r6dan Posted July 16, 2022 Share Posted July 16, 2022 What’s decent iron on film but not absurdly expensive? Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted July 16, 2022 Share Posted July 16, 2022 5 hours ago, r6dan said: Hobbyking same film can be bought from RapidRC and 4-Max. Steve Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted July 16, 2022 Share Posted July 16, 2022 24 minutes ago, EarlyBird said: The same film can be bought from RapidRC and 4-Max. Steve Just under £20 for a 5 mtr roll from Rapid. If you prefer ProFilm then better get a mortgage first 😉. 1 Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted July 17, 2022 Share Posted July 17, 2022 All the 'branded' films are ridiculously priced - 1M of Oracover cost twice as much as a 10M roll of generic film off t'net. Quote Link to comment Share on other sites More sharing options...
Outrunner Posted July 17, 2022 Share Posted July 17, 2022 Solarfilm still available direct from their website Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted July 17, 2022 Share Posted July 17, 2022 (edited) Yeah? Last time I visited the site, they only had a very limited range of colours...... Just visited and loads of colours. Yippee! Edited July 17, 2022 by GrumpyGnome 1 Quote Link to comment Share on other sites More sharing options...
Don Fry Posted July 17, 2022 Share Posted July 17, 2022 I’ve always reckoned Profilm and HobbyKing is the same plastic. It tacks at the same temperature, shrinks at the same temperature, melts at the salme temperature, and shrinks by the same amounts. 1 Quote Link to comment Share on other sites More sharing options...
Tim Donald Posted July 17, 2022 Share Posted July 17, 2022 I've started using MacGregor covering film which I think is the same as the Hobbyking stuff. It's pretty good - not as good as Oralight but about a third of the price. 1 Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted July 17, 2022 Share Posted July 17, 2022 4 hours ago, Don Fry said: I’ve always reckoned Profilm and HobbyKing is the same plastic. It tacks at the same temperature, shrinks at the same temperature, melts at the salme temperature, and shrinks by the same amounts. Maybe. Does Profilm leave a visible white glue line on overlaps? Quote Link to comment Share on other sites More sharing options...
Andy Stephenson Posted July 17, 2022 Share Posted July 17, 2022 50 minutes ago, GrumpyGnome said: Maybe. Does Profilm leave a visible white glue line on overlaps? The answer is no because unlike HK film Profilm uses a transparent adhesive. Quote Link to comment Share on other sites More sharing options...
Don Fry Posted July 17, 2022 Share Posted July 17, 2022 Didn’t say the same GG, just the same plastic, and therefore when glued and shrunk, looks the same. White overlap, invest in some acetone, then there are no white glue lines after a wipe. Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted July 17, 2022 Share Posted July 17, 2022 Obviously transparent adhesive is expensive 🙂 Yeah, I use acetone on overlaps. Quote Link to comment Share on other sites More sharing options...
Keith Billinge Posted July 17, 2022 Share Posted July 17, 2022 I used to use the HobbyKing stuff; but now the postage is so expensive, the stuff from 4-max is the same quality, but not so crazy expensive. Approx £20-£25 for 5metres. You're welcome KB Quote Link to comment Share on other sites More sharing options...
Ace Posted July 17, 2022 Share Posted July 17, 2022 Personally I like the HK/4 Max/Rapid RC film which are Polyester so almost burn proof like Oracover. However they only have one layer with colour and glue so can leave some colour behind if not careful if removed without heat. Oracover traps the colour between two layers then the glue so removes cleanly - I believe that is the difference for a price. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted July 18, 2022 Share Posted July 18, 2022 RapidRC get my vote for covering film. 1 Quote Link to comment Share on other sites More sharing options...
David Holland 2 Posted March 31, 2023 Share Posted March 31, 2023 Does anyone share my enthusiasm for Ripmax AeroFilm? I have covered my last three builds with it and am currently covering a DB Tiger Moth in silver (the immediate post-war RAF trainer silver/yellow scheme). It is relatively cheap, very opaque, sticks like you know what to a blanket, no backing film to wrestle with, goes round compound curves really well and shrinks like a good 'un. I would have preferred Solartex but........... David Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted April 1, 2023 Share Posted April 1, 2023 I cant remeber the name of it but a short while ago there was some so called "seconds" possibly from perkins ? It was awful stuff. Dont be tempted to buy it if you see it offered just slightly cheaper than proper covering. Rapid RC covering is excellent . Quote Link to comment Share on other sites More sharing options...
colin wray 2 Posted April 1, 2023 Share Posted April 1, 2023 It was easy cote seconds as you say it was utter rubbish Quote Link to comment Share on other sites More sharing options...
Outrunner Posted April 1, 2023 Share Posted April 1, 2023 I had a roll of Easycote seconds in silver and had no problem with it. The only film I have problems with is Oracover as is costs an arm and a leg. Quote Link to comment Share on other sites More sharing options...
Andy Stephenson Posted April 1, 2023 Share Posted April 1, 2023 The Easycote 2nds in red that I tried to use is very thin and translucent. It doesn't cover the black lines of a laser cut structure and I found it stays sticky after cooling. I am, by contrast, refurbishing a model with 4Max covering which goes on extremely well at low temperature and shrinks very nicely. Because of the low temperature characteristic, it doesn't go mat when rubbed over with the iron. It's also much cheaper than Profilm and at least as good. So goodbye Profilm with your arm and a leg pricing, it was good whilst it lasted. Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted April 1, 2023 Share Posted April 1, 2023 6 hours ago, Outrunner said: I had a roll of Easycote seconds in silver and had no problem with it. The only film I have problems with is Oracover as is costs an arm and a leg. Thats the trouble with seconds , you dont know if your getting the usable stuff or the rubbish. Quote Link to comment Share on other sites More sharing options...
