Stuart Eggerton Posted January 26, 2021 Share Posted January 26, 2021 Hi all, I keep all of my lipo batteries in a safe which is fire proof and lockable, it has a lid which closes down tightly to seal the safe and it's quite heavy. My question is, if one of the liops malfunctioned and ignited and set the others off would the build up of pressure inside the safe cause it to explode? would I be better to drill a couple of holes in the safe to let any gasses out should they be become present? Quote Link to comment Share on other sites More sharing options...
Andy J Posted January 26, 2021 Share Posted January 26, 2021 Yes, otherwise you have created a bomb! More than 1 hole needs to be drilled as a burning lipo produces a lot of gas and foul smelling smoke. I use army surplus ammunition boxes which are very cheap to buy. Quote Link to comment Share on other sites More sharing options...
MattyB Posted January 26, 2021 Share Posted January 26, 2021 If you use an ammo box as suggested above you don't actually need to drill holes, just remove the rubber seal and you are good. This video compares a few of the options with live demos, hold on to your hats... Quote Link to comment Share on other sites More sharing options...
Stuart Eggerton Posted January 26, 2021 Author Share Posted January 26, 2021 Thank you both for your replies, I have put on order an ammo box immediately! I think the black smoke in the video with seal in place would be the rubber seal burning, that would create toxic gasses. I have a concrete floor so will keep the batteries on it maybe chocked up on two house bricks! Edited By Stuart Eggerton on 26/01/2021 15:14:56 Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted January 26, 2021 Share Posted January 26, 2021 Stuart LiPo fires are real but if the LiPo is stored at the correct storage level capacity failures are not that common. If one does go off you have to make sure the heat it creates does not set off its neighbour or you may set off a chain reaction and you loose the lot. Either keep them well apart or with a fire proof separator between. Edited By Simon Chaddock on 26/01/2021 15:45:07 Quote Link to comment Share on other sites More sharing options...
Dave S. Posted January 26, 2021 Share Posted January 26, 2021 I have to keep my LiPos in the house, nowhere else for them, so am seriously thinking of getting rid of them as I mainly fly glow anyway. Four packs of 4s (used for 2-3 flights per pack), one 3s and two 5s (none used at all). All at storage charge and with XT60s. If anyone's interested, drop me a line and I'll give you the full details. Please delete if against the rules. Quote Link to comment Share on other sites More sharing options...
Andy J Posted January 26, 2021 Share Posted January 26, 2021 Think the real hazard of using amo boxes is shorts caused by trapping the leads in the lid as considerable force is created when the lid clasp is closed. As a secondary precaution I now fit 3D printed blanking plugs to my batteries. Quote Link to comment Share on other sites More sharing options...
MattyB Posted January 26, 2021 Share Posted January 26, 2021 Posted by Andy Joyce on 26/01/2021 16:08:46: Think the real hazard of using amo boxes is shorts caused by trapping the leads in the lid as considerable force is created when the lid clasp is closed. As a secondary precaution I now fit 3D printed blanking plugs to my batteries. Agreed, but there are fixes for that. I have lined all interior surfaces on mine with thin plastic foam (~0.5mm thick) and cut down old 2 pint plastic milk cartons to put the batteries in (lead pointing towards the bottom to further reduce the chance of the issue you speak of). This stops them rattling around in transit and provides a decent degree of physical isolation each other and the outside of the ammo box itself. Edited By MattyB on 26/01/2021 16:14:35 Quote Link to comment Share on other sites More sharing options...
Rich Griff Posted January 26, 2021 Share Posted January 26, 2021 Holly Molly ! These things are everywhere these days ! Don't remember nicads doing that sort of thing. Good job I requested Bmfa sheets on lipo''s which should be with me any day now. Lipo''s can be laptop batteries, yes ? Quote Link to comment Share on other sites More sharing options...
conrad taggart Posted January 26, 2021 Share Posted January 26, 2021 Worth considering the bat safe box : **LINK** **LINK** Quote Link to comment Share on other sites More sharing options...
