J D 8 - Moderator Posted September 15, 2024 Share Posted September 15, 2024 I went flying at the club strip on Friday early to make use of calm conditions for some vintage model flying, then cutting grass. In the afternoon as wind picked up brought out my Citabria pro, Pretty 55"span chunky flyer that does not mind a bit of wind. Power is only an OS LA40 so take off can be quite long, however once in the air it is fine with engine flat out most of the time. I had been flying a while doing usual stuff when was on a slow decent on the downwind leg ready to turn in for a low pass up the strip when suddenly model flicked to the right and headed in a spiral down.[ one turn] Instinct took over I straightened up but there was not the height to recover so shut the throttle. As luck would have it crashed nose well down into a patch of knee high tussock grass which absorbed the impact, anywhere else, hard surface or trees beyond I recon there would not be an issue to address just bits to pick up. As we walked to the crash site I thought I had been caught out going too slow in a gusting cross wind but when at the model first thing that caught my eye was both ailerons were [radio still on] drooped one about 20 degrees other 15. Apart from a cracked cowl there was no other damage even prop is fine. First thought was heck stripped gears in ail servos or splines gone but no, double checked and good As can bee seen in pic Tx stick is central but both ailerons are drooped. Any comments as to what the issue may be. John. Quote Link to comment Share on other sites More sharing options...
kc Posted September 15, 2024 Share Posted September 15, 2024 My first thought was if it's just one central servo then this had failed in some way. Or the aileron horn had come loose or servo has come loose. But if it's two servos then I would look into the Tx memory to see if some mix had been set and inadvertantly been switched in whilst recovering model. 1 Quote Link to comment Share on other sites More sharing options...
RottenRow Posted September 15, 2024 Share Posted September 15, 2024 Do both ailerons still work normally in both directions, but now with that offset? Are the ailerons operated by a single servo, or two separate ones? And if the latter, are they on a Y-lead or on two separate channels? Brian. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted September 15, 2024 Share Posted September 15, 2024 Nose down impact tends towards somethings moved, can clevices be moved under pressure, are the splines on the servo horns o.k, are horns still at 90 degrees ? Quote Link to comment Share on other sites More sharing options...
MattyB Posted September 15, 2024 Share Posted September 15, 2024 (edited) 48 minutes ago, J D 8 - Moderator said: I went flying at the club strip on Friday early to make use of calm conditions for some vintage model flying, then cutting grass. In the afternoon as wind picked up brought out my Citabria pro, Pretty 55"span chunky flyer that does not mind a bit of wind. Power is only an OS LA40 so take off can be quite long, however once in the air it is fine with engine flat out most of the time. I had been flying a while doing usual stuff when was on a slow decent on the downwind leg ready to turn in for a low pass up the strip when suddenly model flicked to the right and headed in a spiral down.[ one turn] Instinct took over I straightened up but there was not the height to recover so shut the throttle. As luck would have it crashed nose well down into a patch of knee high tussock grass which absorbed the impact, anywhere else, hard surface or trees beyond I recon there would not be an issue to address just bits to pick up. As we walked to the crash site I thought I had been caught out going too slow in a gusting cross wind but when at the model first thing that caught my eye was both ailerons were [radio still on] drooped one about 20 degrees other 15. Apart from a cracked cowl there was no other damage even prop is fine. First thought was heck stripped gears in ail servos or splines gone but no, double checked and good As can bee seen in pic Tx stick is central but both ailerons are drooped. Any comments as to what the issue may be. John. Maybe you had a flapeton mix setup and switched it in by accident? Is it reproducible now on the ground? . Have you gone through all the mixers in your Tx setup? And have you range checked the system since the incident? Edited September 15, 2024 by MattyB Quote Link to comment Share on other sites More sharing options...
MattyB Posted September 15, 2024 Share Posted September 15, 2024 Also check the fail safe springs by switching off the radio and seeing where the controls move to. Do the ailerons drop in that situation? Quote Link to comment Share on other sites More sharing options...
J D 8 - Moderator Posted September 15, 2024 Author Share Posted September 15, 2024 The ailerons are operated via two in wing servos short rod to control surface on separate channels. They operate as normal but now have offset [ this could have triggered the loss of control of model perhaps] Rx is Futaba R2006. The only programs operating in this model are the dual aileron and some CAR, rudder and elevator are as should be. No duel rates or expo being set. John S, Horns, splines servo gears are good double checked. MattyB, Flaperon is inhibited. Not done range check since incident but situation still the same TX next to model. The only thing that moves when failsafe operated is the throttle shutting as set to do so, The drooped ailerons remain in drooped position and do not move neither do rudder or elevator. Quote Link to comment Share on other sites More sharing options...
J D 8 - Moderator Posted September 15, 2024 Author Share Posted September 15, 2024 Just been trying TX with 3 other aircraft that have similar two ail servo set up, all normal. Quote Link to comment Share on other sites More sharing options...
Phil Green Posted September 15, 2024 Share Posted September 15, 2024 Put the radio aside for now, check the aileron servos individually, feed them 1500uS from a tester and my bet is that the arm will not be central, maybe skipped spline or jumped gear. 1 Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted September 15, 2024 Share Posted September 15, 2024 Somethings moved to give that droop, you took servo cover off and inspected ? Quote Link to comment Share on other sites More sharing options...
kc Posted September 15, 2024 Share Posted September 15, 2024 (edited) If both are drooped then with 2 separate servos then it must be in the Tx memory as long as the hinges and both TE hinge spars have not moved ( aileron looks a bit low on the part nearest camera compared to inner section) I suppose it's possible both servo mounts have loosened if they are fitted to the same spar. Edited September 15, 2024 by kc Quote Link to comment Share on other sites More sharing options...
