Warbirds Replicas Tempest - tips and tricks
Ron Gray
1 hour ago, John Timmis said:
It distorts as soon as the prop nut is tightened
I’m assuming you mean the back plate is distorting, if so that means that the prop is not sitting correctly on the back plate. Before going any further, which prop are you using?
Ah Chris beat me to it.
Edited by Ron Gray
I started by using a 12x6 APC prop which performed well apart from the noise. I removed the spinner & have been flying without it. This morning I changed the prop for one Richard provided , don’t know the make, but it has a more conventional shape. The spinner still does not run true even with a spacer between the spinner & the backplate . I’ll try a Graupner prop if I can find one. Cheers John.
The SLEC spinners were only £3 so I guess we could expect them to be less than perfect . They have certainly been around for at least thirty years and were either a Radio Active or Micromold product . I have seen them moulded at Radio Active and by Dave Stapleton who owns MM.
I have used them on many IC models in the past without issues other than the screws stripping the plastic if over tightened .
I still use a yellow one on my Tempest and although visually I can see it does not run true , it does not produce any significant vibration .
I am using a Graupner style 12x6 with a prop washer in front of the prop hub but behind the spinner disc mount .
Having said that , Graham R is having the same vibration problem , so I think the solution is either to copy mine exactly and hope for the best , get a 3d printed one or find another 3" spinner that will probably be too pointed .
The Dubro Spinner will fit and runs very smoothly . We have it in stock for the Spitfire but only in 3 blade form which is not much help for belly landing .
However you can get a 2 blade version here
https://www.align-trex.co.uk/planes/rc-plane-accessories/rc-spinners/1-3-4in-spinner-black-1-pc-per-package-dub270.html?msclkid=11e55babe2e412c0b2443c9b9e8420bd&utm_source=bing&utm_medium=cpc&utm_campaign=Shopping MM&utm_term=4577335632823981&utm_content=PL - Everything Else MM
What I would do is buy the two blade then brutally sand the front rounded to ,make a more Tempest style profile . Should end up looking like Rons .
Hopefully a picture attached to show you how it looks after I made one of my Mk9 Spitfire's into a Mk1
I guess you could pester Ron and cross his palm with gold , but with any 3D spinner you need to accept it is your responsibility as the user if it shatters .
One thing people could try is balancing the spinner after it’s mounted. I had spinner vibration problems on my FW190 and that was how I solved it. Here is what I did:
First, I downloaded a vibration measuring app for my phone. This shows a graph and gives a figure for the level of vibration experienced by the phone.
I made 12 marks with a felt pen around the perimeter of the spinner and numbered them from 1 to 12 like a clock.
Next I placed the plane on a cushion (so it would “wobble”) and set it running at a low throttle setting - less than 20% throttle. Then leave the throttle where it is and stop the prop with your throttle cut switch. Obviously you need to be careful at this stage…
Attach the phone to the fuselage (sticky tape, elastic band - whatever works) and measure the vibration before using throttle cut again - leave the throttle in the same position at all times. Write down the vibration score.
Now put a piece of duct tape on the perimeter of the spinner at clock mark 1. Flip the throttle switch and record the vibration level. Cut the throttle, and move the tape to position 2. Record the vibration again and continue working your way around the clock.
You should get a trend of the vibration being highest at one part of the clock and lowest at the opposite end. Now you know where to add tape.
Final stage - try adding a second piece of tape. If the level gets lower again keep adding pieces until it starts to trend back up. And if adding tape increases the vibration, try removing the tape and adding only half a piece to see if your starter is too high.
Once you’ve got the score as low as you can, remove the spinner front and transfer the tape to the inside and replace - being careful to put it in the same orientation to the spinner. Don’t remove the backplate or prop, obviously.
It sounds more complex than it is - it took me about 15 minutes. I’d had multiple attempts continually remounting the spinner with the vibration never going away, and after doing this it’s been super smooth. For anyone struggling it might be worth a try - the app was free so you only have a piece of duct tape to lose.
Edited by Lipo Man
  • 4 weeks later...
Making progress as it won't be long before the Bf110 build starts in earnest and I have had a look through the other WR Tempest threads , but not found what I was after!
C of G is quoted at 80mm from LE (off the drawing), is that where people started and ended up?
What are people using for control surface throws (model with UC any difference?)?
I seem to remember Ron mention 10oz of lead, but can't find that post and could be an entirely different model!  So how much did people use?
Looking through
Ron's was AUW ready to fly without UC 2.380kg
Richard's AUW ready to fly with UC 2.635kg
Mine has UC is finished but not set the C of G  2.670kg so looks like it will be carrying more weight... heavy tail wheel not helping 🤣
I need to finish the hatch, a bit more weathering and secure the cowl, but its getting close!
  • 4 weeks later...
Maiden time!
CG at 85mm and a load of lead so AUW is 3Kg
Before and after
quite a bit of left swing on the take off roll and it needed some elevator and aileron trim but nothing that made it too hard to fly until trimmed out
Does not fly heavy with neutral stall and still needs me to slow it more on the landing as i did a novice bounce but no damage.
Pilot painting, cockpit detailing and a couple of other bits to do.
Thanks Richard, team and all those that chipped in with the build, cheers an another great keeper roll on Buckminster!
  • Like 8
  • 3 weeks later...
Fellow flier Dave started building his Tempest. I see that he used tapes when gluing the LE and TR sections of the wing. The tapes are guarding against the Gorilla glue spill overs. This should give a much cleaner end product.
Edited by Murat Kece 1
I checked the balance for a CG at 85mm, I need 381 gr ballast (and space for it)!  So the battery hatch is ow glued to make space for ballast. I thought I was diligent with weight management - but clearly not sufficiently!
  • Aircraft: 2013 gr
  • Battery : 348 gr
  • Ballast  : 381 gr
Estimated  AUW:    2742gr. As Richard pointed out it should be able to handle such a weight.
  • Aircraft: 2013 gr
  • Battery : 348 gr
  • Ballast  : 381 gr
Don't worry about the weight...speaking from experience (with this model at least) my AUW is 3Kg and it flies well and does not show the pitch up/throttle issue others have had. It takes off and lands a treat + flies very slowly with no apparent tendency to drop a wing on the stall test.
I was very pleasantly surprised how warbird like it flew from the previous comments (C of G at 85 as I was not going to add anymore lead). I made a ply box underneath the motor that nearly touches the cowl and sits into the air scoop to get all my lead in.
PS I'll work out the wing loading out of interest compared with the FW190, but it can't be far off or that dihedral helps.
PPS part of the heavy tail wheel club! 🤣
