Ron Gray Posted May 31, 2023 Author Share Posted May 31, 2023 I didn't bother to take any in progress shots but I stuck the sheeting on then glassed it and have given it a quick (hand brushed 🥴) coat of paint which I've forced dried with the hot air gun to give it some chance of fuel proofing for Friday!! It will be resprayed later! Final job gluing the rad on, hopefully I will get to run the engine tomorrow before packing it all away, if not then it's a suck it and see for Friday. 3 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted June 3, 2023 Author Share Posted June 3, 2023 Unfortunately I didn't get to fly it! I went to start it and found that it was only running on one cylinder which I eventually realised was due to a fuel pipe having come off when I fitted the cowl. I>t was later on in the day so I didn't bother removing everything to fix it, there is always another day, and zip ties! Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted June 23, 2023 Author Share Posted June 23, 2023 A bit of an update, having fixed the fuel pipe I took the Hurri out for a flight the week before last. Engine started and ran better than it ever had done (thanks for the repair works Jon) and is a lot quieter too, much they same as the 160 in-line in the Mustang. The only snag was that it was climbing a bit under power, actually more than a bit, it required a lot of forward elevator stick as I had run out of trim. This made low fast passes a bit difficult. I changed the trim options so that I could dial in a lot more and was then able to fly it somewhat better. After getting it back home I decided to add more down thrust but this also meant that to avoid having a front cowl ring that didn't match the spinner I had to angle the cowl down, which meant that the rear edge of etc cowl no longer sits against the formed recess in the fuse. Rather than do anything about it at the time, I decided to wait to see if the added down thrust was OK. So on to today. First flight up showed that the down thrust added was working fine so, apart from nearly running out of fuel, that flight was a great success. Next flight up and I realised just how quick the Hurri is a WOT, a lot faster than it was before the engine rebuild. So a fast, low, fly by was called and as it flew past there was a quite loud 'bang' and a lot more noise from the engine. I throttled back but had to complete 75% of the circuit without being able to open the throttle by much as the noise was a little bit worrying. Upon landing I found a missing spinner (sheared spinner bolt) and half of one prop blade missing. Obviously the prop hit the spinner and the noise was the vibration so it was lucky that I chose to keep the throttle low. The good news was that the spinner was spotted landing at the far end of the airfield but on the strip so it was recovered! I have to say that the Hurri is now on par with the Mustang for both sound and presence in the air! Roll on the next scale day at Old Warden. 3 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted June 23, 2023 Author Share Posted June 23, 2023 Now that's what I call a break Remains of the prop bolt 1 Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted June 23, 2023 Share Posted June 23, 2023 Lucky to get away with that Ron, Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted June 23, 2023 Author Share Posted June 23, 2023 Very lucky Eric, nursing it round the circuit to land was a bum clenching time. The landing wasn't pretty either but nothing more got broken. Quote Link to comment Share on other sites More sharing options...
Jon H Posted June 23, 2023 Share Posted June 23, 2023 i have had 2 spinner bolt failures now. one broke my prop, one didnt. i now consider these bolts to have a service life and replace them annually. 2 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted June 24, 2023 Author Share Posted June 24, 2023 As stated above, putting in the extra downthrust meant that the cowl position has now left a gap between it and the fuse join. So I filled that with P38 Making sure to cut the join line with a knife just as it was going off Just need to let it really harden before sanding / smoothing 1 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted July 4, 2023 Author Share Posted July 4, 2023 A bit of sanding and some paint 5 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted July 30, 2023 Author Share Posted July 30, 2023 On 22/09/2022 at 09:44, Ron Gray said: Hmmm, just weighed the Hurri, 8Kg 😲 The later ESM ones (post 2016) were a lot lighter. Not sure where I got that figure from, just weighed it and it comes out at 9.7Kg! (wing 3.8Kg, fuse 5.9Kg), I did think it was a bit of a porker. Just goes to show how good the Laser 200 inline is! Quote Link to comment Share on other sites More sharing options...
