RAF's Finest Biplane? Hawker Fury MkI
Just thought I'd post about this mini metal shear and bending brake I purchased last year before Christmas. I believe its made by or sold by Micro Mark tools, see the You Tube demo: https://www.youtube.com/watch?v=BHpl0kQKgOM
My purchase was from Canadian online tool supplier Busy Bee Tools under their Craftex tool name: https://www.busybeetools.com/
I used it to bend up brass landing gear components for the Super Cub currently on the bench and it worked very well. Capacity is 8" wide stock, and shears/bends .0625", or 1/16" brass aluminum with ease. I got tired of trying to cut and bend accurately with hand shears, vises and pliers so decided to pull my finger out and get something better suited for the task.
Edited By Rem Fodder on 06/07/2018 14:08:02
Edited By Rem Fodder on 06/07/2018 14:11:49
The owners manual states that material up to 1/16" can be sheared, including mild steel. So far I have sheared .010", 1/32" and 1/16" brass and aluminum with ease. I think if one were to try and shear steel, the tool would need to be bolted down to a bench, otherwise for the softer metals simply holding it by hand or with a C clamp on the bench works just fine. Bending material is a breeze too, the tool comes with a full length 8" die and a number of smaller dies of different width for finesse work. As with a lot of hobby grade tools, this one required a little bit of tweaking centered around the shear and brake stops. It was necessary to clean up the rough edges for smooth adjustment as fresh out of the box the stops would bind as I tried to adjust them in and out along the guides for cut widths. A bit of polishing with emery cloth and the odd kiss with a file had everything working as it should.
The photos are of the functional sprung bungee landing gear I managed to come up with for my Cub project. Having the shear/brake was very helpful. An earlier attempt to try this with hand tools was an exercise in wasted effort and material. I simply could not get the repeatability or accuracy required. It was also very helpful making up some .010" brass shims for a center fire rifle scope mount.
Neil
Posted by Danny Fenton on 07/07/2018 11:08:24:
Now go and oil that vice/clamp! wink 2
Danny
Edited By Danny Fenton on 07/07/2018 11:09:18
You've a sharp eye Danny on my old vice. I made that during the third year of my millwrights apprenticeship, 31 years ago. Its been through a lot and done a ton of work for me over the years, unfortunately humidity in the basement of the house since I left the trade has not been kind. Still, no excuse to let it rust.
Good luck trying to track the tool down.
Neil
Edited By Rem Fodder on 08/07/2018 03:16:09
Hi Fenton Furies!
I have recently completed a 1/6th scale Mick Reeves Spitfire which I have electrified, just one wing and very few bendy bits I'm afraid! Would very much like to join the Fury gang if that is acceptable Danny?
I've been trying some litho forming using annealed thin material for the cowl blisters - re your article in RCME. Works well. I have also built a half wing of the Fury to test my limited skills with silver Oratex. Main thing I learned is to monitor the iron temperature carefully, the polyester fabric has a relatively high percentage shrinkage. Also the need to think through the best wing rib support during construction due to the underside camber.
With my best wishes,
Stuart R.
Hi Guys
I've finalised the artwork for the 1mm brass bits. It is 300mmx150, and will be 1mm thick. There are' loads of spares, because the sheet is the minimum size that the etchers can produce. Also there are bits for the windscreen frames, and anything else I can think off. Each sheet will cost £25 including post and packaging to europe. So far I've got the following list Richard Mallam, David Avery, Tony Bennet, Martyn K, Martian, Klippy, Colin Leighfield, McG6969, Martin Fayne, Jose LG, and Danny Fenton
If anyone else wants a set , then let me know ASAP; Below is the artwork
ernie
ETCH
