Electric Set Up for Ballerina
The concept that an electric motor has a fixed "design speed" & will always try & achieve it & work as hard as necessary to do so is one that people unfamiliar with electric motors can get their heads around I find....thumbs up
A more detailed explanation does get confusing & I find that fellow modellers I talk to tend to glaze over right at the point I mention "back emf".......wink 2
Posted by kc on 01/12/2015 13:36:49:
Do you really need 150 watt per pound for this type of model? There is a lot of wing area. I would expect it to fly well on 100 watt per pound.
I think it would probably fly quite sedately at about 80W/lb, I will be aiming for something around the 110w/lb with about 20 or 30w/lb capability in reserve if needed by simply up propping it,,,,,, also means that the motor/ESC are not being pushed towards their limits - I'll probably start off with an unreliable 60A esc I have for ground testing and replace it with a new ESC before flight
Oh dear Peter !
Why oh why don't folk like your means of propulsion for which your magnificent designs are meant? Now we are bombarded with incomprehensible motor code numbers/the requirement for a box full of propellors /To going flying with several different batteries (chargers etc) all for just a very few minutes of actual flying .
I''ll get mi coat & I do have a lekky Multiplex motorised glider which will virtually fly as long as I want -so there !
Grumpy grounded Myron
The experts all have their own views!
What we need to decide here is what we should advise the complete newcomers to building to use. Bearing in mind they may well buy the laser cut complete set. If they have fuselage sides pre cut then the possible options become limited ( they cannot easily move F1 ) so what motor and Lipo do we advise for novice builders? And what method of motor mounting? Maybe this type?
Myron it's because the public don't like the noise! Restrictions on power flying sites and developments in brushless motors and Lipo batteries have coincided. Electric flying is taking over. It's called progress!
As for number confusion, that's what we are clarifying here.
Great to have Myron speaking his mind though!
KC that sort of motor mount would work, but we need to find somewhere for the Lipo too and a hatch.....
And now that I am armed with the plan.....
Between F1 and the nose ring is 100mm, lots of room for a motor.... I am tempted to make a motor mounting/battery box from lite ply running from F2, through F1 and extending into the cowl... I will have to choose a motor before I know how far forwards it should extend, the motor box will also form the mounting for a cowl which will slide over the box and be a tight fit perhaps a couple of magnets on what remains of F1 for peace of mind.......
The hatch would be from F1 to F2 giving access to the open top of the battery box..... as long as the box is deep enough a decent sized battery should slide in......
So the deviations from a laser cut short kit would be:
Cut out in F1 for the Battery Box
Sides, top and bottom of the Battery Box
End cap "Firewall" for motor mount
Posted by Myron Beaumont on 01/12/2015 14:42:59:
Oh dear Peter !
The problem is, Myron, that I don't have the brains required for electric flight I can simply say .40 FS and everyone knows exactly what is needed and I know exacty what size range I can build to suit that enngine. This doesn't take any high powered brains, just good old fashioned experience..
Now you may have noticed that basically no one has asked what size engine to use. A few have asked how much bigger to make the nodel with a bigger engine. which is fair enough.
And I must add that I do fly electric. I have have a nice Great Planes Spektra built from a kit and powered with a Speed 600 motor turning an 8 X 4 folding prop and using 7 cell NmHi batteries. Not sure what size speed controller I have but it works.laugh
Posted by kc on 01/12/2015 14:48:37:
Exactly. I am planning on buying the laser cut set. This is a first build(after 3 ARTF's) and whilst I would eventually like to get to the point of just a plan and a stock of wood lets take it in baby steps.
I need to know EXACTLY what to do to differ from the plan to make an electric set up.
In answer to KC's earlier point - no you don't need 150W/lb for this model - but that's what I want! I did make that point in the post! T
he purpose of showing the calculation in detail was so that if you wanted less - say 100W/lb - you could simply follow the method through and you'd end up with your particular values.
The trouble with just saying "buy this motor and this ESC" is that it teaches people absolutely nothing! OK they can buy those things - but they don't know why they are the appropriate items. The point of the MB is help people reach a position where they can do this for themselves.
By showing how to calculate this for yourself I believe I have at least tried to improve knowledge. I'm not saying "buy the same motor as me", what I am saying is "I've told you you need 100W/lb or so minimum now here is a method for calculating what you need - I'm going to illustrate it with a value of 150W/lb (because that's what I want) you use your own values".
Simple!
BEB
Hello to all,
I'll second BEB on his reply.
