David Davis Posted July 20, 2016 Share Posted July 20, 2016 I cannot remember how many models I have built since that first Keil Kraft Ajax in 1959 but it must be at least thirty. One day I will make up a list from memory. Suffice it to say that I consider myself to be an experienced builder. I am currently building a Roy Scott BE2e which is a scale biplane with a 2 metre wingspan. Simultaneously I am building a little Veron Cardinal which is a vintage high-wing monoplane of less than half that size. For Christmas I treated myself to a Chris Foss WOT 4 XL ARTF and fitted an Enya 120 FS.I maidened it last month and found that it flew beautifully like all of Chris Foss's designs. I have assembled ARTFs before and this one went together easily. About a month ago I ceased to be the only Englishman in my club, here in the middle of France, when chap called Daniel joined. Daniel had a couple of Flair Scouts in his van and an ARTF WOTs WOT. As well as being a good builder, it was obvious that he was a better pilot than I am, so last Saturday I asked him whether he'd like to fly my XL. I took off, flew a circuit, handed him the transmitter and when I was sure that he'd got the hang of the thing, I walked off to my van to fetch my sunglasses. When I next looked up I could see that something was flapping about at the back of the model and that Daniel was struggling to control it. However he got it down to a safe landing and that's when we discovered that THE ENTIRE FIN HAD BROKEN AWAY!! . The base of the fin was still attached to the fuselage but it had sheered off neatly where it met the top of the fuselage. I doubt that I could have landed the model in the same situation. It was obvious that despite all of my experience I must have made a beginner's mistake and cut into the balsa of the fin when removing the covering to provide a wood-to-wood glueing surface. This had obviously weakened the structure to such a degree that the fin worked loose then broke away from the rudder which then flapped about in the slipstream as Daniel brought it in to land. Perhaps I should have used pinned hinges on this model. At the very least I should have secured the cyano hinges with pins or cocktail sticks. Not that this would have prevented fin from breaking away. Lesson learned. Now what does a WOT 4 fin look like? . The picture below shows the model ready for repair. The base of the fin which was still glued to the model at the time of the incident, has been removed. Quote Link to comment Share on other sites More sharing options...
Kim Taylor Posted July 20, 2016 Share Posted July 20, 2016 Hi David I don't think it is, but on the other hand - could this be linked to the well documented hiccup on this kit whereby the fin isn't long enough to touch the tail plane to which it should be glued. I'm in the process of building (assembling?) one of these converted to electric and I had to glue an additional 2 or 3 mm on the bottom of the fin so that it touched the tail plane when assembled. Just a thought Kim Quote Link to comment Share on other sites More sharing options...
Former Member Posted July 20, 2016 Share Posted July 20, 2016 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Mark a Posted July 20, 2016 Share Posted July 20, 2016 While I was doing a pre flight check on my XL the other week I noticed some slight movement of the fin even though I had added the extra wood to the base during construction. Just goes to show a pre flight is very important probably saved my XL from a smashing end. Quote Link to comment Share on other sites More sharing options...
ChrisB Posted July 20, 2016 Share Posted July 20, 2016 I had to extend the fin fitting on mine. Glad I did. Quote Link to comment Share on other sites More sharing options...
cymaz Posted July 20, 2016 Share Posted July 20, 2016 I will put some tail bracing top and bottom when I build mine later in the year. Thanks for the heads up on the problem. Quote Link to comment Share on other sites More sharing options...
