Chris Walby Posted June 19, 2018 Share Posted June 19, 2018 Noticed that some modellers are using these and was wondering how useful they are and what different applications they can be used for. Decals simple roundels. Can you do complex shapes/multi colour? Masks for painting Make/model of cutter in use would be a bonus I have feeling that although not essential, once you have one there are many uses Quote Link to comment Share on other sites More sharing options...
Broken Prop Posted June 19, 2018 Share Posted June 19, 2018 There is a previous thread on here Chris which deals with vinyl cutters. Most of us (including me) seem to use the Silhouette Cameo, which comes with good software and will take files in other formats as well. The cutter works in true 2D, so you can cut complicated shapes easily. Basically if you can draw it, you can cut it! TruType texts can be imported so that lettering of your choice can be reproduced as well. The smallest that I have managed is about 3mm in height. As the process involves no heat, covering film can also be cut. Vinyl sheet comes in a single colour but by cutting film you can do chequered sheets etc. Paint masks are a doddle and I have even heard of people cutting printed tissue for free flight models, although I have not tried that! The machine was produced for the craft industry and there are lots of videos on You Tube showing enthusiastic ladies cutting lacy trees and the like, (not that I suggest that you do that of course). Supplies of vinyl in 300mm widths specifically for the Cameo can be obtained from MDA Supplies, although I buy wide sheet and cut it down the middle. It's cheaper that way. A very useful machine and it is the old story.....the more you use it the more you find that it can do. Pete edited for bad spelin Edited By Broken Prop on 19/06/2018 08:28:21 Quote Link to comment Share on other sites More sharing options...
Broken Prop Posted June 19, 2018 Share Posted June 19, 2018 Sorry Chris, the company is MDP Supplies. As for the other thread on here, search under 'Vinyl Cutting' P Quote Link to comment Share on other sites More sharing options...
Chris Walby Posted June 19, 2018 Author Share Posted June 19, 2018 Thanks BP, I did a search for 'Vinyl Cutters' and gto no return then tried just "vinyl" but didn't spot 'Vinyl Cutting' buried in 2012. I would have thought products and technology have moved on a bit since then hence the reposting of the question. Cheers for the info Pete, looks like that could be going on the Birthday present list...at least the better half can't complain its another model! Quote Link to comment Share on other sites More sharing options...
Broken Prop Posted June 19, 2018 Share Posted June 19, 2018 for the birthday present! Another snippet that I heard was that some enterprising soul had managed to cut 1/16th thick balsa wing ribs using a Cameo. Now, if that is true, it opens up a whole new world of home design and build. If anyone out there knows of such a thing, please post on here. (I am not sure I want to try it on my machine for fear of breaking something). Pete Quote Link to comment Share on other sites More sharing options...
PeterF Posted June 19, 2018 Share Posted June 19, 2018 My wife has a Brother Scan'n'cut for crafting that I used for lettering, decals and paint masks on my 1/4 scale Tiger Moth. It worked OK, but the resolution accuracy of the machine was pushed to the limit with some of the lettering. True Type fonts can be imported, but this was a little clunky. If there is already one in the house then try it, but I do not recommend it for us modellers, I am sure that better is available. See https://www.modelflying.co.uk/forums/postings.asp?th=103321&p=18 Edited By PeterF on 19/06/2018 17:04:15 Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted June 19, 2018 Share Posted June 19, 2018 +1 for the Silhouette Cameo. In addition to True Type fonts you can import pictures of any kind and tell the Cameo software to trace the outline. So you can make paint masks for airline logos etc. There's one thing which the Cameo is supposed to be able to do, but which I haven't been able to achieve satisfactorily: You can import a drawing, and instruct it to print the picture with reference marks, on your printer, and then cut around its outline when the picture is fed into the Cameo. I tried it with a simple circular logo, which printed okay, but then it cut out an oval Quote Link to comment Share on other sites More sharing options...
