Tim Kearsley Posted September 27, 2021 Share Posted September 27, 2021 Thanks Paul. It's Hobbyking film and very shiny. I'm modelling the Princess Elizabeth, so it's essentially "bare metal" with a blue nose. I've resigned myself to regarding this build as a learning exercise and acknowledging much of it is far from perfect. I would like to give it as authentic an appearance as I can though, within the limits of film covering, hence the panel line question. I'll try the gentle abrasion technique on some film on a piece of scrap balsa and see how it goes. Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted September 27, 2021 Share Posted September 27, 2021 (edited) Tim Also try some bare film with the permanent/gell markers. The film is applied with heat (hair dryer) and can be removed the same way again try this on some scrap. I have been given a crash damaged FW 190 and it was printed film covered. I used heat to succesfully remove it. Edited September 27, 2021 by Paul Johnson 4 Quote Link to comment Share on other sites More sharing options...
Tim Kearsley Posted October 3, 2021 Share Posted October 3, 2021 I'm getting towards completing this project now - at last! Those of us who are using Richard's lovely aluminium spinner, how are you painting it? I have in the back of my mind that ali is quite tricky to get a finish to adhere to properly. Is an etching primer necessary? I'm modelling the Princess Elizabeth, so mine needs to be bright blue. Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted October 3, 2021 Share Posted October 3, 2021 Etch prime isn't necessary, it is also toxic. A tin of Halfords primer works fine, a few small scuff marks adds to the weathering effect nicely. Quote Link to comment Share on other sites More sharing options...
Tim Kearsley Posted October 3, 2021 Share Posted October 3, 2021 Excellent, thanks Paul. I already have a big rattle can of Halfords grey primer. The next problem will be finding paint that matches the blue Hobbyking film at the front of the model. Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted October 3, 2021 Share Posted October 3, 2021 Take a sample to b&q and get them to colour match a sample pot of their valspare range about £3 for a pot big enough to paint the whole aircraft. ? Quote Link to comment Share on other sites More sharing options...
Tim Kearsley Posted October 3, 2021 Share Posted October 3, 2021 Good thinking. I wondered if you'd spot that.... Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted October 3, 2021 Share Posted October 3, 2021 I have used B&Q for paint matching taking matt samples to be matched. On one occasion I took some covering off a Kyosho Spitfire to get a match for the brown and green When I went to use them they were nowhere near the colour of the sample. I put it down to the sheen on the film covering confusing the sampler. So be careful with trying to match gloss colours. Quote Link to comment Share on other sites More sharing options...
Tim Kearsley Posted October 7, 2021 Share Posted October 7, 2021 I'm nearing completion of the P51 now. I'm about to attach the rudder and the two slots in the fin for the top two mylar hinges are straightforward but the bottom hinge point, in the back of the fuselage, is much harder material of course. How have you chaps cut this bottom slot? Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted October 8, 2021 Share Posted October 8, 2021 Yes Tim, Not having a bottom slot will cause all sorts of constipat.......er consternation. Quote Link to comment Share on other sites More sharing options...
Trevor Posted October 8, 2021 Share Posted October 8, 2021 Tim, you may find it easier to cut the slot if you drill a very fine hole at each end first. It also reduces the risk of splitting the wood. 2 Quote Link to comment Share on other sites More sharing options...
Tim Kearsley Posted October 8, 2021 Share Posted October 8, 2021 Thanks Trevor, good tip. And as for you Paul, well, what can one say?! Quote Link to comment Share on other sites More sharing options...
Tim Kearsley Posted October 13, 2021 Share Posted October 13, 2021 Hmm, I see I've managed to build in another variation compared to the rest of you chaps! I've just installed the control linkages for the tail feathers. On the plan that comes with the kit it mentions the "elevator pushrod on the starboard side". So that's what I did, with the rudder control horn on the port side. Now, looking at the completed models from other builders I seem to be opposite to everyone else! Does it actually matter, as the surfaces move OK and there aren't any nasty angles in the snakes? Incidentally, a colleague at my club who has also built the WR Mustang took it up for its maiden yesterday. There were a couple of minor issues but the model looked beautiful in the air. I can't wait to get mine airborne! Quote Link to comment Share on other sites More sharing options...
RICHARD WILLS Posted October 13, 2021 Author Share Posted October 13, 2021 Hi Tim . Your deviation wont make any difference . There is always a bit of poetic licence . Richard Quote Link to comment Share on other sites More sharing options...
Tim Kearsley Posted October 13, 2021 Share Posted October 13, 2021 Ah, you can't beat a bit of poetry. My building went awry, But it'll still look good in the sky No need to get in a flap Just because your building's cr... not as good as it might be. 1 1 Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted October 13, 2021 Share Posted October 13, 2021 You must ang on to those words of wisdom from Richard. Quote Link to comment Share on other sites More sharing options...
Jonathan S Posted October 14, 2021 Share Posted October 14, 2021 Not sure mine will have poetic license, more careless or ignorant license. ? Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted October 14, 2021 Share Posted October 14, 2021 Everyone's first build is a thing of beauty, each subsequent build becomes easier and neater, but, there's nothing like your first. Quote Link to comment Share on other sites More sharing options...
alan p Posted October 14, 2021 Share Posted October 14, 2021 The most important opinion is of your own? Quote Link to comment Share on other sites More sharing options...
Don Fry Posted October 14, 2021 Share Posted October 14, 2021 Tim, never admit anything. Then you can invent total barf explanations, and delivered with a good liars nonchalant delivery, get away with it. 1 Quote Link to comment Share on other sites More sharing options...
Tim Kearsley Posted October 14, 2021 Share Posted October 14, 2021 1 hour ago, Don Fry said: Tim, never admit anything. Then you can invent total barf explanations, and delivered with a good liars nonchalant delivery, get away with it. Good advice Don. It sounds a bit like you speak with the voice of experience? Quote Link to comment Share on other sites More sharing options...
Don Fry Posted October 14, 2021 Share Posted October 14, 2021 38 minutes ago, Tim Kearsley said: Good advice Don. It sounds a bit like you speak with the voice of experience? Believe it. I had a float plane, fluffed up box of a thing. Russian markings. It’s transport box had the fake type. Little known Russian inter war lakes transport, think Beaver, I said. A bit before Google admitted, but I was never porkie challenged. And it did quite a few years trundling about. Quote Link to comment Share on other sites More sharing options...
Tim Kearsley Posted October 24, 2021 Share Posted October 24, 2021 Well, a few things left to do, mostly cosmetic and rectifying minor cock-ups, but my P51B is 99% there. I've had some exhaust stacks 3D-printed by a clubmate and they are still to go on. The CG is a bit forward at around 90mm back so I'll have to see how it flies. I've not attempted any weathering or detailing yet - it could be tricky on a film-covered model. I just need to reduce the awful glossiness now...... 4 Quote Link to comment Share on other sites More sharing options...
Andy Gates Posted October 24, 2021 Share Posted October 24, 2021 Tim, that is beautiful. Very well done, I hope she flies as well as she looks. Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted October 24, 2021 Share Posted October 24, 2021 Looking good Tim, don't forget the sun glasses ?. Quote Link to comment Share on other sites More sharing options...