Jon H Posted July 30, 2023 Share Posted July 30, 2023 39 minutes ago, Ron Gray said: Not sure where I got that figure from, just weighed it and it comes out at 9.7Kg! (wing 3.8Kg, fuse 5.9Kg), I did think it was a bit of a porker. Just goes to show how good the Laser 200 inline is! Its funny how some models can handle being a little obese. My DB Hurricane is 23-24lbs and i was worried about the 240 being enough. As it is, i think a 200 would be fine for it as it just seems to float around. The DB Spit is the same way. Clearly the YT Hurricane also cares not for its weight. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted July 30, 2023 Author Share Posted July 30, 2023 Explains why it tends to run on when landing, but good for scale looks though! Quote Link to comment Share on other sites More sharing options...
Chris Walby Posted July 30, 2023 Share Posted July 30, 2023 10 hours ago, Ron Gray said: Explains why it tends to run on when landing, but good for scale looks though! Runs on because? Just due to its mass As its heavy, it has a higher landing speed, but then why doe it "float" Something else? Just interested as to the reason, cheers Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted July 30, 2023 Author Share Posted July 30, 2023 It's not the floating it's the amount of runway it uses up from touch down to stopping. I think that this is due to its mass, not its airspeed as it doesn't appear to be coming in that fast, the fully deployed flaps do slow it down quite a bit, but I do rather like it as, when I get it right (!!!) it really does look scale with its tail up for quite a while. However I now need to really plan my landings a lot more as it can use up most of the tarmac and run off onto the nice short grass so maybe an 'all on grass' landing is called for. I will be trying to perfect this when I get back to flying in the )hopefully) not too distant future. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 27, 2023 Author Share Posted August 27, 2023 (edited) A rare video of my Hurricane, taken by flying buddy Andrew on his mobile this morning before the heavens opened! Grass runway landing. Edited August 27, 2023 by Ron Gray 5 Quote Link to comment Share on other sites More sharing options...
Adrian Smith 1 Posted August 27, 2023 Share Posted August 27, 2023 Cracking model and flight, Ron. Really enjoyed it. 👍 1 Quote Link to comment Share on other sites More sharing options...
Kevin Fairgrieve Posted August 28, 2023 Share Posted August 28, 2023 A couple of stills of @Ron GrayHurricane. It looks like I left my focus finger at home (they are not my best shots).😆 5 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 28, 2023 Author Share Posted August 28, 2023 I don’t know Kev, they look good to me, especially the first one. Must paint the spinner though! Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted August 28, 2023 Share Posted August 28, 2023 Do I see a lot of down thrust ?. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 28, 2023 Author Share Posted August 28, 2023 (edited) It has got some Paul but not excessive. If you look back up this thread you’ll see that I had to increase it a bit. Edited August 28, 2023 by Ron Gray Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted August 28, 2023 Share Posted August 28, 2023 1 hour ago, Kevin Fairgrieve said: A couple of stills of @Ron GrayHurricane. It looks like I left my focus finger at home (they are not my best shots).😆 May be Ron's finger is not 100% yet Kev. 1 Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted August 28, 2023 Share Posted August 28, 2023 Beautiful Hurri that........ although my mate Eric would complain at the lack of undercarriage doors.......... he's a bit of a pedant! Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 28, 2023 Author Share Posted August 28, 2023 I know GG and I really must get around to fitting them. The only problem I found with them on my earlier model was that, due to their angle when down, they don't half pull the nose down so required an up elevator mix. I have thought about some way of making them rotate as the wheels go up / down but haven't thought it through in enough detail yet! Other things I need to fit are the aerial and the rear view mirror! Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted August 28, 2023 Share Posted August 28, 2023 I have made a few twist and turn retracts using nose leg retracts, it's a case of finding the right spot to fix the ball links, here 90°, Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 28, 2023 Author Share Posted August 28, 2023 I’ve done exactly the same Paul, based on the HK twist n turn retracts. But what I am thinking of doing is making the doors rotate around a fixed UC leg! Quote Link to comment Share on other sites More sharing options...
