Uno Wot
Basil
Hello fellow modlers. I have had a Uno wot kit for some while I have a set of instructions but dont seem to have a drawing. I am assuming that it came with a set of plans!!!!. Can anyone say if plans exist and if so could I have a copy please. Thanks in anticipation.
Bas
The Uno Wot never had a plan - there are just a couple of sketches in the instruction booklet.
Agree 100% with Richard - loved my Uno Wot and always preferred it to my Wot 4. Mine made a perfect trainer on an OS.25SF and was particularly flattering for a beginner's basic aerobatics with it's lovely outside loops. Still have the airframe and one day will do an electric conversion.
I used to have one, my second r/c model. Mine was powered by an Irvine 20 car racing engine modified with an aircraft crankshaft. It flew it extremely well and was a good introduction to aerobatics. It remains one of three models which I wish I hadn't sold. The other two were a Flair Hooligan, Flair's answer to the WOT 4, and a vintage Radio Queen.
I am glad I'm not the only one to champion Chris's design .
For us old hands , Ive found I can get even more entertainment from it by cutting the ailerons to operate the outer 1/3 and then use the inner aileron on a full flap setting on switch . Its a quick mod as you can just leave the outer ailerons on two servos and put two little torque rods in to drive the flaps .
This beautiful little model really does fly like a bird (much more so then the rather slabby Wot 4) , but with the flaps down it will loop almost in its own length and land in a breeze like a helicopter . It can be trainer and intermediate sports model and STOL all in one . Way better than all these Tundra's we see popping up .
Mine started out as 4 stroke powered but I prefer it now on 4s and 12x6 . 3s variants can have equal performance with the right motor prop .
Its a shame that of the Foss fleet it seems over looked . I guess its because the UNO wot doesnt appear in ARTF form .
  • Like 2
That's an interesting mod Richard. My 30 year + old Uno Wot ailerons are on a single S148 via torque rods, so such a mod would mean a slit in the underside veneer to sink a couple of mini servos further out on the wing. Something to bear in mind when I eventually get around to putting model BC#01 back in action. I'd probably replace the wing bands and dowels with wing bolts at the same time.
Hi all you experts !!!!!. The kit as supplied has the two versions of the Uno wot, 3 and 4 channeIs it. The 3 channel has a pronounced dihedral of 3" each side whilst the 4 channel seems to have no dihedral. In order to maintain some of the stability of the 3chan' version is it possible to maintain the same dihedral with the 4 channnel version. I am aware that I will loose some /all of the advanced flying characteristics.
Many thanks Bas
I built one decades ago, my second r/c model and the first with ailerons. If I remember correctly, if you butt the wings up to one another, the joint is not exactly vertical and you have to lift one wing to ensure that the wings meet at the top. Of course they may have changed things in the intervening years. I think that a UnoWot with a flat wing would not pose any problems for an experienced pilot nor for a beginner on a buddy box.
David, thanks for your prompt reply. The construction seems to have progressed. The wings are venered foam now, requiring a 'Seating' angle to be adjusted according to the required dihedral.
David I appear to have run off half cocked.The 4 channell version has a 1/2 - 1 1/2 " dihedral, that's more in line with what I had in mind, especially as its specified by Mr Foss. It was that I did not want to use a flat wing.
So.... my apologise to everyone for my big ' Not reading the notes correctly' moment !!!!! hope possible replies read this note.
John , I would agree the designer new what he was doing, I did not read it as I should have, thanks.
Bas
Edited by Basil
  • Like 2
On 15/08/2024 at 09:49, RICHARD WILLS said:
Yes Brian , I replaced the bands with two number plate bolts and a dowel at the front . As an experiment I made a second fuselage out of foam board which worked just as well . (sorry Chris ) .
You need the number plate bolts to carry the long CAA number these days.
  • Haha 3
Number plate bolts used as wing bolts needing the CAA Number...?????? First I've heard of that one,, They are just simple plastic/nylon bolts or am I missing something here??
Edited by GaryW
  • Haha 1
Bas
Glad you worked it out Basil. You're going to love the UnoWot once you've built it, as I said above. I'll be watching with interest. I have an SC 32 with a Weston Power Pipe and an Irvine 39 both doing nothing so you never know...😏
