Martin Fraser Posted March 13, 2018 Share Posted March 13, 2018 Hi folks, What is the perceived wisdom for programming the esc on electric power? I'm tweaking some settings on a recent purchase of TT Yak 54 and wondering if a wind milling prop creates more drag than a braked prop. T.I.A. Marty Quote Link to comment Share on other sites More sharing options...
Don Fry Posted March 13, 2018 Share Posted March 13, 2018 Windmilling has more drag. Complicated fluid dynamics, behind me, but believe. Quote Link to comment Share on other sites More sharing options...
Don Fry Posted March 13, 2018 Share Posted March 13, 2018 Windmilling has more drag. Complicated fluid dynamics, believe me, but believe. God I hate predictive spellcheckers Edited By Don Fry on 13/03/2018 18:54:57 Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted March 13, 2018 Share Posted March 13, 2018 A windmilling prop creates much more drag than a stationary one. Whether you really notice the difference depends on the diameter and pitch of the prop and the aerodynamic performance of the plane. For the average trainer the extra prop drag from windmilling is not likely to make very much difference but high performance gliders not only stop their props but fold them as well. Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted March 14, 2018 Share Posted March 14, 2018 The brake function only works for a second or two, and is designed solely for use on a folding prop. When the throttle back, the prop is braked to a halt and the blades can fold back because of the airflow. The brake function makes little or no difference to a model fitted with a fixed prop. Tim Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted March 14, 2018 Share Posted March 14, 2018 Tim, that's not what I have found, I have an ASK11 motor glider with a non-folding prop (due to the cowl shape a folding prop cannot fold properly) and the ESC brake does stop the prop. It still turns over but only very slowly, if the brake is off it windmills and provides more drag. Back to original question, on an aerobatic prop a windmilling prop provides useful drag, e.g. on the downward section of a loop etc and also for slowing the model on landing. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted March 14, 2018 Share Posted March 14, 2018 Even on a foam Wot 4 it makes a difference, a windmilling prop certainly slows it down more than a stationary one. Quote Link to comment Share on other sites More sharing options...
Former Member Posted March 14, 2018 Share Posted March 14, 2018 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted March 14, 2018 Share Posted March 14, 2018 As far as I am aware the ESC "brake" function simply shorts out the motor wires. This causes a rotating motor to slow down pretty quickly - the same is used on many battery drills. The fact that the motor wires remain "shorted" means even at very low revs the motor will be "stiff" to turn. As shown here **LINK** It will remain in this condition as long as the ESC is powered. Quote Link to comment Share on other sites More sharing options...
Cuban8 Posted March 14, 2018 Share Posted March 14, 2018 Good way to strip the gears on a motor/gearbox prop drive. Quote Link to comment Share on other sites More sharing options...
Dickw Posted March 14, 2018 Share Posted March 14, 2018 Posted by Cuban8 on 14/03/2018 11:25:05: Good way to strip the gears on a motor/gearbox prop drive. Depends on the gearbox. A good quality box with steel gears can quite happily stop an 18" prop from 8,000 rpm in fractions of a second without any problem. On the other hand I have stripped plastic gears. Dick Quote Link to comment Share on other sites More sharing options...
Martin Fraser Posted March 14, 2018 Author Share Posted March 14, 2018 Ok folks, I'll keep it as is i.e. no brake - every little helps to slow down the approach speed! Many thanks for the input, Marty Quote Link to comment Share on other sites More sharing options...
Peter Jenkins Posted March 14, 2018 Share Posted March 14, 2018 Posted by Martin Fraser on 14/03/2018 18:37:08: Ok folks, I'll keep it as is i.e. no brake - every little helps to slow down the approach speed! Many thanks for the input, Marty Hi Marty, at the risk of stating the obvious, the elevator controls your speed on approach. So, if you want to slow down, and you don't have obstructions on approach, then a flatter approach using power to maintain the required rate of descent, is the best way of proceeding. Re braking in aerobatics when flying with electric motors, ESCs like the Jeti Spin 99, allow you to vary the amount and ramp up of prop braking so that you can adjust how much drag the braked prop provides and how quickly it ramps up. Remember, these are 21-22 inch props, so that's quite a lot of drag. This type of brake does not stop the prop dead as then there is virtually no braking. 3 blade props also increase drag over a 2 blade prop. Quote Link to comment Share on other sites More sharing options...
Martin Fraser Posted March 15, 2018 Author Share Posted March 15, 2018 Hi Peter, The strip at one of my clubs is quite short and is surrounded on all sides by tall hedges and trees, some of them pretty mature with an unnatural appetite for flying machines . Landing on a calm day can be a challenge! Cheers, Marty Quote Link to comment Share on other sites More sharing options...
Charles Smitheman Posted March 15, 2018 Share Posted March 15, 2018 Hi Marty, I have a Graupner Dandy (ancient simple glider with no airbrakes) with an electric motor and folder prop for launch. Often if it is too high on landing approach I OPEN the throttle slightly, this gets the prop spinning again, and the model can be seen to slow down and drop noticeably. It is then just a matter of shutting the throttle before touchdown to avoid prop damage. So yes, prop windmilling for steeper slower glide. I often find it more fun flying a simple old model than the latest fancy gadget! Charles Quote Link to comment Share on other sites More sharing options...
Erfolg Posted March 15, 2018 Share Posted March 15, 2018 Perhaps rather than worry about which condition generates the most drag, particularly on a non-glider type model, it is worth considering how a slow rotating prop can be useful. After all it is seldom that a power type plane has the motor switched of, other than when landing. I expect that many have found, that just having the prop slowly rotating whilst under power, has the effect of acting like a low powered brake. In that you can slow the model down, if approaching the landing a little faster than you would prefer. Quote Link to comment Share on other sites More sharing options...
MattyB Posted March 15, 2018 Share Posted March 15, 2018 I think this conversation is becoming a little more complex than it needs to be tbh. You can choose how to set the ESC purely based on the type of model and prop: Gliders with big, fine pitched folding props and no undercarriage - Brake on (minimises drag in the glide, keeps the prop out of way on landing). Any other fixed wing powered plane with a fixed prop - Brake off (creates useful drag at low revs that you can use on approach; won't stop the motor with the prop pointing downwards where it is most vulnerable on landing) Quote Link to comment Share on other sites More sharing options...
ASH. Posted March 15, 2018 Share Posted March 15, 2018 To answer the OP's question: YES. A windmilling prop creates a lot needed drag to land. I fly ic mainly and it's very noticable. If you can programme an electric to 'idle' at minium revs then that is a big plus. Good Luck Quote Link to comment Share on other sites More sharing options...
