Neil Orangepeel Posted October 27, 2017 Share Posted October 27, 2017 I'm sure there are a thousand "which is the best fuel" questions - so please don't throw rotten fruit I have a new SC 46 engine for my trainer and I am wondering which of these (easy for me to obtain) fuels I should, or shouldn't be using? Or does It not really matter? 1. Duraglo 2. Model Technics Irvine 3. Model Technics TechPower Thanks in advance for your advice. Neil Quote Link to comment Share on other sites More sharing options...
Jon H Posted October 27, 2017 Share Posted October 27, 2017 Techpower 5 without a doubt. Duraglo is awful and 25 years out of date with all that castor. I have been begging Model Technics to discontinue it! The Irvine fuels are also quite messy and the techpower is a better choice. I had forgotten how messy it was until a customer brought an engine in and needed a hand setting it up. I used his fuel (contest 10) and couldnt believe the difference between it and the Laser 5 fuel we normally use. I was plastered with oil after using the C10. couldnt believe it. so yes, the techpower will be the best option. If you spot Laser 5 from model technics that would also be just fine as its almost the same as techpower and just uses a different oil. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted October 27, 2017 Share Posted October 27, 2017 "Model Technics TechPower" ...is my preference and what I am currently using. Having said that, any of those will do. I would recommend getting some local assistance to get the motor run in and set up. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted October 27, 2017 Share Posted October 27, 2017 Model Technics Formula Irvine Context 10% I use it on everything from Cox .049s up to my 52 four strokes and everything in between. Quote Link to comment Share on other sites More sharing options...
flight1 Posted October 27, 2017 Share Posted October 27, 2017 Prosynth 2000 5% and never need afterrun if run lean at last last shut down of engine, unles Its long storage time. Easy and reliable mail order and if i run short only use fuel with no caster, as with modern synthetic oils being so much better Quote Link to comment Share on other sites More sharing options...
Richard Wills 2 Posted October 27, 2017 Share Posted October 27, 2017 Optifuel 12 for me, also use formula irvine from time to time. I prefer the klotz oil based fuels, though have used techpower thats also good stuff. Seen the liner from an OS 55 that was run on a certain fuel which they will not tell you what or how much oil is in it, after 1 season from new, it was down to the brass inside with no plating left at all. Quote Link to comment Share on other sites More sharing options...
Jon H Posted October 27, 2017 Share Posted October 27, 2017 Posted by Richard Wills 2 on 27/10/2017 11:17:26: Seen the liner from an OS 55 that was run on a certain fuel which they will not tell you what or how much oil is in it, after 1 season from new, it was down to the brass inside with no plating left at all. If you dont know whats in it, dont use it. We wont warranty engines run on fuels where the contents are not known. Quote Link to comment Share on other sites More sharing options...
Former Member Posted October 27, 2017 Share Posted October 27, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Ace Posted October 27, 2017 Share Posted October 27, 2017 + 1 for Southern Modelcraft - Hi-lube 10, 15yrs + usage without any issues on both 2/4 strokes. However they don't do mail order so unless you live in Kent ! its only from shows. Quote Link to comment Share on other sites More sharing options...
flight1 Posted October 27, 2017 Share Posted October 27, 2017 ohh! dear the second had here say about a certain oil ( OS did have a problem with certain liners coatings a few years back i seem to remember) , with modern synth oils you doun't need as much oil for it to do the job and i have been using it for years and so have many others with out any issues with this fuel i believe it uses one of the fuchs oild due to it anti corosion properties , this oil is fantastic but you must not use other oils as it will not mix. see here for a oil content clue ( in german) and here for use. ( use google translate) I belive the other low oil they use is this this info should help inform ones personal opinion and we all have one Quote Link to comment Share on other sites More sharing options...
John Stainforth Posted October 27, 2017 Share Posted October 27, 2017 Another vote for Optifuels, certainly for OS and Saito engines. I generally Optimix 12 2 stroke as a compromise for both, although there is 4-stroke version with slightly higher oil content. Jon Harper recommends Techics Laser 5 for Laser engines (I think); maybe he would like to comment. Quote Link to comment Share on other sites More sharing options...
