cymaz Posted February 4 Author Share Posted February 4 .....Don’t panic. Gentle heating over the frame makes the fabric shrink. Adding coats of 50% shrinking dope will close the pores of the weave and make the fabric begin to shrink. A little more gentle heating will keep the shrink going. Quote Link to comment Share on other sites More sharing options...
cymaz Posted February 4 Author Share Posted February 4 (edited) I know to some I’ve missed some steps and methods with covering, it’s just a skip over for the refurb. The next few days the flaps and ailerons with be installed with Robert 1/8” pin hinges and push rods installed. Edited February 4 by cymaz Quote Link to comment Share on other sites More sharing options...
Don Fry Posted February 4 Share Posted February 4 Nylon, that’s a blast from the past. But the tip re heat. Thank you. 1 Quote Link to comment Share on other sites More sharing options...
cymaz Posted February 4 Author Share Posted February 4 Got the nylon from here https://www.profabrics.co.uk/ Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted February 5 Share Posted February 5 Hope your painter uses a little plasticiser in the paint. 2k is good but can crack on flexible substrates unless plasticiser is used especially in vold weather. Just ouf of interest could you weigh the parts before and after painting ? Quote Link to comment Share on other sites More sharing options...
cymaz Posted February 5 Author Share Posted February 5 Good idea about weighing 👍 Quote Link to comment Share on other sites More sharing options...
cymaz Posted February 7 Author Share Posted February 7 Inch by inch... The flap hinges are reinforced with brass tubes. IIRC 3.5mm ID. When using epoxy to fit in the pin hinges ..... don’t forget to work and heat the Vaseline into the knuckles Quote Link to comment Share on other sites More sharing options...
Peter Jenkins Posted February 7 Share Posted February 7 I think the last time I used doped nylon was in 1968! I did have a control line combat wing called the Early Bird and that was my first nylon covering and that must have been in 1965. It added a great deal of strength to the EB and that was pretty strong to begin with. Quote Link to comment Share on other sites More sharing options...
Steve Jones 15 Posted February 7 Share Posted February 7 Wil you be needing a new cowl ? I can supply a new one if you do. Regards Steve. Quote Link to comment Share on other sites More sharing options...
cymaz Posted February 8 Author Share Posted February 8 6 hours ago, Steve Jones 15 said: Wil you be needing a new cowl ? I can supply a new one if you do. Regards Steve. Kind offer, Steve, thanks. I’ve never had a cowl on it as it has a DLE 30 up front. I’ve got an unused one somewhere. Quote Link to comment Share on other sites More sharing options...
cymaz Posted February 10 Author Share Posted February 10 Finally got everything finished and ready for paint. I’ve got about 80’ of flap and no issues, is that sufficient? Quote Link to comment Share on other sites More sharing options...
cymaz Posted February 18 Author Share Posted February 18 (edited) The wings and fuselage is still with Anthony being painted. I thought I’d make some of my fizzy can wheel hubs. Get a can! I find that Diet Coke ones are the best as the aluminum is very thin and pliable. Cut around the base at the paint line, don’t cut straight through as you nip off the base ! I made 50mm and 65mm ply formers. These are simple holes from scrap ply. I’m sure someone would be able to make perfectly round ones with a laser cutter. These are good enough Place the former over the can base , dome side up and carefully beat the hell out of it, using a flat hard surface Trim up and flatten with a hand wheel. I use an old wallpaper seamer. Fix to the hub with small screws Edited February 18 by cymaz 2 Quote Link to comment Share on other sites More sharing options...
cymaz Posted February 18 Author Share Posted February 18 I forgot to mention, before you cut out the ply hole, put marks 120* apart on the outside. This makes it easy to place the screws evenly around the hub 1 Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted February 18 Share Posted February 18 On 10/02/2024 at 16:24, cymaz said: Finally got everything finished and ready for paint. I’ve got about 80’ of flap and no issues, is that sufficient? The "blister" style servo covers look nice, where did you get those from? Quote Link to comment Share on other sites More sharing options...
cymaz Posted February 18 Author Share Posted February 18 Shaun, I’ve had then in a draw for years. I’ve no idea where they came from. They’re on a site somewhere! Quote Link to comment Share on other sites More sharing options...
FlyinFlynn Posted February 19 Share Posted February 19 21 hours ago, Shaun Walsh said: The "blister" style servo covers look nice, where did you get those from? Make your own? https://www.barcs.co.uk/forums/topic/3682-diy-blister-clear-servo-covers/ Quote Link to comment Share on other sites More sharing options...
Basil Posted February 19 Share Posted February 19 4 hours ago, FlyinFlynn said: Make your own? https://www.barcs.co.uk/forums/topic/3682-diy-blister-clear-servo-covers/ Anyway we can get rid of the over printed 'Photo bucket' Stuff . Really mucks up the picture. Not just yours, anywhere its shown distorts the picture Bas Quote Link to comment Share on other sites More sharing options...
FlyinFlynn Posted February 20 Share Posted February 20 20 hours ago, Basil said: Anyway we can get rid of the over printed 'Photo bucket' Stuff . Really mucks up the picture. Not just yours, anywhere its shown distorts the picture Bas I only printed the link, I didn't have anything to do with the content creation! Quote Link to comment Share on other sites More sharing options...
Andy Stephenson Posted February 20 Share Posted February 20 Photobucket made a change a while ago that meant if you didn't have an account, you weren't eligible to see the pictures in focus. Quote Link to comment Share on other sites More sharing options...
cymaz Posted February 20 Author Share Posted February 20 Anthony has made a start. I’m not going to ask what goes on in his lounge😳 Quote Link to comment Share on other sites More sharing options...
cymaz Posted February 28 Author Share Posted February 28 I’ve finished the wheel hubs. The marvellous people at Stickers Planet have worked their magic again. The decal is 20mm x 24mm, probably the smallest they go Quote Link to comment Share on other sites More sharing options...
Nigel R Posted February 29 Share Posted February 29 the hubs are a brilliant touch, like it Quote Link to comment Share on other sites More sharing options...
cymaz Posted March 10 Author Share Posted March 10 (edited) Just collected it from paint not 30 mins ago.....a few decals to order. There is a small amount of flake in the clear coat, just enough to sparkle in the sun 😎 Edited March 10 by cymaz 1 Quote Link to comment Share on other sites More sharing options...
cymaz Posted March 10 Author Share Posted March 10 More pictures of Anthony and work in progress Quote Link to comment Share on other sites More sharing options...
Outrunner Posted March 10 Share Posted March 10 (edited) I've never seen a cow in a workshop before 😄 Edited March 10 by Outrunner Typo 1 Quote Link to comment Share on other sites More sharing options...
