Basil Posted February 29, 2024 Share Posted February 29, 2024 Hello, I assume the std servo is an analogue type !!!!!!. Whats the difference, ( Not to technical). Can you use a 'Digital' servo in an ordinary set up? Bas Quote Link to comment Share on other sites More sharing options...
John Rickett 102 Posted February 29, 2024 Share Posted February 29, 2024 Digital and analogue servos can be interchanged. For most applications an analogue servo will be all you'll need unless you want to fly zippy models. Digital servos are generally faster and have greater holding power - this can be good and bad, if you stall a digital servo it will draw a very high current trying to reach its commanded position and may well burn out. A programmable servo will be digital, programmable can be useful in some applications if you want servo reversing, end point adjustment, servo slow etc and for whatever reason can't achieve it in the transmitter. For most scale models, gliders and sports models, an analogue servo will perform just fine. Quote Link to comment Share on other sites More sharing options...
toto Posted February 29, 2024 Share Posted February 29, 2024 Hi Bas, My understanding is that standard servos are analogue. Digital servos can be used in " standard " set ups as you say ... but come into their own if using telemetry etc. ..... my usual qualification applies ..... I'm relatively inexperienc3d myself so wait for the more technically correct answer by others. I believe that they can be a little more accurate, programmable and quicker but not ,aybe as much as to be appreciated by novice fliers. I started off buying digital servos for allmy models but have also used analogue servos ( Hitec ) in my Domino trainer. Some of the older hands at one of my clubs told me I was wasting money on digital servos for the type of model and level of flying that I was doing ....... I'm sure more qualified answers will follow. Cheers Toto Quote Link to comment Share on other sites More sharing options...
Nigel R Posted February 29, 2024 Share Posted February 29, 2024 1 hour ago, Basil said: Whats the difference To the average sport flyer, next to no detectable difference, I would say. That said. In like for like cases, a digital version of an standard analogue servo will more accurately hold its position when force is applied and (usually) has higher torque - but you pay for this in terms of extra power being consumed by the servo. If you already have some, just use them. Fancy servos that can be individually reversed or have their speed adjusted or whatever, are always digital. And expensive. 42 minutes ago, toto said: but come into their own if using telemetry etc Why are they better if you use telemetry? Or indeed how do they affect telemetry? Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 29, 2024 Share Posted February 29, 2024 I find this often had discussion confusing. A servos a link in the chain, as is the gap between hinge lines, slop free linkages, building light/straight, having a reliable engine that throttles well, it's part of the package. If you stall an anologue servo it's bad news, extra current used is easily managed, they're Red Herrings, old wives tales. Can I tell if I upgrade a link in the chain ? Of course I can, and I very much think most of you could. Do you need them ? Entirely up to you to decide that one. Negatives ? They cost more. 1 Quote Link to comment Share on other sites More sharing options...
Nigel R Posted February 29, 2024 Share Posted February 29, 2024 Some cost about the same. Savox standards spring to mind. Difference is, max current draw is higher, accuracy under load is better, can you tell? A small bet you couldn't, in a "proper" scientific test, double blind, etc etc. Humans are pretty good at convincing ourselves we've made excellent choices . "Digital' can be used as a pretty good sales pitch. Much better than "those old analogue things". Etc. Quote Link to comment Share on other sites More sharing options...
toto Posted February 29, 2024 Share Posted February 29, 2024 Hi Nigel, I was under the impression that digital servos can feedback info to the transmitter via telemetry. I've maybe picked that up wrong. Toto Quote Link to comment Share on other sites More sharing options...
