, 2015 Share Posted February 2, 2015 Just connected the throttle, rudder, installed the rx and set it up. Also put some registration on the tail - doing the lettering bit-by-bit and will get there. Now to do is fit the u/c, the canopy and go fly... Next? Quote Link to comment Share on other sites More sharing options...
Chris Barlow Posted February 3, 2015 Share Posted February 3, 2015 We're going to have a few maidens to get through when this weather improves! Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 3, 2015 Share Posted February 3, 2015 Quick work Paul, looks good John Quote Link to comment Share on other sites More sharing options...
Graeme Poke Posted February 3, 2015 Share Posted February 3, 2015 That is a very pretty aeroplane. It puts me in mind of an Estrellita which I think was a American racing plane just after ww2. I have a 50" RCME plan of it that I have threatened to build one day. However maybe the Jezebel would be a better bet. Cheers Graeme Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 3, 2015 Author Share Posted February 3, 2015 BeE WARNED. Put a big whte panel under one wing. A dark model under a dark or even cloudy sky is so easy to get disoriented. THis was brought home to me the Sunday before last. A 1/2 mile walk across a very muddy sticky clay field including down into a deep (For Suffolk) valley, up the other side to a small wood to retrieve the wreckage and then walk back. Yes, I chose gthe wrong model, luckily an old and well flown won but one of my favourites, Little Bandit. YOU HAVE BEEN WARNED Quote Link to comment Share on other sites More sharing options...
