Braddock, VC Posted February 16, 2017 Share Posted February 16, 2017 On the face of it this may seem frivolous but the amount of aggro it causes between the wife and I is out of all proportion to the damage done. In my home, I am the tea maker and recently bought a new teapot to replace the bone china one which was vase shaped and useless. This teapot is fine until pouring tea, the liquid initially pours at a quick but steady pace then every so often it literally gushes out blasting tea all over the work surface. I thought that maybe the teabags where the cause so have taken to removing them when the tea has had its five minute brew time. It still does it but not on every occasion. I don't have much hair left but this is causing me to tear the little that's left out, HELP any ideas? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 16, 2017 Share Posted February 16, 2017 Throw it away and buy another Quote Link to comment Share on other sites More sharing options...
kc Posted February 16, 2017 Share Posted February 16, 2017 Put the teabags in the cups and just use the teapot for the used bags! Quote Link to comment Share on other sites More sharing options...
Keith Berriman Posted February 16, 2017 Share Posted February 16, 2017 Sounds like the lid has no vent hole maybe try without the lid and problem solved so then you may have to introduce some small packing piece under the lid to let the air in. Have a nice day Quote Link to comment Share on other sites More sharing options...
PatMc Posted February 16, 2017 Share Posted February 16, 2017 You won't get a decent cup of tea using tea bags. Sort the teapot, buy a strainer & use proper tea. Quote Link to comment Share on other sites More sharing options...
Andy Butler Posted February 16, 2017 Share Posted February 16, 2017 +1 Major Lamberts strong tea - lovely stuff. Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted February 16, 2017 Share Posted February 16, 2017 Posted by RC Plane Flyer on 16/02/2017 12:55:03: Sounds like the lid has no vent hole maybe try without the lid and problem solved so then you may have to introduce some small packing piece under the lid to let the air in. Have a nice day I agree that this sounds like the problem. The tea exits, creating a partial vacum, flow slows down. Then suddenly the teapot gets an inrush of air, the vacum dissapears and the tea gushes out! A simple way to test this is to remove the lid prior to pouring. If the effect goes away then you have found your problem. To perminantly fix it you will need a vent hole or a spacer! BEB Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 16, 2017 Share Posted February 16, 2017 Posted by Biggles' Elder Brother - Moderator on 16/02/2017 13:56:49: Posted by RC Plane Flyer on 16/02/2017 12:55:03: Sounds like the lid has no vent hole maybe try without the lid and problem solved so then you may have to introduce some small packing piece under the lid to let the air in. Have a nice day I agree that this sounds like the problem. The tea exits, creating a partial vacum, flow slows down. Then suddenly the teapot gets an inrush of air, the vacum dissapears and the tea gushes out! A simple way to test this is to remove the lid prior to pouring. If the effect goes away then you have found your problem. To perminantly fix it you will need a vent hole or a spacer! BEB As I said, Buy a better teapot Quote Link to comment Share on other sites More sharing options...
Martian Posted February 16, 2017 Share Posted February 16, 2017 Having problems pouring a cuppa is not frivolous, I agree vent hole make a new lid out of balsa Quote Link to comment Share on other sites More sharing options...
Trevor Posted February 16, 2017 Share Posted February 16, 2017 If the un-vented lid is proved to be the problem (it would be my guess, too), then a pip of epoxy at one point under the rim of the lid should be enough ease the airlock. Quote Link to comment Share on other sites More sharing options...
John Helling Posted February 16, 2017 Share Posted February 16, 2017 Drill a hole in the lid with a tile drill (not on Hammer mode) Quote Link to comment Share on other sites More sharing options...
Keith Berriman Posted February 16, 2017 Share Posted February 16, 2017 So where is Braddock,VC ?? Gone to by another teapot ??? Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 16, 2017 Share Posted February 16, 2017 Get a bigger teapot it'll urn it's keep. John Quote Link to comment Share on other sites More sharing options...