Philip Lewis 3 Posted February 29, 2024 Share Posted February 29, 2024 Some SBUS servo's can feedback telemetry and being SBUS they are all digital, most digital servo's however aren't SBUS and have no telemetry capability I don't think that even all SBUS servo's have telemetry capability just some that do. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 29, 2024 Share Posted February 29, 2024 Yep, and some digis in smaller sizes are very reasonable prices, science and modelling moved on massively over the years, as we're all witness to. Would I rubbish analogue servos, no, I still use them and digis. Quote Link to comment Share on other sites More sharing options...
toto Posted February 29, 2024 Share Posted February 29, 2024 Thanks for clarifying that Philip. I just read for myself that the digital signal used is between the servo and receiver only ..... not the transmitter ..... sorry for the red herring Bas. Toto Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted February 29, 2024 Share Posted February 29, 2024 On a 2.4 system or 35mhz PCM system the servo positions are sent to receiver as a digital stream. The receiver decodes this and each channel then outputs a pulse width signal, the servo position being determined by the length of the pulse, typically 900 to 2100 micro seconds. This is updated ever 22 millisecond for analogue servos and can be more frequently for digital servos, ever 10 milliseconds. If you select the higher rate on analogue servos it can cause them to overheat with potential burnout. Note SBUS servos if fed direct from the SBUS port receiver a digital stream and you have to program the channel into the servo. BTW if you use a gyro or flight controller then beware they may update the servos at a faster rate which could cause analogue servos to burn out. Quote Link to comment Share on other sites More sharing options...
Basil Posted March 1, 2024 Author Share Posted March 1, 2024 Thank you gentlemen for your feedback. I do not use Digital types, just plain old analogue for the sort of model I build . I raised the subject mainly to find out the differences for future reference. I dont see the sense in buying a much more expensive product just for the fun of it. Horses for courses !!!! Many thanks Bas 1 Quote Link to comment Share on other sites More sharing options...
Nigel R Posted March 1, 2024 Share Posted March 1, 2024 14 hours ago, toto said: I was under the impression that digital servos can feedback info to the transmitter via telemetry. Well... I guess probably the more complete / correct picture is - "it depends." (apologies for slightly 'devil's advocate' question earlier BTW) Standard size digital sport servos like Bas is talking about, I'll wager not, they'll be on a standard RX/servo PWM interface. "Digitals" in this context have no extra smarts over and above analogue servos, only the position feedback/control method is digital. Fancier expensive (and certainly digital) servos can provide health status via a digital bus. Not - AFAIK - widely implemented (yet), probably manufacturer specific (e.g. Futaba SBUS... Futaba servos, Futaba RX, Futaba TX), certainly top drawer product line features (after all, why would any manufacturer put this latest stuff on their basic product lines). What use is that telemetry? Temperature, position, current draw, probably you can determine and set limits and alarms. Proving out the kit install chain during first flights, health warning limits for future flights. Large models? Yes. Very fast stuff? Yes. Operating at public demos? Sure, why not. But. Investment in time setting it up, and you probably need to know how to interpret the data. Maybe the servos know enough to do sensible default warnings, I couldn't say. Sport flyer, club size model? I'm not seeing it yet myself. It's another thing to set up and monitor. Sometimes there is a place for that stuff, sometimes you want quick and simple. Those of us grabbing a 3S foamie from the boot? Probably not... Quote Link to comment Share on other sites More sharing options...
Nigel R Posted March 1, 2024 Share Posted March 1, 2024 (edited) 4 minutes ago, Basil said: Thank you gentlemen for your feedback. I do not use Digital types, just plain old analogue for the sort of model I build . I raised the subject mainly to find out the differences for future reference. I dont see the sense in buying a much more expensive product just for the fun of it. Horses for courses !!!! Many thanks Bas For reference, the "standard" Savox servo is a digital: https://servoshop.co.uk/index.php?pid=SAVSG0351PLUS&area=Servo and not particularly expensive. Futaba standard servo now also digital: https://servoshop.co.uk/index.php?pid=FUT051026711&area=Servo End of day, if you want a standard servo, buy a standard servo, don't worry about the buzzword. Edited March 1, 2024 by Nigel R 2 Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted March 1, 2024 Share Posted March 1, 2024 (edited) Isn't there some consideration of frame rate on Spekky radios that means you can't mix and match......? I could well be misremembering; and if not, it could well apply to other brands. Edited March 1, 2024 by GrumpyGnome Quote Link to comment Share on other sites More sharing options...
