cymaz Posted March 17, 2016 Share Posted March 17, 2016 St Austell Models is still in the Market House. Owned and run by Paul Evans....great bloke Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted March 17, 2016 Share Posted March 17, 2016 I see "established 17 years." Should be over 60 years. They used to come up to St Mawgan and set up in the airmen's mess on a Thursday after payday. Happy days!! Quote Link to comment Share on other sites More sharing options...
Chris Barlow Posted March 17, 2016 Share Posted March 17, 2016 Posted by cymaz on 17/03/2016 20:54:43: Posted by Percy Verance on 17/03/2016 20:32:51: I'm down in Cornwall for a week in August cymaz. I may try to put in an appearance......... Without referring to a map, I'll be based near Helston. Roughly how far will I be from your club? 30miles from Helston to St Austell about 1hr drive......depending on the holiday traffic Spent a year working in St Ives 3 years ago. Holiday traffic! Down in that area (St Ives/Hayle) there's also Cornwall & District MAC (I think that's what they're called). One of their flying sites is just East of Godrevy Point. Quote Link to comment Share on other sites More sharing options...
Former Member Posted March 17, 2016 Share Posted March 17, 2016 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
bouncebounce crunch Posted March 18, 2016 Share Posted March 18, 2016 Gifted to me a damaged Yellow J-3 Cub rebuilt and realigned from rear of cabin to tail, covered in hobby king stuff and 4-5 hours of work before returning to the air. OS 40 2stroke. model was electric. Taylor J-2 cub is the sport scale i aimed for. Quote Link to comment Share on other sites More sharing options...
Gary Vinten 1 Posted March 18, 2016 Share Posted March 18, 2016 old one done up as they say Edited By Gary Vinten 1 on 18/03/2016 11:16:40 Quote Link to comment Share on other sites More sharing options...
Andrew Price 2 Posted March 18, 2016 Share Posted March 18, 2016 It's those slow moving truck drivers, enjoying the views over the hedges, that cause the problems Percy!! Quote Link to comment Share on other sites More sharing options...
Chris Barlow Posted March 20, 2016 Share Posted March 20, 2016 Maiden this afternoon of my DB 58" Tiger Moth bought as an airframe and restored over the last 6 months (between other projects) Powered by an ASP .52 fs, covered with solartex and sprayed with Humbrol enamels. First flight was very tail heavy resulting in an out field landing, minor undercarriage damage and a broken prop. 2nd flight much better but still needs more nose weight! CoG will eventually be about 30mm in front of the rear cabane struts. Edited By Chris Barlow on 20/03/2016 18:34:24 Quote Link to comment Share on other sites More sharing options...
cymaz Posted March 20, 2016 Share Posted March 20, 2016 Chris, does this help? Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted March 20, 2016 Author Share Posted March 20, 2016 Quote Link to comment Share on other sites More sharing options...
Mike Rieder Posted March 20, 2016 Share Posted March 20, 2016 1/6. Typhoon just maidened today, loved it. Edited By Mike Rieder on 20/03/2016 19:46:11 Quote Link to comment Share on other sites More sharing options...
Chris Barlow Posted March 20, 2016 Share Posted March 20, 2016 Posted by cymaz on 20/03/2016 19:22:06: Chris, does this help? Thanks cymaz. I was looking on the DB site a while ago and whilst there are some differences between that and my "old" tiggie it does look like the CoG is going to be closer to 100mm. Most of the information I found on the internet put it on the rear cabane where it meets the top wing (about 150mm) I estimate the new CoG to be about 120mm from the LE/centre so might just go for 100mm anyway? I could make some of the ballast removable if it's too nose heavy. Quote Link to comment Share on other sites More sharing options...