Braddock, VC Posted February 16, 2017 Author Share Posted February 16, 2017 I've been out flying. Thanks for the replies. Lid does have a vent albeit a small one of about 2 mm. Can't buy another as this is the correct colour for her indoors. I will try holding the lid a little open then, if that's successful, enlarge the vent. Quote Link to comment Share on other sites More sharing options...
Keith Berriman Posted February 16, 2017 Share Posted February 16, 2017 Hi Braddock. Is the hole clear. Could it be blocked with glaze?? Quote Link to comment Share on other sites More sharing options...
Pete B Posted February 16, 2017 Share Posted February 16, 2017 I'd get some welders gloves too - hot tea can be dangerous..... Pete Quote Link to comment Share on other sites More sharing options...
Braddock, VC Posted February 16, 2017 Author Share Posted February 16, 2017 Posted by Pete B - Moderator on 16/02/2017 17:48:47: I'd get some welders gloves too - hot tea can be dangerous..... Pete It's the work surface that suffers, not me. Quote Link to comment Share on other sites More sharing options...
Braddock, VC Posted February 16, 2017 Author Share Posted February 16, 2017 Posted by RC Plane Flyer on 16/02/2017 17:33:39: Hi Braddock. Is the hole clear. Could it be blocked with glaze?? It's clear. Blessed thing just did it again with no teabags. Thing is, this teapot, unlike others we've had, has no strainer or strum in the opening to the spout and I thought it may be associated with that. Quote Link to comment Share on other sites More sharing options...
Braddock, VC Posted February 16, 2017 Author Share Posted February 16, 2017 Posted by kc on 16/02/2017 12:51:50: Put the teabags in the cups and just use the teapot for the used bags! Don't like tea like that. Also don't want the hassle of loose tea, disposal being a pita. Quote Link to comment Share on other sites More sharing options...
PatMc Posted February 16, 2017 Share Posted February 16, 2017 Posted by Braddock, VC on 16/02/2017 18:23:05: Posted by kc on 16/02/2017 12:51:50: Also don't want the hassle of loose tea, disposal being a pita. Straight down the sink with the cold water tap running does it no problem, then rinse the teapot ready for the next cuppa. Quote Link to comment Share on other sites More sharing options...
Don Fry Posted February 16, 2017 Share Posted February 16, 2017 Posted by PatMc on 16/02/2017 18:35:34: Posted by Braddock, VC on 16/02/2017 18:23:05: Posted by kc on 16/02/2017 12:51:50: Also don't want the hassle of loose tea, disposal being a pita. Straight down the sink with the cold water tap running does it no problem, then rinse the teapot ready for the next cuppa. Pat Mc is a gentleman of taste, with no doubt a SWMBO of similar mettle. Mine does teabags. Quote Link to comment Share on other sites More sharing options...
PatMc Posted February 16, 2017 Share Posted February 16, 2017 Posted by Donald Fry on 16/02/2017 18:44:38: Pat Mc is a gentleman of taste, with no doubt a SWMBO of similar mettle. Mine does teabags. Mrs Pat doesn't share my taste in tea, she often has a cup of hot water or hot water with no more than a dash of tea in it. BTW, worst tea I've ever tasted was made by an Italian/Ozy friend. He would bung a tea bag in a mug of cold water then heat it up in a microwave oven - yuk. I never had the heart to disillusion him regarding his tea making ability, so always chose coffee at his house - Gino made great coffee. However one of his Oz friends wasn't as polite as me, when he was offered a cuppa said "Gino your tea tastes like "expetive omitted", why d'ya think the Poms always have coffee when you make it." Quote Link to comment Share on other sites More sharing options...
Former Member Posted February 16, 2017 Share Posted February 16, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Keith Berriman Posted February 19, 2017 Share Posted February 19, 2017 Waiting with patciance for my next cup of tea and thought of Braddock. Do we have any answers to the tea pot saga? Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted February 19, 2017 Share Posted February 19, 2017 try and keep up with the modern times we are in....Typhoo Q tea...straight out the jar..add watter..job done. ken Anderson...ne...1 .......2017 tea dept. Quote Link to comment Share on other sites More sharing options...
