Andy C Posted July 27, 2019 Share Posted July 27, 2019 I am slowly growing my IC fleet, and read a lot on here warning of poor and low quality switches for RXs. So, where should I buy decent ones from please? Quote Link to comment Share on other sites More sharing options...
Richard Wills 2 Posted July 27, 2019 Share Posted July 27, 2019 Futaba genuine HD switches used to be my favourite, but alas now no longer made. I am now using the Hitec HD switch which seems to be doing the job well. Quote Link to comment Share on other sites More sharing options...
Phil 9 Posted July 27, 2019 Share Posted July 27, 2019 I have been toying with the idea of buying some quality switches such as switchcraft but then you need to solder then up yourself. but it might be a good way to go to get something of a high standard Quote Link to comment Share on other sites More sharing options...
Chris Walby Posted July 28, 2019 Share Posted July 28, 2019 I have used this from 4-Max **LINK** or HK do a dual supply version, only problem is which warehouse it comes from (import tax adds a lump). Others are available but seem more expensive...until your model goes into failsafe and you collect it with a bin liner Little or no soldering required! PS - If you are running petrol or more complicated setup, George at 4-Max can give phone advice of other products in his range. Quote Link to comment Share on other sites More sharing options...
Former Member Posted July 28, 2019 Share Posted July 28, 2019 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Ultymate Posted July 28, 2019 Share Posted July 28, 2019 If you do some research there are several "failsafe" switches available ie should the switch fail it will fail in the on position, maybe more expensive but worth it Quote Link to comment Share on other sites More sharing options...
Rich too Posted July 28, 2019 Share Posted July 28, 2019 I source mine from the US, for larger models **LINK** Edited By Rich too on 28/07/2019 09:30:42 Quote Link to comment Share on other sites More sharing options...
John Lee Posted July 28, 2019 Share Posted July 28, 2019 Inwood I used the 'JR/Spektrum switch with DSC/Charge Lead Black& Silver Front', for decades when I flew IC, not cheap now but I've never had a failure, albeit I replaced them every 2/3 years as part of routine maintenance. Quote Link to comment Share on other sites More sharing options...
Cuban8 Posted July 28, 2019 Share Posted July 28, 2019 Posted by John Lee on 28/07/2019 12:25:21: Inwood I used the 'JR/Spektrum switch with DSC/Charge Lead Black& Silver Front', for decades when I flew IC, not cheap now but I've never had a failure, albeit I replaced them every 2/3 years as part of routine maintenance. Did you ever dismantle an old one that you'd changed just to see what was justifying the high price? Decent mechanical switches are becoming difficult to get hold of, thankfully I have a couple of Futaba HD's to keep me going for a while. The electronic ones worry me, both as to their quality unless you go for the very expensive types and perhaps an unnecessary complication. The cheapy switches are not to be trusted, I bought one for a couple of quid for a non modelling use and it was intermittent in use and would go O/C when a little pressure was applied to the operating lever when in the on position. Stripped it down to take a look and it was 'orrible inside. Edited By Cuban8 on 28/07/2019 13:01:05 Quote Link to comment Share on other sites More sharing options...
stu knowles Posted July 28, 2019 Share Posted July 28, 2019 I have a couple of the GT Power switches but haven't used them because, as I read it, if they were inadvertently set in the LIPO mode, then they will cut the power as the voltage falls, saving the battery and killing the model. Murphy's Law is strong and sooner or later it will happen...…. or have I got that bit wrong? Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted July 28, 2019 Share Posted July 28, 2019 Good quality switches are readily available - but not necessarily made up for model use. My larger/faster models have twin battery/switch harness set-ups to minimise the chances of a critical failure point resulting in loss of control. I'm afraid I have a (maybe unjustified) distrust of electronic "smart" solutions, preferring the simple approach to critical systems wherever possible. Quote Link to comment Share on other sites More sharing options...
Steve Balaam Posted July 28, 2019 Share Posted July 28, 2019 What about something like this: **LINK** Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted July 28, 2019 Share Posted July 28, 2019 The JR switches were probably the best available but sadly no more. Futaba are very similar but most may be copies now. Twin batteries/switches are a good idea but when using these I now fit HK Failover ones which are identical to the eye wateringly priced Powerbox offerings. No problems with these as yet. Quote Link to comment Share on other sites More sharing options...
cymaz Posted July 28, 2019 Share Posted July 28, 2019 Excellent statistics and no moving parts... **LINK** Quote Link to comment Share on other sites More sharing options...
John Lee Posted July 28, 2019 Share Posted July 28, 2019 Posted by Cuban8 on 28/07/2019 12:49:42: Posted by John Lee on 28/07/2019 12:25:21: Inwood I used the 'JR/Spektrum switch with DSC/Charge Lead Black& Silver Front', for decades when I flew IC, not cheap now but I've never had a failure, albeit I replaced them every 2/3 years as part of routine maintenance. Did you ever dismantle an old one that you'd changed just to see what was justifying the high price? I never did but the cost at the time was under a fiver & they were often on offer at the shows. I was surprised to see how expensive they have become when I looked them up for the link. Quote Link to comment Share on other sites More sharing options...
SIMON CRAGG Posted July 29, 2019 Share Posted July 29, 2019 I have been using the E-tronix Futaba switches, good price and good product. Quote Link to comment Share on other sites More sharing options...
Bruce Collinson Posted July 29, 2019 Share Posted July 29, 2019 + 1 for Cymaz. Lots at NLMFC. 3 second ones are falling out of favour. They are local to us. BTC Quote Link to comment Share on other sites More sharing options...
