Dai Fledermaus Posted December 19, 2014 Share Posted December 19, 2014 As a callow youth, I seem to remember having no problems soldering fuel tanks together from galvanised tin plate for some of my control line models, but at the moment I can't seem to keep my soldering iron clean enough for more than a minute or two to solder some undercarriage legs together. I've bought and tried various paste type flux, but the copper tip of my 70watt iron soon goes black, so I have to stop, let it cool and clean it up again to a bright copper finish only for the same thing to happen again. Time consuming and very frustrating. The only flux I haven't tried is Bakers Fluid, only because I can't buy it locally. Could this be the answer? Quote Link to comment Share on other sites More sharing options...
Andy Green Posted December 19, 2014 Share Posted December 19, 2014 You don't want a copper finish, the solder will eat copper, that what the tin coating is for. No need to let it cool, use a damp tea towel, and just wipe on that, with the iron at working temp. Andy Quote Link to comment Share on other sites More sharing options...
TigerOC Posted December 19, 2014 Share Posted December 19, 2014 Confirm what Andy said. You need to break the tip in so that the tip and area above has a nice shiny silver sheen and keep it like that using a damp cloth or damp natural sponge. If it gets dirty flood the tip with cored solder and bang it off and then wipe. Rob Edited By TigerOC on 19/12/2014 16:37:50 Quote Link to comment Share on other sites More sharing options...
Braddock, VC Posted December 19, 2014 Share Posted December 19, 2014 U/C legs and soldering thereof can be one of life's greatest trials; sacrificial insulation is what you need. Cyno together two bits of wood, hard balsa is good, with a rightangle between them. Face the inside with several folds of kitchen foil or cut up a beer/coke can or similar, just ensure that the shiny side is toward the outside. Place over the wire to be joined ( I cyno mine to the leg, one less thing to worry about) and let your iron heat up whilst you were making this, needs a good 10 mins to stabilise. File the tip shiny beforehand then using multicore run some over and wipe off as suggested (damp paper towels is what I use). Then solder - you shouldn't need to move your insulating thingy, just ensure that the uncovered back is uppermost so all the heat rises to the wire. Feed your solder in from the top. Fixed it for me oh and I use the copper wire from 2.5 mm squ mains cable to bind the joint. The wire on my Wot4 took about 2 - 3 mins before it was hot enough to fuse the solder and I use a 100 Watt iron. Quote Link to comment Share on other sites More sharing options...
Plummet Posted December 19, 2014 Share Posted December 19, 2014 Just a thought. Are you using an old soldering iron and new solder? The new elfin safety solder is lead free and needs a higher temperature, and is a pig to use. You can, however, still buy the old stuff at some places. Plummet Quote Link to comment Share on other sites More sharing options...
monty2 Posted December 19, 2014 Share Posted December 19, 2014 Perhaps you should look at the Galvanising, That is probably the issue, try using some sandpaper or emery cloth to remove the galvanising. that is always a pain for paint or other coverings. Edited for language Edited By Biggles' Elder Brother - Moderator on 19/12/2014 18:01:04 Quote Link to comment Share on other sites More sharing options...
Dai Fledermaus Posted December 19, 2014 Author Share Posted December 19, 2014 Posted by Plummet on 19/12/2014 17:01:58: Just a thought. Are you using an old soldering iron and new solder? The new elfin safety solder is lead free and needs a higher temperature, and is a pig to use. You can, however, still buy the old stuff at some places. Plummet That's interesting. The solder I'm using is solid wire and it is lead free, the flux is a water soluble type both from B&Q. The iron is perhaps 8 years old. I can tin the tip of the iron O.K. but it doesn't stay that way for long and brushing on some flux or dipping the iron in the flux doesn't seem to make much difference. I haven't tried the damp cloth method, but I will. I seem to remember using a flux which was a liquid, perhaps it was acid based rather than a paste and dipping the tip of the iron in that cleaned off all the crud. Quote Link to comment Share on other sites More sharing options...
Vecchio Austriaco Posted December 19, 2014 Share Posted December 19, 2014 lead free solder - This may probably the issue Fledermaus! I stocked up with several different soldering wires 5 years ago. Cannot be bothered to throw away all my soldering equipment. VA Quote Link to comment Share on other sites More sharing options...
kc Posted December 19, 2014 Share Posted December 19, 2014 www.component-shop.co.uk sell old fashioned tin lead solder which melts at 183C to 188C ( lead free melts at 207C to 217C they say) Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted December 19, 2014 Share Posted December 19, 2014 Leaded solder is definitely easier. The claim you occasionally hear that it's very difficult to get, or even that it can't be bought now, is nonsense. It's not allowed for commercial operations but perfectly legal and available for hobby use - but you have to go to an appropriate supplier - not B&Q! I worry about all this stuff about filing tips! I've never filed a solder tip yet, and never needed to and in fact I think that filing most modern tips would be very bad for them. I use a damp natural sponge pad that is set into my soldering iron stand combined with a very occasional dip into the flux and the iron remains tinned. One thing that is slightly non-standard is that I use 9% phosphoric acid as a flux. This is an excellent flux, cleans wonderfully. The only downside is you do have to carefully rinse any joints under running water afterwards to make sure that all traces of the acid are removed. Nothing is for free! BEB Quote Link to comment Share on other sites More sharing options...