David Davis Posted July 21, 2016 Author Share Posted July 21, 2016 Posted by Percy Verance on 20/07/2016 21:02:21: I omitted to mention in my earlier post that probably the best way to remove the film covering from the bottom bit of the fin prior to gluing is to (just) burn through the covering with a soldering iron, then peel it off. David, what's the heavy looking metal bracket thingy which looks like it's bolted to the motor mount arms? When I moved to France last year I planned to rent a house for twelve months to see whether I liked living here. Kitchens in rented houses in France are often very basic and many tenants supply and fit their own kitchen units, taking them with them when they move. The kitchen in my house came with a sink unit with three cupboards underneath. I bought the old cooker from the previous tenant for 50 € but I did not have anywhere to store pots and pans so I bought three galvanised industrial metal shelving units from Bricomarche for about 65€ each. Each shelf is capable of holding 75kgs (165lbs) when reinforced with the L shaped brackets supplied with the shelving units. As my pots and pans do not weigh anything like 75kgs I did not bother using them, but one of them came in handy as a remote glow plug bracket! I was able to tune the engine much more easily than I would have had the cowl been in place! It's my intention to fit the cowl eventually and to bolt the remote to the side. I've been actively house hunting recently and have seen a beauty but it's right at the top of my budget. ( Isn't that always the case!) It already has a superb fitted kitchen but the shelving units will come in handy in the workshop. Thanks for the tip about burning off the covering Percy. I have an Acrowot ARTF to assemble and I'll use a soldering iron on that. Quote Link to comment Share on other sites More sharing options...
Rich too Posted July 21, 2016 Share Posted July 21, 2016 Posted by Percy Verance on 20/07/2016 21:02:21: I omitted to mention in my earlier post that probably the best way to remove the film covering from the bottom bit of the fin prior to gluing is to (just) burn through the covering with a soldering iron, then peel it off. David, what's the heavy looking metal bracket thingy which looks like it's bolted to the motor mount arms? Cutting the film is something I have never liked doing - thanks for the tip Quote Link to comment Share on other sites More sharing options...
John Olsen 1 Posted July 21, 2016 Share Posted July 21, 2016 I've had the fin fall off on a Great Planes 40 size Stik. The root cause is that the bottom edge of the fin that goes into the fuselage has the grain running fore and aft, so that the balsa is being stressed across grain. The bits of vertical grain on the leading and training edge don't engage significantly with the slot in the fuselage, so it is very weak...but not obviously so unless you are looking at one with all the covering stripped off. They really need some reinforcement in this area, which I have done using bits of kebab stick for dowels. Other than that weakness, they are a good plane and fly well. John Quote Link to comment Share on other sites More sharing options...
David Davis Posted July 21, 2016 Author Share Posted July 21, 2016 So having lost the fin I set about building a replacement. I measured the height of the rudder, added the depth of the fuselage and cut a suitable length to make up the rear part of the fin out of 4"x1/4" balsa sheet. The notch at the corner will match the extreme rear of the fuselage. The existing covering film will be cut away. I then cut a diagonal based on the TLAR principle, "That Looks About Right!" and from the off-cut made up the front part of the new fin. I decided to make the top of the fin a little wider than I remember the original to have been in order to give the top hinge some extra support. I could have used the triangle from the off-cut as the front part of the fin but it would have looked a bit rum so I cut a larger triangle using the smaller one as a sort of guide. I then sanded the edges flush and glued them together over the Cardinal plan referred to above. Note the very small triangular filling piece at the bottom. With a bit of final cutting and sanding it'll probably be alright. Please ignore the specious pencil marks, spatial awareness has never been my strong suit. The fin will be a little larger than the original and will be epoxied to the top of the tailplane and to the top of the fuselage, front and rear as well as to the fin-slot. The whole exercise has reminded me of the enlarged fins that were fitted to RE8 trainers in the First World War to make the aircraft more stable. These were cobbled together, er.. sorry, these were "engineered" out of whatever was available and I doubt if many were identical. Edited By David Davis on 21/07/2016 06:58:54 Quote Link to comment Share on other sites More sharing options...
cymaz Posted July 21, 2016 Share Posted July 21, 2016 Job done Quote Link to comment Share on other sites More sharing options...
David Davis Posted July 21, 2016 Author Share Posted July 21, 2016 I may take up your suggestion of tail bracing too Cymaz. Quote Link to comment Share on other sites More sharing options...
