Aerial positioning
Hi Guys, couple of quick questions.
On a normal twin aerial 2.4 receiver, I understand it's onlt the bare end of the aerial that does the work.
However I am using on of these
They have a sausage bit half way down. Does the same still apply?
Also I understand the aerials need to be at 90 deg to each other for best reception. Normally I have one lengthways in the fuz and the orther spanwise, but on my current project this is simply not possible.
What's the 'second best' layout?
Jeff
Bob is right. That looks like a centre-fed dipole to me, with one of the two elements "sleeving" the co-ax feeder.
Ideally the two should be at 90 degrees, but its not super-critical. Anything better than 60 degrees will usually do in practice, but the nearer 90, the better.
I usually try and get one of them vertical in the fuselage somewhere, and the other either length-wise down the fuselage or across it. This is usually possible in even quite small models.
Hope this helps!
Pete
Peter is correct. I use the FS-iA6b and I have one that I killed on the bench.
Taking off the heat shrink, it is like this
The brass can is soldered to the central wire.
It is loose over the coaxial feeder cable.
The FS-iA6 does not have the brass can part on its aerials, and is rated as 'Park Fly'.
Jeffrey,
It's properly known as a sleeve dipole and as Peter says it's all part of the aerial. The sleeve and the wire extending away from it should remain straight. If there isn't room to put the two at right angles as you describe then try putting one at 45° to the axis of the fuz and the other at the opposite 45°. this will give you 90° between them. Also try to keep anything conductive away from the active part of the aerial by at least 30mm.
A.
Posted by Dad_flyer on 13/04/2020 16:23:46:
I certainly hope not!  its soldered to the braid, the inner passes straight through.
Edited By Phil Green on 13/04/2020 16:55:21
While we're on the subject of dipoles, I noticed aftermarket dipoles on Banggood listed as replacements for some FrSky receivers which are supplied OEM with the usual stripped coax type. Would fitting dipoles in place of the more common stripped coax affect the tuning, susceptibility to swamping, direction sensitivity or any other factor either improving or worsening the performance?
Posted by Phil Green on 13/04/2020 16:53:44:
yes blush
Phil - In simple terms, what is the benefit of such a set up?
Ideally, a monopole aerial (usually 1/4 wavelength) should be mounted vertically over a ground plane (a large area of metal, relative to a wavelength). The metal ground plane acts as a reflector, so that the monopole looks like a dipole, in the same way that standing a pencil on a mirror looks like two pencils end to end.
The more usual "bare-wire" aerials use the braid as the reflector, which is not terribly efficient. The sleeve dipole is a neat way of providing a genuine dipole aerial with a minimum of problems feeding it.
However, bear in mind that even the basic, wire ended aerial is still much more efficient than the dangly bit of wire which we used on 27 / 35 MHz! And on those frequencies we were also limited to 100mW ERP transmitted output. So any of the current crop of 2.4 GHz aerials will provide much superior performance to that achieved in days of yore, when we rarely had any range issues!
Sometimes it doesn't pay to worry too much over these things! wink
Pete
Hi Guys, thanks for all the info.
Getting the impression the iA6b might be a better bet for range, yes? Have to say I have an iA6 in both my Riot and Foamie Wots Wot, neither of which is flown as a park flier, and never had an issue.
Internet reports also suggest although the iA6 is labelled as park flier, range is rarely a problem.
Back to the plot.
This is the layout I have.
Daresay I can arrange for one of the Dipoles to be vertical by cutting (yet another) hole in the cockpit floor.
The lengthwise one, not so sure.
Going forwards puts it next to the battery, back next to the servo leads.
I'm guessing the battery would be classed as conductive, but still looks the better option.
Your thoughts
Jeff
Perhaps drill a small hole through the floor of the fuselage and put one dipole pointing vertically downward. Route the other backwards along the side of the fuselage, tidying those servo leads so that they are on the other side instead. The two aerials will then be at 90 degrees in a vertical sense, not in the same horizontal plane, not potentially masked by the mass of the battery and not next to the servo leads.
I agree with leccyflyer about drilling a small hole and putting one pointing vertically downwards.
Its difficult to tell from the picture, but it looks as if the other aerial ought to be short enough to go transverse across the fuselage, between the receiver and servos.
Alternatively, again, poke one down vertically and move the one alongside the battery back so its alongside the receiver.
The whole point of having two aerials is so that if one is either screened or poorly orientated wrt the transmitter, the other will take over. In any model, this is bound to happen at some stage of the flight, so don't worry too much about it.