Geoff S Posted March 21, 2016 Share Posted March 21, 2016 Posted by Chris Barlow on 20/03/2016 20:26:20 I estimate the new CoG to be about 120mm from the LE/centre so might just go for 100mm anyway? I could make some of the ballast removable if it's too nose heavy. My 58" DB Tiggie has the CoG set at 100mm and the maiden (late December) went well but needs quite a lot of ballast to get it so far forward. Mine's electric but is a conversion from a part completed model I was given so I wasn't easily able to get the battery as far forward as I'd have liked. It's also a pre CNC cut kit and several years old. I haven't flown it since but I'm kicking myself I didn't take it to the field yesterday because the weather was fantastic. Tim Hooper has recently completed a Tiggie for his RCME column but one slightly smaller than the DB and his CoG is a lot further back and nearer to the position of the full size. It's a page or so back from here in the 'New Models' thread. I think your 120mm figure will probably be OK. I'm intending to remove ballast progressively to save a bit of weight. Mine's pretty heavy at just over 3kg - far heavier than than that quoted on the DB S&S web site. Geoff Quote Link to comment Share on other sites More sharing options...
chris Bond - Bondaero Posted March 30, 2016 Share Posted March 30, 2016 New trainer for 2016 95% done. If you are old enough you will recognise it. Quote Link to comment Share on other sites More sharing options...
Stevem3akm Posted March 30, 2016 Share Posted March 30, 2016 Kamco Kadet? Quote Link to comment Share on other sites More sharing options...
Alan Jarvis Posted March 30, 2016 Share Posted March 30, 2016 Here are some pics of my South Herts Models Vulcan. 6ft wingspan, weighs 10lbs without battery and finished as per the original anti flash white. Quote Link to comment Share on other sites More sharing options...
Robert Parker Posted April 2, 2016 Share Posted April 2, 2016 Hi All, Just finished my Balsa USA Taube 40, very quick to build. Something for those long hot summer days. you've got to hope haven't you. Crewed by the Maxford twins 1/8 scale Regards Robert Quote Link to comment Share on other sites More sharing options...
pete taylor Posted April 2, 2016 Share Posted April 2, 2016 Here's a few pictures of a project that I've been working on for a while now, also posted in the EDF section. It's a Canberra PR9 from the former Greenair Designs kit, now being produced by the designer, Jim Gordon. 1780mm span with an AUW of 3.8kg for a wing loading of around 16oz/sq ft She's for 2 x 64~70mm EDF units - I've got EPF Mercury 64s in this one. Waiting for the maiden. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted April 2, 2016 Share Posted April 2, 2016 Nice one Peter. I see what you mean by the extended root chord. Quote Link to comment Share on other sites More sharing options...
Alan Thorpe Posted April 2, 2016 Share Posted April 2, 2016 Super models here!! Great skills! Amazing. Quote Link to comment Share on other sites More sharing options...
Tony Cook Posted April 2, 2016 Share Posted April 2, 2016 Hi There, Here;s my take on Carl Goldberg 'Skylark twin' (plan circa 1965) Oracover / solarfilm / solartrim , SC25;s JR 2.4 gear. Its really fun to fly something different..and IC twin always poses a challenge!!! Quote Link to comment Share on other sites More sharing options...
bouncebounce crunch Posted April 3, 2016 Share Posted April 3, 2016 Seagull Ultimate Second flight today, OS 120Ax, this is the first model that i have ever experimented with Exponential, and i feel that this will present challenges for my usual non aided flying style. It is unerving when you move the sticks and nothing is happening. Other than that she loops and rolls very well and lands nicely. Quote Link to comment Share on other sites More sharing options...
Former Member Posted April 3, 2016 Share Posted April 3, 2016 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
David Davis Posted April 3, 2016 Share Posted April 3, 2016 Percy, BBC lives in Australia. Quote Link to comment Share on other sites More sharing options...
cymaz Posted April 3, 2016 Share Posted April 3, 2016 Edited By cymaz on 03/04/2016 07:46:44 Quote Link to comment Share on other sites More sharing options...