Shaunie Posted July 21, 2016 Share Posted July 21, 2016 What about a triangular fillet between the top deck of the fuselage and the fin? I always feel that there is a stress raiser right where your fin broke and a fillet helps to spread the load a bit. Shaunie.. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted July 21, 2016 Share Posted July 21, 2016 The fin on my Marauder (Sept 16 RCM&E) is virtually butt glued to the tailplane with the smallest of fairing blocks. I have two 1/4" dowels set into the fin and these go through the tailplane and into a 1/2" sheet tailplane platform. For film, I have two ways of doing it. I mark where the film must end and cover up to that line. I allow it to go 1/32" intothe joint. Method 2. I pul masking tape down on the balsa. Apply the film with a slight overlap onto the masking tape.Cut the film over the taped area and then pull the tape off before finally ironing the edge down Quote Link to comment Share on other sites More sharing options...
Manish Chandrayan Posted July 21, 2016 Share Posted July 21, 2016 Most kits from yesteryears did have those fillets at tailplane and fin junction, but slowly the practice seems to have been discontinued. Fillets (nicely faired in) do the job very well. An old soldering iron for film removal from the ARF's is always better than doing it with a blade. The iron can also help in opening up servo cutouts and other tasks. Smaller holes are best dealt with a heated piano wire piece. This not only cuts the film without damaging the balsa underneath but also seals the film edges. Wire bracing is also a good trick and adds tremendeous rigidity to the entire unit. While using screws to secure the anchors for bracing, use of a metal tube of sufficient length let in the wood surface ensures that the screws when tightened do not crush the wood Bottom line is most of us do commit errors that we should have not. Good to see the model survive. Testimony to the design and flying skills of the pilot on the sticks at that time Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted July 21, 2016 Share Posted July 21, 2016 Posted by Manish Chandrayan on 21/07/2016 10:18:59: Wire bracing is also a good trick and adds tremendeous rigidity to the entire unit. While using screws to secure the anchors for bracing, use of a metal tube of sufficient length let in the wood surface ensures that the screws when tightened do not crush the wood I insert a short stub of 1/4" dowel into the T/P or fin for the bolts. Also use 8BA solder tags to attach the wires. Struts made from K&S 1/4" sreamlined brass tube work very weell for tailplane bracinf. Quote Link to comment Share on other sites More sharing options...
PatMc Posted July 21, 2016 Share Posted July 21, 2016 I just cut the film using a sharp scalpel, peel it away from the area to be glued & use pva as the adhesive. If I don't think the design uses enough support between tailplane, fin &/or fuselage I modify the joint. Where possible I fix tail surfaces using some form of screw or screw & peg system rather than gluing them permanently in place. Quote Link to comment Share on other sites More sharing options...
Peter Christy Posted July 21, 2016 Share Posted July 21, 2016 I must put my hand up and confess to a stupid error I made only a couple of weeks back, involving a WOT4E-Foamie. I'd bought it as a test hack for checking out new or repaired radio gear, assembled it as per instructions. On checking the CofG, I found it to be quite a way aft of where the instructions said. I added about 50gm of lead to the nose to get it right, and then headed to the field. To my surprise, the model was way out of trim, constantly trying to dive sharply into the deck. And whilst frantically fumbling for the elevator trim - yes - I managed to turn the TX off!!! On most transmitters, this wouldn't have been a problem. I immediately realised what I had done, and switched it back on again! Unfortunately, this was a computer Tx, and it took some seconds to re-boot! Worse, I had programmed a "throttle cut" switch, and the Tx would only boot if the switch was in the "cut" position - which of course it wasn't because I was flying at the time! The poor old Wot4 spun into the crops, sustaining quite severe damage to the fuselage, though everything else survived OK. I've now replaced the fuselage, but in the process discovered that there is apparently an error in the kit instructions. The CofG should be 80mm back from the LE, not 70! I discovered this warning on the website where I got the new fuz. The repaired model balanced spot on the correct position without the need for any lead up front, and flew straight off the board. So anyone building a Wot4E-Foamie, watch out as the printed instructions indicate the wrong CofG! But that still doesn't excuse my "dumb thumb" moment. And another word of advice: Whilst a throttle cut switch is a good safety idea on an electric model, it should NOT be set so that the Tx will not boot unless it is activated! My check list now goes: Tx ON, throttle cut SET, and only then power up model. Lesson learned - and after 50 years of RC flying! -- Pete Quote Link to comment Share on other sites More sharing options...