I'm a total newbie myself (RC, modelling, IC, EP, EPP, ESC, Gorilla stuff, PVA, GF, CF, TMA, AUW, BRU Airport & a lot more acronyms to master ...). smile o
But if you tell people what they 'have' to do - ie. motor A, combined w/ ESC B & prop C -, obviously they 'll not be learning a lot, just 'copycatting' what as been said (ordered?). No learning phase there, I'm afraid.
Explaining W/lb, max current, KV, prop pitch & so on, seems to be the right approach in a learning curve.
One's knowledge 'll only improve if he/she understands how & why things are happening.
Since more than one year I'm daily visiting this forum as we don't have this kind of 'wealth' in the country. And some members here are really dedicated to 'help' the newcomers. Great pedagogy, thanks to them.
So, I'm buying a Wattmeter right away...
Chris
Brussels, Belgium
ps: ... the easiest way to calculate the lateral offset of your motor mount is to use the sine of the thrust angle... wink
I dare say those going the I.C route will fit a variety of engines, no different for lecky flyers, each to his/her own, by the time we start building there should be enough set ups mentioned, for us to choose one that suits our own particular style of flying. I like a bit of grunt myself but that don't mean it'll be a pylon racer, just means loops will be big and i'll be throttling back and getting longer flights.
John
Posted by john stones 1 on 30/11/2015 17:15:29:
Always a conundrum for myself choosing the motor prop combination, I have a Turnigy SK3 3548 1050kv it's a little on the powerful side wink but my thinking is prop it down on a 4c 3300mah lipo and 60 amp esc? then i'll get longer flight times and cooler running, prop will be figured out using the watt meter, I have some APC 14x7 and am guessing a little over 620w ? all guess work so far though. I have been using these SK3 for a while now and they've been very good. Feel free to chip in if my thinking's wrong.
John
My prop thinking was way out, I've been reliably informed on a 10x6e apc i'll get 153w/lb..46 amp max and 7 minutes flight time on this set up, these figures are from ecalc and it's been my experience so far, that I get better flight times than predicted without pushing the lipo's smiley
John
I do have a number of models in the general range being discussed, that is circa 54" span.
I do have information with respect to the motor, voltage and propeller combinations. What I do not have is the weight of the models, nor wing loading.
What I am not recognising at present is the power necessary for what I had anticipated in a gut feel sort of way. You are all looking for far higher power than I had sort of guessed would be necessary.
In my case I need to get the scales out and sort out my own model weights,
Perhaps the Ballerina weight is higher than I had anticipated. Although my own models are pretty much the same type of structures of both Peter and Tims. In the case of the TH, CS, the model itself weighs nothing, could this be part of the issue with the IC model. The engine the extra nose weight? At present I do not know or understand.
It seems for me there is some work to do.
Wot watt meter, excuse pun. I bought one and it arrived with three leads at one end, three leads at the other, not a connector attached to any of them!
Lesson, don't forget to order some connectors, and be prepared to solder them on. Another part of the learning curve I suppose.
Happy landings, Glyn.
I've put 5.5mm bullets on mine and then made a pair of 5.5mm bullet to XT60 adapters.
Most of my batteries are XT60 so the wattmeter sits in my box with the adapters on ready to be used (I won't lose them this way). When I need to measure my F3A stuff with bullet connecters, I just unplug the adapters.
This logic should work with any type of connecters. Just think about what you will need, then make up the leads to suit.
Glyn: Both my Wattmeters have 4 wires. A positive and negative in (from the battery) and a positive and negative out (to the esc). I can't think why yours has 3 at each end. One of mine does have a connector for a balance lead so that it can check the voltage of each cell in a LiPo pack but the other ( an original Astroflight one that cost a small fortune when I bought it) just has the 2 in and 2 out.
There is a wide variety of connectors for electric flight. I use 4mm bullet connectors but others use Deans or XT60 etc. Annoyingly my polarity of choice is opposite from the ones HK supply. I chose mine 20 years ago, almost at random and it's too much trouble to change now.
Geoff
It is perhaps worth a few words on the different types and sizes of connectors?
The aspects that concern me, and influence which ones I would consider using are:
  • Polarity protection, and how fool proof inadvertent wrong connection is.
  • How bulky the connectors are.
  • How easy are they to solder and protect.
At one time there was a brief period that many seem to have standardised on Lipos using Deans type (now never supplied on the Lipo), now C60's are pretty common, as are bullets in housings and so on.
I am just prepared to solder, every time.