Simon Feather Posted June 19, 2018 Share Posted June 19, 2018 I heart my Silhouette Portrait. I've done paint masks for clubmates (e.g. a large Miles Hawk), and one of the first things I did was our club logo, scanned from an old sticker, now I can do highly detailed any size any colour I want as long as it fits on the print bed: and everything on here - roundels, numbers, and including the intricate (but upside down - oops) Yorkshire Rose was done on the Silhouette: value for money = 11 / 10 The Portrait is a bit cheaper than the Cameo, I've not compared them directly but the Portrait has managed to do everything I've needed and in spades! Blades aren't cheap,around £9, but I've done a lot of cutting and not had to replace it yet. If you've not already got some, I recommend you get some transfer tape - this lets you cut intricate markings, weed them, then use the transfer tape to move all the separate bits as a single entity to your model. The other most useful item is a simple domestic spray bottle filled with a mild detergent mix: spray this on first, then the fresh decals can be slid around precisely until you're happy with the positioning, then squeegeed out. Without this, you have exactly one go to get it right... Edited By Simon Feather on 19/06/2018 23:04:24 1 Quote Link to comment Share on other sites More sharing options...
Andy Sephton 1 Posted June 20, 2018 Share Posted June 20, 2018 I've been using a Craft Robo cutter plotter for over 10 years, I recently upgraded to a Silhouette Cameo 3. The machine is an outstanding aid to any modeller who wants to decorate their model, I wholly recommend I wrote a brief review of the Cameo 3 illustrated with a decorated example model with masked stripes and squares plus cut lettering, for my Scale Column in the April issue of BMFA News. For info, cut tissue is possible on the Cameo 3 and Craft Robo. The technique is to pre-dope the tissue, then fix it to a carrier sheet when putting it through the cutter/plotter. Quote Link to comment Share on other sites More sharing options...
Christopher Long 1 Posted June 20, 2018 Share Posted June 20, 2018 The Silhouette Portrait was one of my best buys, I have used it to cut vinyl roundels and letters some as small as 10mm high and also water slide decals using the print and cut feature which I have found to be very accurate. It is a bit fussy on which TrueType fonts it will import (some it won't for some reason). It also imports DXF file so that I can create images and custom text in my CAD programme and then import them into the Portrait's design software - although they do need to be resized as for some reason it always enlarges them, but that is very easy. Quote Link to comment Share on other sites More sharing options...
Max Z Posted June 23, 2018 Share Posted June 23, 2018 ++1 for the Silhouette Cameo! I printed some 5 mm high text recently, ISO font iirc. Amazing quality! Your biggest problem will be finding the correct transfer film/tape. I experimented with masking film, scotch tape and regular paper masking tape, all with less than satisfying results. The vinyl does not stick very much to the backing paper (which is how it should be), but the main problem seems to be that the cut sort of pushes it down into the backing paper, and you have to carefully pry some letters loose with a sharp object (I use a #1 modelling knife for that) to make sure the transfer film lifts them without shifting or tearing. Edited By Max Z on 23/06/2018 21:24:28 Quote Link to comment Share on other sites More sharing options...
Andy C Posted February 25, 2019 Share Posted February 25, 2019 Hi all. I've all but decided to get a Silhouette Cameo. However, do I the need to buy the software upgrade to make best use of it or is the standard free software good Enough? I'm a bit confused about importing ready made files and also using jpegs of images to get cut out. Any thoughts please? Quote Link to comment Share on other sites More sharing options...
Graham R Posted February 25, 2019 Share Posted February 25, 2019 I also recently bought a Silhouette Studio.I didn't go for the software upgrade. I bought Easy Cut Studio. very happy with it. Quote Link to comment Share on other sites More sharing options...
Max Z Posted February 25, 2019 Share Posted February 25, 2019 I use the standard Silhouette Studio software. Most of the stuff I cut gets designed in my Rhinoceros cad software, then exported as .dxf which Silhouette Studio can import. Any cad program that can export in .dxf can be used of course. You can download the software for free from SilhouetteAmerica.com and see the possibilities for yourself. Max. Edited By Max Z on 25/02/2019 21:50:23 Quote Link to comment Share on other sites More sharing options...
Broken Prop Posted February 27, 2019 Share Posted February 27, 2019 Hi Andy I bought the Design Software upgrade but to be honest I did not find much difference between that and the original. As with Max, I do a lot of the design on CAD and export the files to the Cameo in dxf format. Pete Quote Link to comment Share on other sites More sharing options...
Max Z Posted February 28, 2019 Share Posted February 28, 2019 THIS is a good page to compare features of the different upgrades, with prices, and complete with links to YT videos showing the details of each feature. Oh, and remember to place your dxf design somewhere near the origin before exporting. It will save you searching for it in space when imported into Silhouette Studio . Max. Edited By Max Z on 28/02/2019 13:42:50 Quote Link to comment Share on other sites More sharing options...
