Edgeflyer Posted September 6, 2024 Share Posted September 6, 2024 I want to put this nice vintage 049 engine on a Sharkface. It's a rear reed valve type with radial mounting. I'm confused as to whether the rear mount doubles as fuel tank as it is not obvious where the filler is. Quote Link to comment Share on other sites More sharing options...
Robert Welford Posted September 6, 2024 Share Posted September 6, 2024 There should be a pipe(s) coming out of the back plate. 049 Babe Bee.pdf Quote Link to comment Share on other sites More sharing options...
RottenRow Posted September 6, 2024 Share Posted September 6, 2024 As Robert says, vertically, right next to the needle. Brian. Quote Link to comment Share on other sites More sharing options...
Robin Colbourne Posted September 6, 2024 Share Posted September 6, 2024 (edited) Edgeflyer, If your Babe Bee has been assembled from random Cox parts that someone had laying around, it is possible that they used a Golden Bee or Black Widow backplate, which doesn't have the filling pipe on it. In this case the filler projected from the top of the tank itself, whilst the vent projected from the bottom, as in this picture. You may need to either get a Babe Bee backplate or a Golden Bee/Black Widow tank, carburettor pipe and mounting screws (the latter being longer than yours). Otherwise, if you're prepared to butcher the engine, then just drill a small hole in the top of the tank to fill it (dismantle the engine first so you can clean away all the swarf). A Babe Bee back plate should have either a filler pipe to the left of the needle valve or a pipe each side like this: Given how many Cox engines were produced, the price they sell for these days is insane. A look through the various Cox engines for sale here gives some idea how many variants there are, even this small selection shows three different varieties of extended tanks. Den's Model Supplies on the Isle of Wight is the 'go to' place for Cox spares in the UK these days. Edited September 6, 2024 by Robin Colbourne 1 1 Quote Link to comment Share on other sites More sharing options...
Phil Green Posted September 6, 2024 Share Posted September 6, 2024 2 hours ago, Edgeflyer said: I want to put this nice vintage 049 engine on a Sharkface. Good man! 👍 Quote Link to comment Share on other sites More sharing options...
Rich Griff Posted September 7, 2024 Share Posted September 7, 2024 Yes, goto dens model supplies.... Fuel pick up pipe and spring, for full tank run not control line. Even RC back plates are available, check on Cox engine forum for suitability.... Larger Cox tanks available, or, sacrifice the small tank with suitable hole and run fuel pipe to "external tank" of larger capacity..... Cox engine forum..... Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted September 7, 2024 Share Posted September 7, 2024 Amazing that an engine so small can make so much noise -and be loads of fun. Some people are like that! 🤩 Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted September 7, 2024 Share Posted September 7, 2024 For best performance you will need a fuel with 16% nitromethane . Odd sort of number but makes a world of difference. Dave watts when he owned SMC fuels made a cox mix . From memory it was castor based . The new owner still makes 15% nitro castor based . I ran a littl 2 chanel model back in the 1980's with a Cox Black widow. Ran it on my normal fuel 10% and although it ran it wasnt t As good as i remdbered them as a boy. I tried some SMC cox mix and wow .night and day difference, plus it ran for two or three times as long on same ammount of fuel. As RC says your engine could be a bitsa. The mounting plate does look like its plastic from a later model with no filler pipes. Loads about so a new backplate shouldnt be a problem . Two other options is drill two filler holes either side of the NV or dril tank an run pipe to an external tank. Beware, if taking second option dont make tank too big !! As they run for ages on a sniff of fuel. You can also find backplates / NV assemblies desiigned for using with external tanks as used in the RTF CL models from years ago. Ill have a look in my box of cox odds and ends later to see if i have any bits. Quote Link to comment Share on other sites More sharing options...
Rich Griff Posted September 7, 2024 Share Posted September 7, 2024 Hi engine doctor, in your Cox box, might you have any td09 bits and bobs, or even medalion 09 bits ? ? Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted September 7, 2024 Share Posted September 7, 2024 Hi Rich , the medallion and TD 09 stuff went a long time ago , sorry , Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted September 7, 2024 Share Posted September 7, 2024 Talking about cox engines Ive in the last few minutes bought from a club mate a Graupner Viper mini pylon racer with a cox TD in it and a spare complete kit . should be interesting if I can get it up and in flying condition ? Quote Link to comment Share on other sites More sharing options...
Rich Griff Posted September 7, 2024 Share Posted September 7, 2024 (edited) Thanks ed .... Nice one....td049 or larger in the viper...? Pm me so we don't get "told off" for poluting/thread drift, or start a new thread even. I am sure others will be interested. Good article on TV this morning about lipo's.....but that's a whole other bag of bitter lemons and we'll worth a new thread all if it's own....lest we forget... Shark face is only one of the RC models a cox 049 with drag around the sky....remember kk nitrex 15 ? Edited September 7, 2024 by Rich Griff Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted September 7, 2024 Share Posted September 7, 2024 5 hours ago, Engine Doctor said: From memory it was castor based . The new owner still makes 15% nitro castor based . Music to my ears,, you opened the door ED,,,😄two more to go,,,🤢 Quote Link to comment Share on other sites More sharing options...
