Sid Dennis Posted December 21, 2017 Share Posted December 21, 2017 I don't have much in the way of model shops nearby. I need a filler for balsa mainly. is there anything I can by from diy stores that will do the job? Quote Link to comment Share on other sites More sharing options...
Flyer Posted December 21, 2017 Share Posted December 21, 2017 I've been using Wilko's lightweight filler; it's the one that you think there's nothing in the tub. Sands easily too. Ade Quote Link to comment Share on other sites More sharing options...
Jon H Posted December 21, 2017 Share Posted December 21, 2017 There is a specific pollyfilla that works really well but i cant remember what its called. I will try to remember to take a photo of the tub when i get home Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted December 21, 2017 Share Posted December 21, 2017 Quote Link to comment Share on other sites More sharing options...
Nigel Dell Posted December 21, 2017 Share Posted December 21, 2017 I mix my own using either Micro balloons or Bucks Composites Super lite Fairing compound and emulsion paint, if you get the match pots you can get a near match to the wood, once done I have covered with transparent film and you don’t see it. The secret is not to mix it too wet, goes on easily, dries quickly and sands perfectly, been doing it this way for years. Edited By Nigel Dell on 21/12/2017 09:53:39 Quote Link to comment Share on other sites More sharing options...
Ace Posted December 21, 2017 Share Posted December 21, 2017 As Jon mentioned - Polycell, "Advanced quick drying Polyfilla." And yes it does feel empty when you pick it up. You can even mix in a little water based acrylic brown to tint it balsa in small batches. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted December 21, 2017 Share Posted December 21, 2017 Posted by Nigel Dell on 21/12/2017 09:50:31: I mix my own using either Micro balloons or Bucks Composites Super lite Fairing compound and emulsion paint, if you get the match pots you can get a near match to the wood, once done I have covered with transparent film and you don’t see it. The secret is not to mix it too wet, goes on easily, dries quickly and sands perfectly, been doing it this way for years. Edited By Nigel Dell on 21/12/2017 09:53:39 I like the sound of that as I find the commercial one pack fillers too powdery and quite liable to flake off. I had a polyester based two part extra light filler once upon a time that sanded like wood and actually bonded to the wood. Pity I can't remember what brand it was or where I got it from. Quote Link to comment Share on other sites More sharing options...
Robert Parker Posted December 21, 2017 Share Posted December 21, 2017 John, the name you are thinking of is "One Time". I do use it as well as One strike as Dennis has put up in the above post. Both work well and a tub lasts for ages. When it dries out just add a little water and mix it in and your good to go. Regards Robert Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted December 21, 2017 Share Posted December 21, 2017 I think that it's called One Fill. Quote Link to comment Share on other sites More sharing options...
Nigel Dell Posted December 21, 2017 Share Posted December 21, 2017 Posted by Bob Cotsford on 21/12/2017 10:16:03: Posted by Nigel Dell on 21/12/2017 09:50:31: I mix my own using either Micro balloons or Bucks Composites Super lite Fairing compound and emulsion paint, if you get the match pots you can get a near match to the wood, once done I have covered with transparent film and you don’t see it. The secret is not to mix it too wet, goes on easily, dries quickly and sands perfectly, been doing it this way for years. Edited By Nigel Dell on 21/12/2017 09:53:39 I like the sound of that as I find the commercial one pack fillers too powdery and quite liable to flake off. I had a polyester based two part extra light filler once upon a time that sanded like wood and actually bonded to the wood. Pity I can't remember what brand it was or where I got it from. Yes Bob it works really well, you can experiment to find a formula that works for you, never had any let go and sands really easily so as not to damage the surrounding area, also only mix as much as you need, I had half a tub that went off hence me doing this, you can store it in an air tight container, I put a dampened piece of sponge in to help, you of course can do this with commercial products. The best bit is the cost. Quote Link to comment Share on other sites More sharing options...
Richard Wood Posted December 21, 2017 Share Posted December 21, 2017 If you have some clear dope try mixing it with talcum powder to make a filler. Works well if I remember. Could also try mixing talc with PVA or Aliphatic resin instead of the dope. Quote Link to comment Share on other sites More sharing options...
John Tee Posted December 21, 2017 Share Posted December 21, 2017 Richard, not tried that as a filler but tried it years ago as a sanding sealer. john Quote Link to comment Share on other sites More sharing options...