DaveyP Posted October 27, 2017 Share Posted October 27, 2017 Model Technics Irvine for me, I really don't understand why anyone is upset by a little oil deposit down the side of their model. Wipes are really cheap and I love the smell of the oil.......... If you really want clean, go dentist drill, sorry I meant electric Quote Link to comment Share on other sites More sharing options...
flight1 Posted October 27, 2017 Share Posted October 27, 2017 Posted by John Stainforth on 27/10/2017 16:25:27: Another vote for Optifuels, certainly for OS and Saito engines. I generally Optimix 12 2 stroke as a compromise for both, although there is 4-stroke version with slightly higher oil content. Jon Harper recommends Techics Laser 5 for Laser engines (I think); maybe he would like to comment. Yes I have heard that and laser 5 has 15% . Its uses ML70 which is a good oil (synthetic) and thats what I used when I used to mix my own a few years back and at 15% too Quote Link to comment Share on other sites More sharing options...
Solly Posted October 27, 2017 Share Posted October 27, 2017 There is nothing wrong with Prosynth fuel. Just because Westons will not divulge its formula is no reason to stop it's use.- you haven't a clue what the formula of your car engine oil is but that doesn't prevent you from using it. I've used their oil for all my engines for many years completely without problems, including Laser. It's a known fact that some OS engines had big problems with peeling cylinder plating some time back, regardless of what oil was used. There seems to be a clique determined to rubbish Prosynth fuel without offering any concrete proof to back up what they claim, other than to say"I don't know what's in it". I find it all rather strange. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted October 27, 2017 Share Posted October 27, 2017 Bekra 10 or Coolpower 30% nitro. Quote Link to comment Share on other sites More sharing options...
Richard Wills 2 Posted October 27, 2017 Share Posted October 27, 2017 Posted by Solly on 27/10/2017 17:47:40: you haven't a clue what the formula of your car engine oil is but that doesn't prevent you from using it. You don't need to know the formula for car engine oil. For my car, it just needs to be made to the manufacturers spec, and labelled as such, or I won't use that either. But like you said, they are our own engines and we are free to choose what they drink. If you have good results with brand x, thats great. I pick my fuel from my own experience and making my own mind taking note from other peoples experiences and the advice of a very well respected engine manufacturer in my opinion should at least be considered. Quote Link to comment Share on other sites More sharing options...
cymaz Posted October 27, 2017 Share Posted October 27, 2017 To be honest, with Weston not telling you the oil content of prosynth, when I ran up my 4 OS 40la engines on the large refurb I’ve just done, it took 20 mins to clean all of the oil off the underside of the wing. There is plenty of oil content in that fuel. Used it for years without problems...only because the club gets a bulk discount. Quote Link to comment Share on other sites More sharing options...
Cuban8 Posted October 27, 2017 Share Posted October 27, 2017 Followed Laser Jon's advice to convert to Model Technics Laser 5 brew at the beginning of the year and it's been a wise move. All my ASP fourstrokes have performed well on it and the models do remain quite a bit cleaner. I have tried a couple of gallons of Prosynth a while back and whilst the engines all ran nicely on it, I did encounter an odd problem with carburettor jets becoming blocked with a white residue if the engines hadn't been run for a couple of weeks . This occurred on all my engines ASP 52,61,120 four strokes. Engines would not start at the beginning of a flying session until the main needles had been removed and jets blown through with fresh fuel. Engines would run fine until being left again. Never seen this with any other fuel, so the reason remains a mystery.Edited By Cuban8 on 27/10/2017 18:47:31 Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted October 27, 2017 Share Posted October 27, 2017 Well I hope this has all enlightened you Neil, there's plenty good fuels about seems to be the answer. Edited By john stones 1 on 27/10/2017 18:57:53 Quote Link to comment Share on other sites More sharing options...
Stephen Smith 14 Posted October 27, 2017 Share Posted October 27, 2017 Optifuel all the and there from Yorkshire so it must be good Quote Link to comment Share on other sites More sharing options...
flight1 Posted October 27, 2017 Share Posted October 27, 2017 Posted by Tom Sharp 2 on 27/10/2017 20:43:56: Dont really matter now, Winter is almost here. No doom and gloom for me , some of the best days I have had flying are on a still winters day, admit it too few and far between, but the winter hack braves it all. Quote Link to comment Share on other sites More sharing options...
Ace Posted October 27, 2017 Share Posted October 27, 2017 Nice bright clear frosty morning - can't beat it especially when its snowed and i can dust off the skis -Arrrrrrr A drop of petrol in the glow fuel and it starts first time even on the coldest mornings. Quote Link to comment Share on other sites More sharing options...
tigerman Posted October 27, 2017 Share Posted October 27, 2017 I been using Model Technics Propower fuel ,will not use anything else Quote Link to comment Share on other sites More sharing options...