Stuart Z Posted January 26, 2021 Share Posted January 26, 2021 +1 for Battsafe. 👍 S Quote Link to comment Share on other sites More sharing options...
Phil McCavity Posted January 26, 2021 Share Posted January 26, 2021 Posted by Stuart Eggerton on 26/01/2021 15:13:59: Thank you both for your replies, I have put on order an ammo box immediately! I think the black smoke in the video with seal in place would be the rubber seal burning, that would create toxic gasses. I have a concrete floor so will keep the batteries on it maybe chocked up on two house bricks! Edited By Stuart Eggerton on 26/01/2021 15:14:56 Store your batteries in the ammo box and outside on a slab is the safest way. Lipo fires are usually at the lowest risk whilst in storage, charging and transporting is the greater risk to them. Quote Link to comment Share on other sites More sharing options...
conrad taggart Posted January 26, 2021 Share Posted January 26, 2021 Posted by Stuart Eggerton on 26/01/2021 15:13:59: Thank you both for your replies, I have put on order an ammo box immediately! I think the black smoke in the video with seal in place would be the rubber seal burning, that would create toxic gasses. I have a concrete floor so will keep the batteries on it maybe chocked up on two house bricks! Edited By Stuart Eggerton on 26/01/2021 15:14:56 Stuart re the seal and the black toxic spoke take a look at the second link i posted above - which shows thick black smoke spewing out of an ammo box with its seal removed. Quote Link to comment Share on other sites More sharing options...
Roger Jones 3 Posted January 27, 2021 Share Posted January 27, 2021 I keep mine in 'Tupperware' type boxes in a near-valueless shed at the bottom of the garden. The shed also contains severely crashed model planes, burnt out electric lawnmowers and other junk we haven't 'got round to' taking to the council tip. There is no need to overdo this stuff with safes, ammo boxes, etc. The likelyhood of lipos self-igniting (unless being actually used incorrectly at the time) is much exaggerated but DON'T keep them in your house. Quote Link to comment Share on other sites More sharing options...
DaveyP Posted January 27, 2021 Share Posted January 27, 2021 I live in a flat, where do you suggest I keep my Lipo's ? Quote Link to comment Share on other sites More sharing options...
Roger Jones 3 Posted January 27, 2021 Share Posted January 27, 2021 Posted by DaveyP on 27/01/2021 06:59:27: I live in a flat, where do you suggest I keep my Lipo's ? In the cooker when it's not in use But if you feel you MUST keep them in a metal box line it with plywood or similar insulating material so the plugs cannot short out against the metal sides. Don't just rely on the inside of the box being painted. Also when putting them in the metal box make the first one points to the left, the second one to the right, and so on so the plugs (and the balance leads) cannot short with each other. Shorting is much more likely than 'passive' self-ignition. Quote Link to comment Share on other sites More sharing options...
Outrunner Posted January 27, 2021 Share Posted January 27, 2021 I store and transport each lipo pack in it's own little bag. When transportinging they go either in a lipo sack or an ammo tin still in their bags. For storage I have a fire safe and a kiln. When charging they always go in the kiln. I never store any lipo loose where connectors could short on another pack. In the early days I used bullet connectors and you had to very very careful about storage. Phil Quote Link to comment Share on other sites More sharing options...
