Robin Colbourne Posted November 15, 2021 Share Posted November 15, 2021 Cox Stuka Rebuild 1 Quote Link to comment Share on other sites More sharing options...
Rich Griff Posted November 15, 2021 Share Posted November 15, 2021 (edited) And the words Cox, Glow plug and control line not y mentioned even once The engine ran on a prime so a fuel feed issue, they don't d not say how they cleaned the engine. Long nose ( stumpy ) pliers to remove the head, no cylinder flats on that era so i wonder how he got the cylinder off ? Hope they didn't crash it if they flew it, worth quite a bit. Hope the oe engine was kept with the plane. Edited November 15, 2021 by Rich Griff Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted November 15, 2021 Share Posted November 15, 2021 One of my pivotal models(no pun intended) -as my first engine powered model. Don't think I ever got the little Cox .049 to run consistently for any length of time. Quote Link to comment Share on other sites More sharing options...
Barryorbik Posted November 15, 2021 Share Posted November 15, 2021 Steve made the mistake of referring to the bellcrank as operating the Ailerons too - not the Elevator. Apart from that it was easy watching but I'll bet it will not be flight tested as the undercarriage looked very flimsy, and the plastic airframe must be brittle too. I had a Wenmac plastic control line model back in the day, but it was far too heavy to fly properly and needed a smooth tarmac play ground to have enough ground speed to even lift off ! Quote Link to comment Share on other sites More sharing options...
Robin Colbourne Posted November 15, 2021 Author Share Posted November 15, 2021 5 minutes ago, leccyflyer said: One of my pivotal models(no pun intended) -as my first engine powered model. Don't think I ever got the little Cox .049 to run consistently for any length of time. Was the Cox 049 a factor in your username these days? ? Quote Link to comment Share on other sites More sharing options...
Bryan Lea Posted November 15, 2021 Share Posted November 15, 2021 A friend had a similar plane a Dauntless I think and my experience was the same as Barryorbik. Heavy and underpowered, Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted November 15, 2021 Share Posted November 15, 2021 (edited) I am pretty sure the repair shop gave that Stuka some new decals. I tend to agree that as the Cox ran on a prime and from a flick start at that, there was little fundamentally wrong with it. It looked like a reed valve Cox and once that gets gummed up it needs considerable care to rectify. The Stuka version is quite rare. In my loft I do have an original (1960?) P40 version that my Dad brought back from America along with a can of Cox 20% nitro fuel. No worries back then. Never flown. It 3 blade prop was used elsewhere. Edited November 15, 2021 by Simon Chaddock 1 Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted November 15, 2021 Share Posted November 15, 2021 (edited) 1 hour ago, Robin Colbourne said: Was the Cox 049 a factor in your username these days? ? I've still got at least one Cox .049 Robin. Had much greater success with them in the early noughties, but the airframes have long since been electrified. Even managed to get them running on 5% nitro in later years. Edited November 15, 2021 by leccyflyer typo Quote Link to comment Share on other sites More sharing options...
Robin Colbourne Posted November 15, 2021 Author Share Posted November 15, 2021 27 minutes ago, Simon Chaddock said: I am pretty sure the repair shop gave that Stuka some new decals. I tend to agree that as the Cox ran on a prime and from a flick start at that, there was little fundamentally wrong with it. It looked like a reed valve Cox and once that gets gummed up it needs considerable care to rectify. The Stuka version is quite rare. In my loft I do have an original (1960?) P40 version that my Dad brought back from America along with a can of Cox 20% nitro fuel. No worries back then. Never flown. It 3 blade prop was used elsewhere. Simon, that P40 must be quite a rarity. Maybe it was only sold on the other side of the pond? You thoughts on the gummed up reed valve in that Stuka were exactly what I was thinking as I watched it. Care would be needed, but I'm sure it could have been got going with the right person on the job. Quote Link to comment Share on other sites More sharing options...
Rich Griff Posted November 15, 2021 Share Posted November 15, 2021 (edited) Yep, lovely little things. I have 6 049's, screamers all of them, all destined for a model, 2 using a pt19 plastic wing and balsa fuz. They are easy starters and reliable runners The peewee is a jewel I'm after Rc carbs and parts for TD09 which are very powerful for the size. Anyone got any td09's or parts they will no longer use/need ? A pt19 fuz in any condition would be very usefully to me also Edited November 15, 2021 by Rich Griff Quote Link to comment Share on other sites More sharing options...