G-YRUS Posted December 19, 2014 Share Posted December 19, 2014 I solder nearly every day, admittedly copper tube but I use my work flux on piano wire etc and have no issues no matter what the so called experts say in the magazines. Use one of the self cleaning fluxes readily obtainable from usual outlets and wipe off with a damp cloth on completion. Concur on above and keep your iron tip clean with a damp cloth but tinned with solder don't sand it of. The above assumes your not soldering electrical components as these are not good fluxes. Temperature control is important and most faults are due to a low temperature so an adequate size iron to the size of job is a must, trying to heat something to slowly burns the flux as does to hot. Now I would say I am an expert and I use a flame on all my wire etc but do have various nozzles and 40 plus years of practice. I also have a really good quality iron with various tips and temperature adjustment. Lead free solder requires a slightly different technique as its melting point is higher and is more brittle when cold. Its just practice looking for the metal and flux colour as you heat it and feeding the solder at the right time. I guess the useable temperature range is smaller but I don't really need to think about it when working. Lead based solder is still available and I cut down mine to size required. Soldering came up in another thread and MAPP gas was mentioned. Reserve this for silver soldering as it is really for refrigeration work and burns much hotter than propane but can be useful outside in the winter. Quote Link to comment Share on other sites More sharing options...
Dai Fledermaus Posted December 20, 2014 Author Share Posted December 20, 2014 Thanks for your thoughts on this fellers Quote Link to comment Share on other sites More sharing options...
Kevin 216 Posted December 20, 2014 Share Posted December 20, 2014 I also had difficulty getting the solder to stick. I now clean the wire with a dry scouring pad, pre-tinned copper wire (available from CPC) and silver solder (from Maplins), and a 100W iron. So far the results have been good. Quote Link to comment Share on other sites More sharing options...
FlyinBrian Posted December 20, 2014 Share Posted December 20, 2014 Posted by 216er on 20/12/2014 10:48:49: I also had difficulty getting the solder to stick. I now clean the wire with a dry scouring pad, pre-tinned copper wire (available from CPC) and silver solder (from Maplins), and a 100W iron. So far the results have been good. I don't think you mean "silver solder" as that requires much more heat than an iron can provide. Quote Link to comment Share on other sites More sharing options...
Plummet Posted December 20, 2014 Share Posted December 20, 2014 Posted by FlyinBrian on 20/12/2014 13:09:44: I don't think you mean "silver solder" as that requires much more heat than an iron can provide. Well... I think that there is a terminological problem here. If my memory is not playing too many tricks I think that there is a form of low temperature silver solder, the purpose being to provide a very low resistance (electrical resistance - ohms and all that) joint. The other sort of silver solder is more like a brazing rod, and you need a lot more heat - in that the metal glows - to use it. Type 2 is, I believe, a lot stronger than type 1 which is only intended for electrical and not structural purposes. Confusing isn't it. Plummet Quote Link to comment Share on other sites More sharing options...
Dai Fledermaus Posted January 16, 2015 Author Share Posted January 16, 2015 Problem solved! It wasn't my iron. It wasn't the solder I was using. It wasn't my technique. I simply used a different flux to the paste types I was using previously, ie Baker's Soldering Fluid No3 and .......................... Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted January 16, 2015 Share Posted January 16, 2015 I am not sure that is solidly soldered. I would expect the solder to have flowed over the piano wire, your picture seems to show solder as only flowing on the thinner binding wire... This pic is from Andy Greens thread and shows what I would expect to see. Just a thought and of course I might be misinterpreting your photograph Cheers Danny Quote Link to comment Share on other sites More sharing options...