J D 8 - Moderator Posted September 15, 2024 Author Share Posted September 15, 2024 JS, Yes have removed servo covers, Servos are firmly fixed to covers. It is odd that both are affected, the impact with the tussock grass did not even break the prop. PG, Both servo arms are central with control surface set to line up with wing [done by hand] I am a bit old school that way with mechanical set up of controls. As soon as radio is on both servo arms and therefor ailerons move to droop position. PG, No issue with ail alignment just the pic. Thinking this is most likely a radio issue, thinking of the flight that during it I felt model was rather sensitive in the roll and trim not right, could it be that issue was already developing? Controls were fine during preflight check. 1 Quote Link to comment Share on other sites More sharing options...
kc Posted September 15, 2024 Share Posted September 15, 2024 With Futaba which does not have ' Model Match' it's posible to fly with the wrong model memory - so that's a thing to check......... Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted September 15, 2024 Share Posted September 15, 2024 So alls square until radios switched on, you had a look flapperon screen/switch, not done owt daft ? Quote Link to comment Share on other sites More sharing options...
J D 8 - Moderator Posted September 15, 2024 Author Share Posted September 15, 2024 Kc, not that one, right at the time and right since. JS, Flaperon INH not activated for this model. Giving it up for now TX needs charging anyway. Oh and RX batt tested still 89%. 1 Quote Link to comment Share on other sites More sharing options...
MattyB Posted September 15, 2024 Share Posted September 15, 2024 (edited) 44 minutes ago, kc said: With Futaba which does not have ' Model Match' it's posible to fly with the wrong model memory - so that's a thing to check......... Highly unlikely imo given he got so far into the flight before experiencing the issue. Personally for such a simple model I would just set it up again from scratch in a clean model memory as that willmau be e simpler than trying to find a setup gremlin in the Tx. Alternatively, have you d the servo Subtrin values in whatever menu covers that? Edited September 15, 2024 by MattyB Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted September 15, 2024 Share Posted September 15, 2024 If you flew other models same day with no issues, would be looking at changing RX and see what it says. Quote Link to comment Share on other sites More sharing options...
J D 8 - Moderator Posted September 15, 2024 Author Share Posted September 15, 2024 Hi Matty, Checked sub trims all at zero, Model was set up mechanical way. Last thing I did was clear model memory and reset, had to reverse ail and elevator but that was all. CAR still off. still the same. John, Only flew my Veron Cardinal which has no ailerons but rudder operated from Ail stick no issues. Have tested TX with other twin ail servo planes today all fine. Next thing will be to swap out the RX. 1 Quote Link to comment Share on other sites More sharing options...
Richard Harris Posted September 15, 2024 Share Posted September 15, 2024 I've had this happen with an 8FG, had to keep retrimming between flights on all of my models in its memory. Ailerons would be off centre each time the transmitter was turned on by quite a bit and throw in one direction slowly reduced. Seemed to be pointing at the roll pot. Have since bought another transmitter but been given a second hand 8 to transfer the parts to hopefully get some more life out of it. Quote Link to comment Share on other sites More sharing options...
MattyB Posted September 15, 2024 Share Posted September 15, 2024 (edited) 17 minutes ago, Richard Harris said: I've had this happen with an 8FG, had to keep retrimming between flights on all of my models in its memory. Ailerons would be off centre each time the transmitter was turned on by quite a bit and throw in one direction slowly reduced. Seemed to be pointing at the roll pot. Have since bought another transmitter but been given a second hand 8 to transfer the parts to hopefully get some more life out of it. Wow, and I thought mechanical build quality and bullet proof reliability were supposed to be the given with Futaba that justified the higher price? I’ve never had any issue similar to that on >10 years of flying the “Challenger brands” from China! Edited September 15, 2024 by MattyB Quote Link to comment Share on other sites More sharing options...
J D 8 - Moderator Posted September 15, 2024 Author Share Posted September 15, 2024 Hi Richard, I have had my T8j a good number of years and this is the first issue with it. Only this model affected so far, tests with others have shown no problems but may well try a flight long test moving controls while on the ground with my Limbo which has similar set up given what you say. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted September 15, 2024 Share Posted September 15, 2024 Have you activated a flight mode from a long forgotten experiment? Quote Link to comment Share on other sites More sharing options...
i12fly Posted September 15, 2024 Share Posted September 15, 2024 Don't think this helps but..... I have a twin aileron model with New Power servos, model stood for some time (2 yr?). On powering up one servo drooped about 20 degrees as if the centring was haywire. Servo worked up and down from this 'new' centre. George at 4max suggested it was the pot at fault, something he'd heard of on New Power after a lay up. I didn't feel like risking a cure so I scrapped the NP servos... Quote Link to comment Share on other sites More sharing options...
MattyB Posted September 16, 2024 Share Posted September 16, 2024 10 hours ago, i12fly said: Don't think this helps but..... I have a twin aileron model with New Power servos, model stood for some time (2 yr?). On powering up one servo drooped about 20 degrees as if the centring was haywire. Servo worked up and down from this 'new' centre. George at 4max suggested it was the pot at fault, something he'd heard of on New Power after a lay up. I didn't feel like risking a cure so I scrapped the NP servos... Yes, servo pot failurew is absolutely a possibility, though the chances of that ha[ppening in two different servos at precisely the same time (within mins of each other having passed a pre-flight check would seem very low. Quote Link to comment Share on other sites More sharing options...
Dickw Posted September 16, 2024 Share Posted September 16, 2024 How a bout swapping the connectors around at the receiver (e.g swap one aileron and rudder, and one aileron and elevator) to see if the offset follows the servos or stays with the Rx port. That should confirm if a radio or a servo problem. Dick 2 Quote Link to comment Share on other sites More sharing options...