Manish Chandrayan Posted July 21, 2016 Share Posted July 21, 2016 K&S tube ends squashed, flattened and drilled appropriately at the ends and suitable size carbon rods epoxied in to other ends is another variation for rigid and light bracing Quote Link to comment Share on other sites More sharing options...
bert baker Posted July 21, 2016 Share Posted July 21, 2016 Me too, should have known better. Having decided to get out a Hanger Queen, I checked it over and fueled it up ran the engine and all seemed ok. As it has been a while since I last used it I thought I would run a tank through it on the ground first. After a short while the engine cut, and a load of fuel ran out of the fuz when I tipped it up. Having removed the tank found the bung had come loose. more like shrunk been a least 7 years doing nothing in the shed. Tightened it up and refitted tank, ran the engine same result engine quit. Removed tank and checked the clunk line all ok, refittef tank and cleaned out carb, same result, Removed tank again,found the so called brass pipes had corroded and spit right where they go into the bung. Fitted new brass pipes and all is ok. Bert Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted July 21, 2016 Share Posted July 21, 2016 Peter Christy. I wrote off my Minnow totally when trying to adjust the elevator trim on my Spektrum Tx. I have now made a hinged cover which is bolted to the neck strap loop.Can't do that again!! Just show that we can have luck too. My Minnow crashed about 300 yards away on a recently havested field. When checking the werckage the next day I found that my satellite receiver was missing. The following day I went back to the field and started searching. I only had a vague idea within a couple of hundred yards where the crash happened. I had tramped the area for over an hour but didn't even see a scap of balsa (WE had cleaned up pretty well.) As I started back I was looking at the ground as I like looking for fossils and archaeoloical bits. I saw a stone and thought "That looks interesting" and I bent down. There was my postage stamp sized satellite Rx, I tell you, someone was walking with me that day!!! Quote Link to comment Share on other sites More sharing options...
David Davis Posted July 21, 2016 Author Share Posted July 21, 2016 I can't quite match that one Peter but I was at our flying field a few weeks ago with the club's treasurer Fabrice who was flying a drone, alright a quad-coptor. I heard an exasperated Gallic expression and then realised that he'd planted it into a field of standing wheat. He had a rough idea of where it had gone but half an hour's searching by both of us came up with nothing. Then something touched my leg. It was the drone! Half a yard to the left or right and I would have missed it. As for the XL's fin, I don't have enough triangular stock to hand but I've got some 1/4 x3/4 inch TE stock which I will press into service. That will increase the glueing area where the fin meets the top of the fuselage. I may also brace the fin with control-line or closed loop cable. I see I've done something similar on my Senior Telemaster. Maybe I'll copy the same idea. Quote Link to comment Share on other sites More sharing options...
cymaz Posted July 21, 2016 Share Posted July 21, 2016 Posted by David Davis on 21/07/2016 07:00:10: I may take up your suggestion of tail bracing too Cymaz. Don't forget to do the underneath as well Quote Link to comment Share on other sites More sharing options...
Peter Christy Posted July 21, 2016 Share Posted July 21, 2016 Re: the elevator trim /switch off scenario - My Ace MicroPro has the trims on the opposite sticks eg: the elevator trim is where you would expect to find the throttle trim, and the aileron trim is where you would expect to find the rudder trim. This makes stretching across the front of the Tx totally unnecessary. It also has an auto-trim function, which re-centres the sticks to wherever you are holding them at the touch of a button! Thinking about it, I believe the Taranis has the trims separately addressable. I wonder if its possible to program it as per the MicroPro? My homemade transmitters (with mechanical trims) always used to have the trims for throttle and elevator on the outside edge of the stick rather than the inside. Can't understand why other manufacturers don't go this route..... -- Pete Quote Link to comment Share on other sites More sharing options...