These systems typically have an in-the-air range of a few kilometers, so even with a relatively poor installation, you should have range beyond the limits of your ability to see it adequately!
Its always worth removing the prop and doing a ground range check with the motor running if you have any worries, but I'll be surprised if you have any problems.
Pete
@Peter C - thanks for that - I get it now! (Perhaps I should have asked Phil for the slightly more complicated version )
In Jeffrey's installation pictured above, I'd be inclined to turn the rx around and have both aerials projecting at the extreme rear of the hatch, each bisecting the angle between TE and fus., giving them a 90 deg. angle relative to each other. The advantage of the bog-standard 'whisker' is that you can drill a small hole and pretty much poke them anywhere...
PS - I've just had a thought (staggering, innit?  Two in the space of an hour...).  Given Peter's comments about the braid being a reflector, does that mean that the entire 'whisker' should be out in the breeze for best reception?  I usually arrange mine so that just the 'active' bit is poking outside...
Edited By Mike T on 14/04/2020 12:42:00
I don't normally have mine poking outside the airframe. Balsa and fibreglass are pretty transparent to RF! I usually have a couple of plastic tubes, or even drinking straws, glued somewhere convenient inside the fuselage, and poke 'em down those.
Having them "out in the breeze" makes them more prone to unnecessary bending and damage. Keeping them inside the fuselage protects them, and won't have any significant impact on range.
The one caveat to the above statement is where carbon fibre, or any other kind of electrically conductive material (sheet aluminium, even silver foil) is present. These can make a very effective screen against RF, and aerials should not be placed nearby.
Pete
As an example of "how not to do it" have a look at the install for my 2m electric glider. The model is all carbon fibre (wing, fuselage, tailplane) apart from an approximately 6" section of the fuselage where the receiver sits which is glass or kevlar.
You can see the active portion of one aerial (yellow sleeved) almost taped to the side of the Rx. The other aerial is on the other side of the Rx with the slope reversed in the nearest I can get to a 90 degree separation!
I would never suggest anyone tries an install like this, but I have flown up to the safe limits of my elderly vision with a slim 2m glider - approx 500m LOS - without any problems.
It probably shouldn't work, but I have 3 models like this and they are all OK. If you are unsure of your receiver installation just make sure you do a really good range check with the model turned to all angles. Telemetry helps give confidence of course.
Dick
Posted by Dickw on 14/04/2020 16:29:33:
Dick
Quality radio gear obviously helps
I have some 2.4 GHz receivers which have only one aerial. Are these more likely to suffer from a loss of contact than those with the two aerials? As the best reception is at right angles to the incoming signal what is the best orientation for the aerial on such a Rx? So far I have located mine along the length of the fuselage and had no problems even when the model has been flying directly away from or towards me. Any suggestions would be welcome.
Malcolm
Hi Guys, and thanks.
Finally ended up with one aerial along the fuz, opposite side to the servo leads and the other poking down through the fuz bottom.
Big dollop of hot glue to hold it in place. Not pretty but who cares?
Just happy to get it off my bench. This model has fought me all the way. Glad to see the back of it.
Anyway, this has been an enjoyable and informative thread but now time to bring down the curtain.
Couple of final thoughts.
Thanks Stephen for showing an install almost as bad as mine. Makes me feel better. One thing. I may be wrong but shouldn't the radio be inside the fuz. Lot less drag that way!
Malcolm, I have a single aerial rx fitted to a 2.4m ASW28. Only managed one flight before weather and lockdown got in the way, but noticed no issues even at height.
You should be good to go.
Jeff
Posted by Malcolm Fisher on 14/04/2020 20:20:12:
Malcolm
I fly with Hitec gear, I have about 10 of the Optima 6 and 7 channel receivers which have only one antenna, and these have never given me any problems at all, even a large 3m thermal soarer flown to the limit of vision. These have the dipole set up with the fatter section by the whisker. I use the Optima 9 channel with 2 antennae for all larger, faster, heavier or expensive models even if they have 7 channels or less for added peace of mind, even though the 6 and 7 channel receivers have never been a problem.
Edited By PeterF on 15/04/2020 08:15:03
Posted by Jeffrey Cottrell 2 on 14/04/2020 22:52:19:
..................... I may be wrong but shouldn't the radio be inside the fuz. Lot less drag that way!
Jeff
surprise .... I knew I was probably doing something wrong. Should be a lot faster now, thankssmiley
Dick