G-YRUS Posted January 16, 2015 Share Posted January 16, 2015 I would second Danny it looks like the solder has not taken to the piano wire just the wrap. Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted January 16, 2015 Share Posted January 16, 2015 I agree with Danny Fenton , that joint is not properly soldered. one good knock and it will all come loose It looks from the pic that the piano wire needs proper cleaning and tinning (coating with a thin layer of solder)prior to assembly . Clean wire only with glass paper and not emery or wet and dry paper. They can often impregnate the surface with carbon that will reject solder . Once tinned bind joint with clean copper wire , apply some Bakers Fluid flux and solder all together . The solder should as said flow onto the wire as well as the copper. Solder will flow easily onto copper as it has an affinity to it . A Trick I was taught at school in metal work class for tinning steel or piano wire or any ferrous metal is to clean the metal thoroughly then dip it into a solution of Copper Sulphate . This leaves a very thin coat of copper particles on the steel that will attract the solder making soldering easier . The picture also looks like not enough heat is being use. What size iron are you using ? You will need a decent sized iron the higher wattage the better . Suggest a 100W . The old fashioned heat up up type that you heated on the cooker work well but again you need a decent sized tip to store enough heat for the job. If you have a small blow lamp then it could be soldered with that by heating just at the edge of the joint after preparing it and allowing the heat to travel through the joint allowing the solder to flow with it . Quote Link to comment Share on other sites More sharing options...
Dai Fledermaus Posted January 16, 2015 Author Share Posted January 16, 2015 Fellers, Looks can be misleading. The two legs were soldered together first, the joint cleaned really well, then wrapped in copper wire and soldered again, the fact that you can't see that in the photo doesn't mean that it's a weak joint and "that a good knock and it will come loose" Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted January 16, 2015 Share Posted January 16, 2015 Thats good to hear, as I said I might not be seeing the full picture, but I had to ask Cheers Danny Quote Link to comment Share on other sites More sharing options...
Shaunie Posted January 16, 2015 Share Posted January 16, 2015 Sorry Dai, but I have to agree with the others. If the solder has not wicked out from under the binding onto the piano wire I would not accept it. Even if the piano wire is soldered underneath the situation you have will cause a stress raiser and the joint will crack and thus fail at some point. The discussion about filing soldering iron bits depends on the type of bit. Early bits were solid copper, could be filed and in fact needed to be as the solder dissolved the copper resulting in the tip needing frequent re-profiling. Modern bits however are iron coated, have a very long life and should never be filed. Use a soldering iron sponge kept damp, not soaking wet to clean the tip. If the tip goes black in a short period of time then your temperature is too high. The golden rule is to have plenty of Watts but always use a thermostatically controlled iron, especially if you solder only infrequently. Shaunie. Quote Link to comment Share on other sites More sharing options...
Poppy Ann Lynagh-Smith Posted February 21, 2015 Share Posted February 21, 2015 Posted by Dai Fledermaus on 19/12/2014 16:03:08: As a callow youth, I seem to remember having no problems soldering fuel tanks together from galvanized tin plate for some of my control line models, but at the moment I can't seem to keep my soldering iron clean enough for more than a minute or two to solder some undercarriage legs together. I've bought and tried various paste type flux, but the copper tip of my 70watt iron soon goes black, so I have to stop, let it cool and clean it up again to a bright copper finish only for the same thing to happen again. Time consuming and very frustrating. The only flux I haven't tried is Bakers Fluid, only because I can't buy it locally. Could this be the answer? Hi Dai, it sounds like you have the iron set to high if the tip turns black quickly after cleaning and tinning it, you mentioned you use to solder "galvanized Tin plate" it is either galvanised or tin not both, galvanised is coated in zink and tin is coated with ti. if it was tin plate then it is easy to solder but Galvanized plate is harder, a thing to watch out for is the fumes that come off Galvanized plate are not good to breath so try not to end up breathing them. It is much easier to use bakers fluid to solder plate items than to use cored solder but always remember to remove all the flux after you finish soldering, the best way is with warm water for most people. I know you are meant to wash it off with an acid but for most of us we do not like to keep acid around the home and water removes almost all of it good luck with your project, Regards Poppy Ann. Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted February 23, 2015 Share Posted February 23, 2015 Just having a look at this thread. I am a professional solderer and the only type of iron worth having is a temperature controlled one. I do not use anything flashy at work, just a cheap solder station from CPC, cat. No. SD01116 with various coated tips available for about £1 each. Don`t even think about using lead free solder, besides being very difficult to flow you need special cleaning equipment for the tips. I solder quite a lot of u/c`s and linkages at home and you need a none corrosive flux (I use Templers Telux) every time on steel wire. I think the confusion about silver solder is that on some types 2% silver is added to lead/tin (Sn62) which lowers the melting point slightly and has specialist applications (like soldering gold plated connectors). Quote Link to comment Share on other sites More sharing options...
John Cooper 1 Posted February 23, 2015 Share Posted February 23, 2015 Good joints require 3 things:-cleanliness- clean then clean & clean again! Heat & plenty of it (I use a 6oz. solid copper iron) Tin everything before attempting to join. Job done! Never had a failed joint in 60 years. Quote Link to comment Share on other sites More sharing options...
