onetenor Posted February 9, 2018 Share Posted February 9, 2018 An easy way to shift a worn disc is to peel an edge then trickle a small amount of thinner behind it .The. Bau universal is ideal This softens the adhesive and allows easy removal.Remaining adhesive can if required be removed by rubbing with a cloth dampened with thinners. Quote Link to comment Share on other sites More sharing options...
Charles Smitheman Posted February 9, 2018 Share Posted February 9, 2018 Have to say thanks to you all for the heads up on this one. I snuck off work and got one yesterday. Plenty at the Gap RD Wimbledon branch. It looks very good.for the price. No more excuses now to get building. I also got the jiggly cut into the corners thingy (general purpose cutter sander?) which looks great. With a fine blade it should have model building applications too. I was thinking perhaps for removing a skew fin perhaps. Quote Link to comment Share on other sites More sharing options...
Simon Feather Posted February 9, 2018 Share Posted February 9, 2018 Here's another top tip for this device. If like me you use a Dyson vacuum cleaner, you'll find that the vacuum cleaner attachment for the sander doesn't fit... it comes with a 2 stage adaptor, but neither stage will fit either of my Dysons... This is very easily fixed, with a short offcut of 32mm plastic waste pipe, as illustrated below! I now have a very strong connection between vacuum cleaner and sander. Quote Link to comment Share on other sites More sharing options...
Geoff S Posted February 9, 2018 Share Posted February 9, 2018 Posted by i12fly on 09/02/2018 00:32:08: Well Geoff thank you for leaving one for me. I couldn't get to Ripley until 5.30.... There were just 3 left after I got one. I was tempted by the '20V' lithium battery drills at £16 but I'd forgotten to recharge my wallet before going You're welcome I did think about the detail sander but only briefly. However, Avice is off swimming right now but she threatened to go to Lidl afterwards and buy one for herself - which means I'll have one too Geoff Quote Link to comment Share on other sites More sharing options...
Erfolg Posted February 9, 2018 Share Posted February 9, 2018 The nut on my sander had more than come loose. Taking the sander apart. There was no sign of a nut, as if it was never there. That note of just 4 self tappers provide, the confidence to take it apart. It is so easy, in that the internals are so very well arranged, in a motor, and one board. I did contemplate taking it back, considering the time, etc. I decided I would first try a hex nut. I thought it was either a M5 or 6. It appeared to be neither. Whereas a 0BA brass thin nut seems perfect. The only issue is that it was slightly wider than the slot into which it is meant to be located. A few minutes with a file had a good transition/slight interference fit. Which is great, as it will not just drop out of the slot. I tried the sander, and found that it is turbine smooth. Great!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
Nigel R Posted February 9, 2018 Share Posted February 9, 2018 Brilliant - thanks for the recommendation. I've been after a small disc sander for a long while now. I had the last one in my local branch! Quote Link to comment Share on other sites More sharing options...
The Wright Stuff Posted February 9, 2018 Share Posted February 9, 2018 Does anyone have the clamp depth for fixing to the bench? How thick can the surface be and it still fits on? Quote Link to comment Share on other sites More sharing options...
Erfolg Posted February 9, 2018 Share Posted February 9, 2018 the clamp will fit In the region of 60mm, between the underside of the sander and the clamping swivelly thing on the screw. Having run the sander and sanded a peirce of balsa, it looks like overkill, other than it stops the sander being moved. Quote Link to comment Share on other sites More sharing options...
The Wright Stuff Posted February 9, 2018 Share Posted February 9, 2018 Posted by Erfolg on 09/02/2018 13:07:59: the clamp will fit In the region of 60mm, between the underside of the sander and the clamping swivelly thing on the screw. Brilliant. Thanks for that Erfolg. Quote Link to comment Share on other sites More sharing options...
Tony Harrison 2 Posted February 9, 2018 Share Posted February 9, 2018 I'd been tempted by this item anyway, but the favourable opinions here persuaded me so I bought one Wednesday night - best time to be sure of picking up the Thursday special offers, shortly before they close the night before, with everything out on display already. Haven't tried it yet, but forgive me if this has already been asked: what's the best source of 115mm sanding discs in various grades, preferably self-adhesive? Those supplied are too coarse for my purposes, and I'd like discs from 400 to 1200 grit. Also picked up a couple of Lidl's garage/workshop large hooks etc for my new project of making the garage a vastly more comfortable and well-organised workshop (half the price of similar at B&Q or on Amazon); plus a couple of their LED ceiling lights, £36 the two compared with the £50 fluorescent I had planned to get from B&Q. rgds Tony Quote Link to comment Share on other sites More sharing options...