Rich Griff Posted September 7, 2024 Share Posted September 7, 2024 See Cox engine forum about lub for these little jems. Quote Link to comment Share on other sites More sharing options...
Edgeflyer Posted September 7, 2024 Author Share Posted September 7, 2024 Closer examination shows a single tiny pipe more if a capillary tube! Next to the needle valve. So is that for filling or sucking from a small external tank? Quote Link to comment Share on other sites More sharing options...
Phil Green Posted September 7, 2024 Share Posted September 7, 2024 Many had a simple modification where the short internal pick-up tube was replaced with a length of fuel tube run through a hole drilled on the tank wall to an external tank This was usually done to give a longer run but sometimes for tree-flight to give a short. controlled run. Quote Link to comment Share on other sites More sharing options...
Robin Colbourne Posted September 7, 2024 Share Posted September 7, 2024 (edited) 30 minutes ago, Edgeflyer said: Closer examination shows a single tiny pipe more if a capillary tube! Next to the needle valve. So is that for filling or sucking from a small external tank? That will be for filling. These Cox 049 instructions infer that there is a small hole near the needle valve for venting. I've not studied one of these later ones though. This backplate on the Cox international site makes it clearer. The vent hole is right next to the base of the filler tube (see red circle in the picture). Hover your mouse over the picture so it zooms in and you will see the vent hole at about 10'o clock if you use the base of the filler tube as the centre of the clock. Edited September 7, 2024 by Robin Colbourne Quote Link to comment Share on other sites More sharing options...
Edgeflyer Posted September 7, 2024 Author Share Posted September 7, 2024 Aha! Thanks for that. I will try filling and starting. I seem to remember something about British 049s like the DC Wasp needed 1.5 volt on the plug but Cox needed 2 volt. (Or t'other way round??) Quote Link to comment Share on other sites More sharing options...
Robin Colbourne Posted September 7, 2024 Share Posted September 7, 2024 2 minutes ago, Edgeflyer said: Aha! Thanks for that. I will try filling and starting. I seem to remember something about British 049s like the DC Wasp needed 1.5 volt on the plug but Cox needed 2 volt. (Or t'other way round??) DC Wasp & Bantam, Testors/McCoy and Cox are all 1.5V. It is best to use a nicad or Nickel Metal Hydride (NiMH) cell as anything over 1.5V runs the risk of burning the plug/head out. Quote Link to comment Share on other sites More sharing options...
Robin Colbourne Posted September 7, 2024 Share Posted September 7, 2024 I was at the Popham Show today, and 'A Plane Olde Bargain' had several Cox 049s on his stall at £15 each. That is a lot less than ebay prices. Quote Link to comment Share on other sites More sharing options...
Edgeflyer Posted September 7, 2024 Author Share Posted September 7, 2024 Thanks for the voltage info and the prices info. Mr Plane OB does sell on eBay but he probably then wants to cover fees Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted September 8, 2024 Share Posted September 8, 2024 (edited) Hi Edgeflyer Just for info . Most Glow plugs have been 1,5 volt over the years . Some 2 volt plugs became available back when 2 V sealed lead acid types became available. Always use a single Nimh or a few in parallel to give 1.2 volts and plugs will last a long time especially the glow heads that cox use as they are harder to come by now and expensive . Plug doesnt have to glow bright red like some think . A dull red glow is quite sufficient Edited September 8, 2024 by Engine Doctor Quote Link to comment Share on other sites More sharing options...
Jim Hearnden 1 Posted September 8, 2024 Share Posted September 8, 2024 The USA always used 1.5V plugs, probably because they had decent dry cell batteries to power them. Bare in mind that the USA was the home of glow motors originally. Not sure where 2V plugs originated. probably Europe where 2V SLA were freely available. I always used a 2V lead acid with very long, thin leads until I came into the 20th Century & used a glowstick. 2V plugs are like hens teeth these days but I remember were OK with a 1.5V source. In those days lots had power panels with a 12V SLA and a voltage reducer which you adjusted for a dullish red on the plug. Oh happy days & how time moves on. Quote Link to comment Share on other sites More sharing options...
RottenRow Posted September 8, 2024 Share Posted September 8, 2024 The Keil Kraft ready to fly (ready to crash) control line Hurricane of the 1970s came with a Testors / McCoy .049 with a similar glow head to the Cox. The glow clip that came with the model had a plug on the lead that was ready to use with an Ever Ready AD4 battery (not included, of course, and not cheap then). This was a dry cell 1.5V battery that originated in the days of valved portable radios, where it was used as the LT power source. Brian. Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted September 8, 2024 Share Posted September 8, 2024 AD 4 battery's cost me more than fuel with my Merco .35, I could never get the thing started ! Quote Link to comment Share on other sites More sharing options...