Richard Wood Posted December 21, 2017 Share Posted December 21, 2017 Hi John, It's many years since I used the technique but from what I remember you can vary the thickness of the mix by how much talc is used with the dope. It was good for filling the usual little cracks & 'less than perfect' joints in balsa. I've found some household fillers are a bit too coarse for balsa. Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted December 21, 2017 Share Posted December 21, 2017 Hi gents, Jon, Robert and Ron are 'very close' regarding the brand names. My 'latest version' would be: > 'One Fill' by Polyfilla > 'One Time' by Red Devil I'm using One Time mostly but they are very equivalent. Cheers Chris Quote Link to comment Share on other sites More sharing options...
Jon H Posted December 21, 2017 Share Posted December 21, 2017 I used to use the red devil but have not seen it for years Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted December 21, 2017 Share Posted December 21, 2017 I think that very close, in my case, was spot on Quote Link to comment Share on other sites More sharing options...
onetenor Posted December 21, 2017 Share Posted December 21, 2017 See if this helps https://www.google.co.uk/search?q=red+devil+filler+stockists+uk&oq=Red+Devil+filler&aqs=chrome.3.69i57j0l5.30516j0j7&sourceid=chrome&ie=UTF-8https://www.google.co.uk/search?q=red+devil+filler+stockists+uk&oq=Red+Devil+filler&aqs=chrome.3.69i57j0l5.30516j0j7&sourceid=chrome&ie=UTF-8 Or google Red Devil filler and One time Filler or in fact any of the mentioned fillers. Uncle Google is very clever you know. Quote Link to comment Share on other sites More sharing options...
Former Member Posted December 21, 2017 Share Posted December 21, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Mike Etheridge 1 Posted December 21, 2017 Share Posted December 21, 2017 I have recently used Ronseal wood filler. It dries quickly and sands easily but pongs a bit ! It comes as a moist compound that you add a proportionate catalyst to, much the same as epoxy glue. So far I have bought two tins, the first compound was coloured white and the other matched balsa colour. When it is set it is not so hard that sanding it on balsa is a problem. https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=9&cad=rja&uact=8&ved=0ahUKEwi845zc9JvYAhUqBsAKHaGvCI0QuAIIezAI&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DAjXUgsR5pFU&usg=AOvVaw1UVpA4ywsQP4wzWNfWYxbS Edited By Mike Etheridge 1 on 21/12/2017 20:17:29 Quote Link to comment Share on other sites More sharing options...
Andy G. Posted December 22, 2017 Share Posted December 22, 2017 Posted by Robert Parker on 21/12/2017 10:35:21: John, the name you are thinking of is "One Time". I do use it as well as One strike as Dennis has put up in the above post. Both work well and a tub lasts for ages. When it dries out just add a little water and mix it in and your good to go. Regards Robert Rather than adding water I revitalize mine with Poly C or the equivalent polyurethane floor varnish. I find it works well and seems to make the filler a little more resilient. Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted December 22, 2017 Share Posted December 22, 2017 Hi all, Reading Andy's comment about using PU floor varnish with the filler, It made me think about Freddie B's Secret Sauce. I've used it - for foam as it is water based - on the Depron wings of my Ballerina but on the balsa LE and TE as well. This is just a test piece of a wing section, with the foam at the top part, center section has the Freddie B 'sauce' sanded down and the bottom is primered and sanded too. One could never tell it's just 3mm Depron underneath. For those interested, you can find it here by scrolling down on page 43 of the Bella build. Maybe it could be of use to someone. Cheers Chris Quote Link to comment Share on other sites More sharing options...
Jon H Posted December 25, 2017 Share Posted December 25, 2017 finally got a really bad photo of my filler Edited By Jon Harper - Laser Engines on 25/12/2017 08:11:24 Quote Link to comment Share on other sites More sharing options...
Former Member Posted December 25, 2017 Share Posted December 25, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted December 25, 2017 Share Posted December 25, 2017  plus 1 for Ronseal wood filler two pack,comes in white or beige . Definitely no good on normal foam might be ok on the tougher foam but not tried it on Depron though. It might melt it as it's a polyester base. Quote Link to comment Share on other sites More sharing options...
Jon H Posted December 25, 2017 Share Posted December 25, 2017 Posted by Percy Verance on 25/12/2017 08:49:58: Not seen Advanced Polyfilla before Jon. In what way have they advanced it? Lighter perhaps? Not sure, its just advanced I guess! I bought it from bnq a while back, it feels like the tub is empty even when new! Quote Link to comment Share on other sites More sharing options...