Glyn44 Posted February 9, 2018 Share Posted February 9, 2018 I must have got a good one. The nut didn’t fall off! Works a treat. Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted February 9, 2018 Share Posted February 9, 2018 Fortunately I didn't read the instructions and I was too lazy to remove the table. Consequently I didn't lose the bolt inside and I was able to get the self adhesive disc concentric on the sander through a combination of skill and beginners luck. Quote Link to comment Share on other sites More sharing options...
Chris Whalley Posted February 9, 2018 Share Posted February 9, 2018 Got my sander this morning, what a great little machine for the price Quote Link to comment Share on other sites More sharing options...
Former Member Posted February 9, 2018 Share Posted February 9, 2018 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Geoff S Posted February 9, 2018 Share Posted February 9, 2018 Scroll saws (mechanical fret saws) were reduced to £59.99 in our local Aldi (Belper) from the £69.99 I paid for mine a few weeks earlier. I'm not too upset. I'm very happy with what mine cost. Meanwhile my wife and I made a joint trip to Lidl this afternoon and she bought a hand sander to rub down paintwork (I think it's a big big for our use building models). There were still 3 rotary sanders in stock. Geoff Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted February 10, 2018 Share Posted February 10, 2018 Managed to pick one up in my local Lidl this morning.....looks great. They had 6 left so still plenty around it seems. Now I can be sure all my formers will be nice & square & sanded to the right size... Lovely.... Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted February 10, 2018 Share Posted February 10, 2018 Hi, I have been keeping my eye on this one and as others on here have given it a good thumbs up. I decided to get one as well. Its a big improvement on my existing one which i got for free. I got the last one, and then i noticed a gent looking at me and my Sander and it was my neighbor that lives at the back of me. I guess i beat him to the last one, Oh well 1st come as they say. Steve. Edited By Stephen Jones on 10/02/2018 16:49:18 Quote Link to comment Share on other sites More sharing options...
Cliff Bastow Posted February 10, 2018 Share Posted February 10, 2018 Bought one today and already used, seems good for the money. Quote Link to comment Share on other sites More sharing options...
i12fly Posted February 10, 2018 Share Posted February 10, 2018 Mine had the loose nut so when I removed the bolt and table it dropped inside. It really was very loose. It was easy enough to remove the cover, only thing was I couldn't find the nut Thought it must have attached itself to a magnet inside the motor, so spent 20 mins trying to see it with a torch and a mirror. Couldn't see it so decided to put it all to one side until later. Doh the nut was sitting on my bench underneath the unit To avoid any risk of losing it what I suggest is stand the sander in its normal operating position Remove the hex bolt and slide off the table -do not tip the sander up after removing the bolt. Screw in a short bolt back into the nut so it cannot drop out of the retaining slot inside Only then turn the sander in its back and remove the 4 screws that hold it together Holding it all together turn the whole unit back the right way and remove the green top half You can then get to apply a bit of glue to the nut/retaining slot It really is simple to do. Quote Link to comment Share on other sites More sharing options...
The Wright Stuff Posted February 12, 2018 Share Posted February 12, 2018 I went. I bought. I hid it from the wife! Quote Link to comment Share on other sites More sharing options...
Gordon Nicol Posted February 12, 2018 Share Posted February 12, 2018 It also sharpens pencils ace Quote Link to comment Share on other sites More sharing options...
trebor Posted February 12, 2018 Share Posted February 12, 2018 Posted by The Wright Stuff on 12/02/2018 14:07:24: I went. I bought. I hid it from the wife! Top tip for a peaceful life. Make sure you don't put the box in your recycle bin unless it's cut into tiny bits so she can't tell what it was Quote Link to comment Share on other sites More sharing options...
John Robertson 3 Posted February 12, 2018 Share Posted February 12, 2018 This evening, I went. Just to see, you know? I bought. Plus a multimeter (it seemed wrong not to do so). And a pack of zip ties in a variety on sizes . . . just because. Then I went home . . . and just happened to visit my shed first. I wouldn't say I hid it from the wife as she simply wasn't around at the time. Ahem! Quote Link to comment Share on other sites More sharing options...
Glyn44 Posted February 13, 2018 Share Posted February 13, 2018 The braver ones amongst us might just be interested in Spring clamps and gorilla glue amongst other offers at Aldi this Thursday: **LINK** Quote Link to comment Share on other sites More sharing options...
DaveyP Posted February 13, 2018 Share Posted February 13, 2018 There's a better deal for Gorilla glue on ebay, I've just bought 250ml for £7.70 free postage from uk_runag. UK based in Plymouth, I have no connection with them other than buying from them.... Quote Link to comment Share on other sites More sharing options...
