Peter Miller Posted August 14, 2021 Share Posted August 14, 2021 Well the lockdown and lack of flying seemed to crush my inspiration. I did a few small designs one of which was a resurrected old design. I built a kit but that is not much fun as I keep thinking "I wouldn't have done it that way" At last in desperation I did a bit of doodling and came up with a bit of a mongrel design which should be very nice so this is the build blog for that. The model is electric powered.50" span This is a set of parts cut out. The basic fuselage assembled. Below is tje basic wing.It follows my standard wing construction and is built pinned down until the top leading edge is sheeted. It is cockeyed here but was pinned down to leave the under side of the leading edge over hanging the building board so I could pins in under the leading edge 2 Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted August 14, 2021 Author Share Posted August 14, 2021 Sorry, I haven't mastered just putting one picture up at a time with the new set up. The pictures show The right wing completed up to sheeting the top of the leading edge. Then muilding the second wing leaving the root rib loose. The wings are then joined with th tip of the completed wing propped up 2" and the root rib glued on and clamped . THis ensures a perfect joint at the root. This is my standard method and works. I will not go into details of someone who did not read the instructions on a similar model apartfrom to say that it is still mentioned in the club. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 14, 2021 Share Posted August 14, 2021 Have we got to wait for the end of the build to see what it looks like Peter? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted August 14, 2021 Author Share Posted August 14, 2021 Well I might photographs the plans later. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 14, 2021 Share Posted August 14, 2021 ? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted August 14, 2021 Author Share Posted August 14, 2021 3 Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted August 14, 2021 Share Posted August 14, 2021 as per usual Peter it looks great. ken anderson...ne..1..PM dept. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 14, 2021 Share Posted August 14, 2021 Thanks for doing that Peter, looks good! Quote Link to comment Share on other sites More sharing options...
kc Posted August 17, 2021 Share Posted August 17, 2021 This design does seem to be just right - good size, electric with fuselage mounted u/c, solid balsa tail surfaces, servos out in the wings ( no bellcranks or torque rods) - all very practical. And it looks like a practical type of wheel fairings too. Just the job...... Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted August 17, 2021 Author Share Posted August 17, 2021 Thanks, yes that about sums it up. Th wheel fairing work perfectly. I have used them several times before on Rhapsody etc At a distance they look like spats but are firmly but easily fixed. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted August 20, 2021 Author Share Posted August 20, 2021 Some more progress. The wing is complete apart from the tips. Aileron servo bay is made up. Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted August 20, 2021 Share Posted August 20, 2021 On 14/08/2021 at 09:01, Peter Miller said: Sorry, I haven't mastered just putting one picture up at a time with the new set up. I have been experimenting. I assume you select the pictures and paste them below the text. If so then either use choose files... or drag them into the area with the paper clip. The files will be uploaded but not placed in the text area. Type some text ending with a return for a new line. Left click the picture and it will be placed where the cursor was. Now the cursor is to the right of the added picture, it's not obvious. A couple of returns to create a gap then left click the next picture. And repeat. Hope this helps. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted August 20, 2021 Author Share Posted August 20, 2021 The fuselage now has the turtle deck fitted. There will be a head rest. The battery hatch will take a 3000 3 cell battery but that will depend on the CG location Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted August 20, 2021 Author Share Posted August 20, 2021 Sorry Early Bird Did't see you posting as I was half way though doing it and was interrupted by a long phone call. Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted August 20, 2021 Share Posted August 20, 2021 1 minute ago, Peter Miller said: Sorry Early Bird Did't see you posting as I was half way though doing it and was interrupted by a long phone call. No problem. Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted August 23, 2021 Share Posted August 23, 2021 Hmm I like the battery hatch! You are giving me ideas for The Ohmen build. ? Yes yet again you have got me thinking. Which is good as that adds to the interest and the cogs turning. It looks like you are going for ply plate wing servo mounting. Which I also like. ? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted August 23, 2021 Author Share Posted August 23, 2021 Yes,the servos are on 1/16" ply plates with uprights to screw the servos onto. I will try to post pictures of them later as shown on the Ohmen plan Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted September 5, 2021 Author Share Posted September 5, 2021 Hound Dog will be test flown today. It is the best day for months. 1 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted September 5, 2021 Share Posted September 5, 2021 Photos? (Pre flight!) Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted September 5, 2021 Author Share Posted September 5, 2021 There will be but I didn't finish the windscreen until too late Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted September 5, 2021 Share Posted September 5, 2021 ? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted September 6, 2021 Author Share Posted September 6, 2021 Well here it is. "Hound Dog" 50" span, about 4 lbs weight. It flies very nicely and is aerobatic (Not much point if it isn't aerobatic!!) 7 2 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted September 6, 2021 Share Posted September 6, 2021 Very nice Peter. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted September 6, 2021 Share Posted September 6, 2021 Like the spatlets. Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted September 23, 2022 Share Posted September 23, 2022 The free plan is in the October 2022 edition. Quote Link to comment Share on other sites More sharing options...