Keith Billinge Posted April 4, 2023 Share Posted April 4, 2023 I recently bought the Brother Scan 'N Cut CM700 from facebook market place and I have cut some decals and I find it great to use. If you have an old offcut of vinyl you can just scan it in and choose carefully where to cut your stencils or decals. It won't do tiny stuff but it will do lettering down to 5mm. It is very accurate so if you want to print something out on your printer or import a picture then cut it out it will cope with that. There's loads of Youtube videos showing how to use the thing and mine came with an ordinary 1ft x 1ft(30cmx30cm) cutting mat a 2ft x 1ft (60cmx30cm) cutting mat and an extra sticky cutting mat for doing material. It'll also do lettering for teeshirts or iron on designs. I've tried cutting covering material with it and it'll do that too if you play with the settings. I would advise against getting a new one but if you want to give it a go get a second hand one, like I did and you get the accessories with it. I paid £90 for mine and brand new I think it was about £300. I went on Amazon and got a 40 pack of 1ftx1ft vinyl for £14 loads of different colours. The accuracy is amazing and it will cut multiple times if the cut didn't go through on the first try. It'll do RAF roundells from different colours etc and they'll fit together afterwards. Ideal for large lettering on your model or large shapes. Mine is also wi-fi enabled so you can design stuff on your PC and easily port it over to be cut. I would recommend it if you can get a cheap one on Ebay or Facebook Marketplace. Fun to use and useful to the hobby. KB Quote Link to comment Share on other sites More sharing options...
tiny-james Posted April 4, 2023 Share Posted April 4, 2023 I think I have a craft robo cutter some where in the attic up for grabs if anyone is intrested I just have to find it but I'm going away for a week camping Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted July 26, 2023 Share Posted July 26, 2023 "Whos thing tha's very important..."? Sounds like an AI bot from Yorkshire - or would that be an Ey-Up Bot? 😉 Quote Link to comment Share on other sites More sharing options...
Nigel Heather Posted July 26, 2023 Share Posted July 26, 2023 (edited) 9 hours ago, mojot said: Vinyl cutters are machines that precisely cut designs or shapes from vinyl sheets. They are commonly used in crafting, sign-making, and other applications. For window glass cleaning, vinyl cutters are not directly related, as they serve different purposes. However, a clean window glass surface can enhance the accuracy of vinyl cutter designs and ensure proper adhesion when applying vinyl decals or stickers to windows. Regular window glass cleaning is essential for maintaining a clear and attractive appearance. I did similar to you. I saw a Panasonic CM900 with loads of accessories on a local sale website for £90. It was a bit of an impulse buy to be honest as I'd not really considered one before that other than a curiosity when I had seen similar in HobbyCraft. But it seemed very little money for a machine that had good reviews, looked very lightly used and came with tons of extras. Edited July 26, 2023 by Nigel Heather Quote Link to comment Share on other sites More sharing options...
Graham Bowers Posted July 26, 2023 Share Posted July 26, 2023 8 minutes ago, leccyflyer said: "Whos thing tha's very important..."? Sounds like an AI bot from Yorkshire - or would that be an Ey-Up Bot? 😉 Better pull it's plug before it tells it's pals ! 1 Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted July 26, 2023 Share Posted July 26, 2023 13 minutes ago, Nigel Heather said: I did similar to you. I saw a Panasonic CM900 with loads of accessories on a local sale website for £90. It was a bit of an impulse buy to be honest as I'd not really considered one before that other than a curiosity when I had seen similar in HobbyCraft. But it seemed very little money for a machine that had good reviews, looked very lightly used and came with tons of extras. You're not replying to an actual person Nigel. It's almost certainly an AI bot using Chat GPT or similar AI text generation to post random, barely related, out of context replies to posts. IT's becoming an increasing problem in online fora. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted July 26, 2023 Share Posted July 26, 2023 Yes, we've had a few posts like that recently. Post and poster now deleted. 1 Quote Link to comment Share on other sites More sharing options...
Nigel Heather Posted July 26, 2023 Share Posted July 26, 2023 (edited) 21 minutes ago, leccyflyer said: You're not replying to an actual person Nigel. It's almost certainly an AI bot using Chat GPT or similar AI text generation to post random, barely related, out of context replies to posts. IT's becoming an increasing problem in online fora. I was meant to be replying to @Keith Billinge, thought I had, but clearly I clicked on the wrong 'quote' link. I'd go back and fix it but I can't because the the Forum's edit limitations. Edited July 26, 2023 by Nigel Heather Quote Link to comment Share on other sites More sharing options...