John Lee Posted March 1, 2024 Share Posted March 1, 2024 You can certainly mix and match analogue & digital servos. But if you do so you cannot take advantage of the digital servos ability to accept a higher frame rate, the whole system must operate to the lowest common denominator otherwise you may burn out the analogue servos. That means in practice for mixed digital/analogue servos the frame rate must be left at the default 22ms for Spektrum (or 17ms for Jeti, those are the 2 brands I am familiar with) rather than a faster rate being selected under the 'Frame rate' options in the menu. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted March 1, 2024 Share Posted March 1, 2024 Some analogue servos do not like the 11ms frame rate, do not like it one little bit, magic smoke kind of not like. 1 Quote Link to comment Share on other sites More sharing options...
DocPrinter Posted April 29, 2024 Share Posted April 29, 2024 (edited) I have seen frame rates for digital servos goes of 333Hz, which is more like 9ms. Certinally relevant to RC cars like 1/12th carpet racers. Easily hitting 50kph, 13.9m/s, or 0.28m of travel between servo updates on a 50Hz PWM signal. The track lane is not much more than 1.5m wide, and so reliably hitting apexes on hairpins and chicanes warrents faster responce from the servo. I'm yet to fly my plane (NW UK weather and family birthdays conspiring to keep me off the field!) but struggle to see why this would help fly an docile by design plane flown line of sight at more than 100m away. Raise speed, or bring it close and the argument improves. That said if you have any sort of electronic stabaliser, flight controller, or advanced failsafe on board then these could certinally make use of faster response & speed servos. "Digital" servos may also grant many other benefits other than responce & speed. For exxmple; accuracy, repeatability, and potentially reliability. Starting with the latter brushless and hall sensors over brushed dc and potentiometer position sensing strengthens two weak points of traditional analogue servos. Repeatability is one I hadn't given much thought too but it the ExpressLRS world there was a real fuss about temperature issues effecting the Tx and Rx circuitry. Anyone ever tested if the analogue servo goes to the same posions up high on a cold day vs your ~18 to 20C workshop? Sure, if your setup process is consistent, not an issue but changing servos even within make/model could add unnecessary unknowns to your re-maidens. Anyway, as with all things you pay your money and take your choices. A set of brushless, hall sensor, programmable servos would cost more than many to most aerobatic plane kits ready to fly. Technology is slowly creaping down the price chain, but too slowly in my mind. PWM is archaic, and only recently being superceded by canbus (simpler wiring, improved reliability), even so only really at the highest price points. I don't know much about sbus, but generally steer clear of proprietary formats where possible. Edited April 29, 2024 by DocPrinter Adding 50Hz clarigication to original example. Quote Link to comment Share on other sites More sharing options...
Andrew McKelvey 1 Posted May 11, 2024 Share Posted May 11, 2024 The only difference between an analogue servo and a digital one is the input amplifier that reads the signal from the receiver which is analogue, it either converts the train of pulses to a digital signal based on length of time the signal is high or it doesn’t, it then compares this signal to what the feedback loop is saying, the position of the servo horn and drives it one way or the other to match what your tranny stick is saying you want it to be. The servo hardware is likely to be of better quality in a digital servo than a cheap analogue servo because they can charge more and yes there are benefits but the digital bit is the amplifier A/D converter call it what you want. The rest is advertising hype but I do use digital servos in my bigger models that require more torque to move a bigger flying surface Quote Link to comment Share on other sites More sharing options...