Doctor Chinnery Posted January 27, 2021 Share Posted January 27, 2021 In days of yore my LiPos used to live in my Office, neatly stacked in plastic boxes. Charging has always taken place outdoors on an old metal trolley - then I had a 3S 2200 self combust whilst charging (No, no idea why, which was particularly worrying.) To make matters worse, SWMBO saw the whole thing - result - all my LiPos were almost immediately cast into outer darkness. Fortuitously there were a couple of strong foam frozen food boxes courtesy of Donald Russell in the Barn waiting to be taken to the tip - brilliant - tough as old boots, snug fitting lids so damp proof. My LiPo boxes now live in a quiet corner outside away from the house - result - Marital Harmony. After the LiPo fire we wondered how our household insurance would have viewed their liability to make good any consequential damage to our property caused by a LiPo stored on the premises ( it goes without saying that if I'd been charging it indoors I reckon I'd be on my own). Probably partial liability if stored in the house? Any ideas Chaps? Edited By Doctor Chinnery on 27/01/2021 09:38:24 Quote Link to comment Share on other sites More sharing options...
Roger Jones 3 Posted January 27, 2021 Share Posted January 27, 2021 Posted by Doctor Chinnery on 27/01/2021 09:36:37: In days of yore my LiPos used to live in my Office, neatly stacked in plastic boxes. Charging has always taken place outdoors on an old metal trolley - then I had a 3S 2200 self combust whilst charging (No, no idea why, which was particularly worrying.) To make matters worse, SWMBO saw the whole thing - result - all my LiPos were almost immediately cast into outer darkness. Fortuitously there were a couple of strong foam frozen food boxes courtesy of Donald Russell in the Barn waiting to be taken to the tip - brilliant - tough as old boots, snug fitting lids so damp proof. My LiPo boxes now live in a quiet corner outside away from the house - result - Marital Harmony. After the LiPo fire we wondered how our household insurance would have viewed their liability to make good any consequential damage to our property caused by a LiPo stored on the premises ( it goes without saying that if I'd been charging it indoors I reckon I'd be on my own). Probably partial liability if stored in the house? Any ideas Chaps? Edited By Doctor Chinnery on 27/01/2021 09:38:24 Yeah. Sell your house and rent one. Then it won't matter to you if it burns down Quote Link to comment Share on other sites More sharing options...
Rich Griff Posted January 27, 2021 Share Posted January 27, 2021 Tesco recycle battery bins...any warnings on them I wonder, also council recycle sites ? Quote Link to comment Share on other sites More sharing options...
Wingman Posted January 27, 2021 Share Posted January 27, 2021 IT WAS A 3s 2900 Edited By Wingman on 27/01/2021 14:37:04 Edited By Wingman on 27/01/2021 14:38:14 Quote Link to comment Share on other sites More sharing options...
john davidson 1 Posted January 27, 2021 Share Posted January 27, 2021 T\wo weeks ago, in Perth a council bin collection lorry , one of the ones which compact rubbish ,caught fire in the street and completely burnt out. It is reported likely to have been caused by a discarded battery being crushed. I think that lithium ion batteries can combust as well as lipo so it may have been either I have had one lipo erupt while charging , I mistakenly set it at 3 cell instead of 2cell and did not notice the warning on the display. Luckily I charge on a concrete slab in the garage so got away with it. but it gives you a turn , Quote Link to comment Share on other sites More sharing options...
Andy J Posted January 27, 2021 Share Posted January 27, 2021 Before I dispose of my old batteries I discharge them as far as I can by connecting them to one of my starter motors and running the motor until it stops. Then I dispose of the item in a battery re-cycling bin which we had at work. Would be interested to know of other ways to dispose of old batteries as no longer have access to my work site having now retired. Have heard of some people placing the battery is salty water but not sure what happens to the battery when you do this. Quote Link to comment Share on other sites More sharing options...
John T Posted January 27, 2021 Share Posted January 27, 2021 Is storing LiPo batteries in out buildings or garages that are subject to large temperature changes likely to cause problems? Quote Link to comment Share on other sites More sharing options...
Nigel R Posted January 27, 2021 Share Posted January 27, 2021 lifespan is reduced with lots of heat cold isn't too much of a problem for lifespan, but they would benefit from being warmed before use. most recycling centres have a battery bin now Quote Link to comment Share on other sites More sharing options...