J D 8 - Moderator Posted November 15, 2021 Share Posted November 15, 2021 My od mini mustang racer made about thirty years ago had an outing recently. I had forgot just how fast it is on the lines [ lap about every 3 seconds ] and the sound of its TD 051 can be said to be frightening. Two minuets in the air is enough. Quote Link to comment Share on other sites More sharing options...
Wookman Posted November 15, 2021 Share Posted November 15, 2021 I have an 051 that used to be on a power pod on top of the Impala. Changing from 5% and a 6x3 to 16% and 5x3 certainly helped the performance but the noise was unreal. Quote Link to comment Share on other sites More sharing options...
Robin Colbourne Posted November 15, 2021 Author Share Posted November 15, 2021 16 minutes ago, Wookman said: I have an 051 that used to be on a power pod on top of the Impala. Changing from 5% and a 6x3 to 16% and 5x3 certainly helped the performance but the noise was unreal. Once when having a hearing test, it occurred to me that the frequency of my poor hearing coincided with the rpm of the TD049. 1 Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted November 16, 2021 Share Posted November 16, 2021 Just watching it now and surprised to see that the Stuka is green. Mine was all black and I've never seen a green one. Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted November 16, 2021 Share Posted November 16, 2021 Interesting that he replaced the missing spinner, but didn't replace the missing bomb. The damage was minimal really- the model really only needed a good clean, some minor gluing of broken parts and the engine sorting. Since they aren't going to fly it, I think personally that it would have been better to put the original, freed up engine back in and keep everything as original as possible. Quote Link to comment Share on other sites More sharing options...
Cuban8 Posted November 16, 2021 Share Posted November 16, 2021 (edited) Haven't seen the programme yet so looking forward to that. When I was about nine in the mid sixties, I badgered my parents to buy me IIRC a Keil Kraft control line Chipmunk for Christmas - goodness knows why. I do recall it being all plastic, light blue fuselage and possibly cream coloured wings with a Cox or maybe McCoy 0.49 of some description. a bit like a big Airfix model. Anyone remember it? I think they did an injection moulded Hurricane as well. I recall them being quite heavy so did they actually fly if you knew what you were doing? It came from Lathams in the Royal Arcade, Norwich and TBH, was totally out of my young skill set at the time - and with nobody to help me with it, it soon began to gather dust and was eventually lost, given away or dumped, I don't remember. Did take it over the local park on one occasion with my dad, who could build you a lovely brick wall, replace your ceilings or do intricate plastering but was all at sea with models, but would indulge me as much as funds allowed. A freezing cold day with snow on the deck and we never got a murmer out of the motor. Put me off control line (and flying in freezing cold weather) and I've never felt the urge to have a go at either ever since but do take my hat off to those that have mastered that particular branch of the hobby. Edited November 16, 2021 by Cuban8 Quote Link to comment Share on other sites More sharing options...
Rich Griff Posted November 16, 2021 Share Posted November 16, 2021 Hi Cuban, you may be thinking of the Cox pt19 fledgling which flew quite well and even better in aerobatic mode ( positional engine mount/firewall. However parts always broke. Kk did hurricanes with a mcoy wind backwards and let go sprung starter. They did a silver hurricane. The stuka was my favourite but I never had one, but did have a go with "pecks", a friend's. I did not crash it. Then came the champ and DC sabre, no flat battery needed. Quote Link to comment Share on other sites More sharing options...
John Lee Posted November 16, 2021 Share Posted November 16, 2021 I wanted the plastic Hurricane model as a youngster but the local model shop owner persuaded me to build a Phantom Mite on which to learn to fly C/L. Good advice which started me on the right path to success. This is from the back cover of Model Aircraft Magazine Aug 1965: 1 Quote Link to comment Share on other sites More sharing options...