Christopher Wolfe Posted May 12, 2024 Share Posted May 12, 2024 14 hours ago, Andrew McKelvey 1 said: The only difference between an analogue servo and a digital one is the input amplifier that reads the signal from the receiver which is analogue, it either converts the train of pulses to a digital signal based on length of time the signal is high or it doesn’t, it then compares this signal to what the feedback loop is saying, the position of the servo horn and drives it one way or the other to match what your tranny stick is saying you want it to be. The servo hardware is likely to be of better quality in a digital servo than a cheap analogue servo because they can charge more and yes there are benefits but the digital bit is the amplifier A/D converter call it what you want. The rest is advertising hype but I do use digital servos in my bigger models that require more torque to move a bigger flying surface Andrew, it is quite refreshing to read about something that I also suspect is 99% hype. What does a 'Digital' servo mean? Just that it relies on a digital decoder instead of a linear potentiometer to give feedback to it's position. Nothing to do with power! * Chris * Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted May 12, 2024 Share Posted May 12, 2024 "The servo hardware is likely to be of better quality in a digital servo than a cheap analogue servo because they can charge more...." The cynic in me says there is no substance to this proposition.................... along with all the hype, there is the opportunity to make more profit by using mostly the same hardware that rolls off Chinese factory lines in their millions. Anyone quoting "You get what you pay for" will be rebutted within another well known saying 🙂 Quote Link to comment Share on other sites More sharing options...
Nigel R Posted May 13, 2024 Share Posted May 13, 2024 19 hours ago, Christopher Wolfe said: Andrew, it is quite refreshing to read about something that I also suspect is 99% hype. What does a 'Digital' servo mean? Just that it relies on a digital decoder instead of a linear potentiometer to give feedback to it's position. Nothing to do with power! * Chris * They still use a linear pot for position feedback. Quote Link to comment Share on other sites More sharing options...
FlyinFlynn Posted May 13, 2024 Share Posted May 13, 2024 20 hours ago, Christopher Wolfe said: Nothing to do with power! Well, that depends on your interpretation of 'power'. An analogue servo uses an analogue amplifier to discern the required position of the servo arm (via the feedback pot), this means as it closes in on the desired position it's output voltage falls (and thus the 'power' delivered to the motor) until it reaches the correct position. A digital servo on the other hand determines a digital value (ie between 0 and 1024 for example) of the position it requires the servo to be in and compares that to the digital value it determines from the feedback pot, it these are not the same it applies 'full power' to the motor until they are in balance. It is not quite as simple as that but that is the basic logic. This means the digital servo should have more torque driving the servo when it is moving. Does torque equal power? Depends on who you talk to! Quote Link to comment Share on other sites More sharing options...
Nigel R Posted May 13, 2024 Share Posted May 13, 2024 Nope, torque never equals power... different units, ask any GCSE/O level physics student... Power is the rate at which "work" is done, i.e. time / speed is important. "Work" is force times distance; and force is linearly related to rotational torque (e.g. typical hobby servo). No speed or time is involved. More torque will move a given load quicker, this much is true. So power and torque are (indirectly) related, but, not the same thing. The big difference with digitals vs analogue is that they are (typically) capable of applying full torque very quickly In theory it could be possible to have an analogue amp with the same kind of performance as a digital amp, but you'd need to start adding very expensive and very accurate components to a typical servo feedback amp, and in the end it is much simpler, easier, and more repeatable to do all the required sums inside a digital widget. Short version - digital feedback amp beats analogue for performance/cost. Quote Link to comment Share on other sites More sharing options...
FlyinFlynn Posted May 14, 2024 Share Posted May 14, 2024 I understand the technical definitions you describe but I rather think the question that was asked and the manner in which it was written cared not for the technical definitions rather it was asked as a colloquial term. ie. power as in 'is it stronger?' Like most things in modern life, the later technology provides some benefits over the older technology, but these usually come with disadvantages too, in this case, the increased 'power' requirements.( power as in current.. nothing to do with the rate at which work is done) Quote Link to comment Share on other sites More sharing options...