Cuban8 Posted November 16, 2021 Share Posted November 16, 2021 (edited) 3 hours ago, Rich Griff said: Hi Cuban, you may be thinking of the Cox pt19 fledgling which flew quite well and even better in aerobatic mode ( positional engine mount/firewall. However parts always broke. Kk did hurricanes with a mcoy wind backwards and let go sprung starter. They did a silver hurricane. The stuka was my favourite but I never had one, but did have a go with "pecks", a friend's. I did not crash it. Then came the champ and DC sabre, no flat battery needed. It is well over 50 years ago and the memory can play tricks but I do recall the 'plane had the classic shaped closed Chipmunk canopy rather than the open PT19. Don't know for sure, certainly nothing comes up from a Google search. BTW, I just remembered that I did get a Phantom Mite kit a while afterwards (no idea why) and was very disappointed to find the attractive box just contained a few lumps of balsa, a plan and instructions to carve everything to shape! No go on that one either. No more control line after that. Edited November 16, 2021 by Cuban8 Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted November 16, 2021 Share Posted November 16, 2021 I remember poring over the Keil Kraft catalogue at the control line models but didn’t manage to afford such luxury as the Phantom Mite until I was into my later teens. I don’t recall any disappointment with the kit contents and it flew very well until an attempt at a loop went horribly wrong. I moved on to RC after that - but a few years ago I downloaded the plans and built a replica with a DC Merlin from my collection of bits and bobs. Perhaps one day I’ll pluck up courage to loop it but it’s well worth the effort of laying out the lines and flicking the engine into life - for the wonderful aroma at the very least - and getting rather dizzier than I recall in earlier years! 1 Quote Link to comment Share on other sites More sharing options...
David P Williams Posted November 16, 2021 Share Posted November 16, 2021 My dad bought me a ready to fly Cox Thimble Drone set, a Piper Cub or similar, all red IIRC. He wanted it of course, and I was the excuse. Would have been late 50s/early 60s. Off we went to North Reddish park where we got it running, dad on the handle, me hand launching as the grass was too long. It left my hand, went straight up, over the top, and piled nose first into the ground on the opposite side of the circle. Broken into a lot of pieces it was consigned to the loft and eventually binned, but I kept the engine. It did service on a powered glider years ago and I eventually sold it at a swap meet about 10 years ago. It was followed by a KeilKraft Champ with a PAW 149 which we did fly successfully, the engine from which was sold at the same swap meet. Quote Link to comment Share on other sites More sharing options...
Robin Colbourne Posted November 16, 2021 Author Share Posted November 16, 2021 (edited) The Cox PT19 and the Tri-ang/Frog/Cox Fledgling were two different aircraft, both Cox powered. This is the Fledgling: This is the PT-19. Its my brother's that he bought in Canada in 1970. The engine went into various other models and is around somewhere. Note how both models were available with reversed colour schemes to that on the box: Edited November 16, 2021 by Robin Colbourne PT-19 added. 1 Quote Link to comment Share on other sites More sharing options...
John Lee Posted November 16, 2021 Share Posted November 16, 2021 Those that had the PT-19 were in good company. Here's the first man on the moon Neil Armstrong with his son Mark & their Cox PT-19. 2 Quote Link to comment Share on other sites More sharing options...
Cuban8 Posted November 16, 2021 Share Posted November 16, 2021 50 minutes ago, Robin Colbourne said: The Cox PT19 and the Tri-ang/Frog/Cox Fledgling were two different aircraft, both Cox powered. This is the Fledgling: This is the PT-19. Its my brother's that he bought in Canada in 1970. The engine went into various other models and is around somewhere. Note how both models were available with reversed colour schemes to that on the box: Robin, I reckon you've solved it! The Fledgling looks very much like the model I had, maybe sold in a slightly different box, I can't be certain - but the right colours and a bit Chippyish as I said. Thanks. Quote Link to comment Share on other sites More sharing options...
PatMc Posted November 16, 2021 Share Posted November 16, 2021 2 minutes ago, Cuban8 said: Robin, I reckon you've solved it! The Fledgling looks very much like the model I had, maybe sold in a slightly different box, I can't be certain - but the right colours and a bit Chippyish as I said. Thanks. Cuban8, I think you should go to Specsavers ? Quote Link to comment Share on other sites More sharing options...
