J D 8 Posted March 31, 2023 Share Posted March 31, 2023 11 hours ago, GrumpyGnome said: 3S lipo cable tied to the starter (20cc max engines); NiMh glow stick (don't tell Jon but some planes have on-board-glow units..); manual fuel pump. I'm a heathen and have NEVER put a LiPo into storage - but I use cheap packs and fly year round. I use onboard glow units for some models where connection can be awkward, but of the type that you push a button [little 2s batt powered] and for 15/20 seconds you have glow to start your motor then goes off and remains off [ this type fine with Jon I recon] I like as you just press button, spin prop and away to go. Nothing to connect or disconnect. PS, also a bit of a heathen with Lipos. Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted March 31, 2023 Share Posted March 31, 2023 I've never seen an issue with a glow stick, but have seen wires caught in the prop, and on an airframe when lifting a plane with a running engine, causing the nose of the plane dipping towards legs.. Shows the need for vigilance and care, irrespective of equipment. Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted March 31, 2023 Share Posted March 31, 2023 (edited) I used to use a 12v 7amp hr lead acid in my flight box but as i seem to be using it less frequently of late the batteries quickly suffered. I removed the old battery and soldered a heavy leads to the panel input that has an XT 60 connector. If the box and panrel are need I take a 3s 2p li-ion pack along and plug it in when required. Pack is assembled from cells out of old laptop battery packs or old tool/ drill packs that can be bought cheaply. Usually only one cell has gone down rendering the pack unusable but ideal for cells . They hold charge well, give far better power for starter motors and are much lighter than lead acid or Nimh equivalent. You will need to fit a balance lead etc and charge with a lipo/li-ion charger but most of us have them anyway. For glow plugs a glow stick is prefered method. Edited March 31, 2023 by Engine Doctor Quote Link to comment Share on other sites More sharing options...
steve too Posted March 31, 2023 Share Posted March 31, 2023 (edited) 18 hours ago, toto said: What is the best kind of battery I don't know about best but, in common with lots of posters above, I use an old LiPo to power my starter and glow. IIRC it's a 3S 4500mAh. My glow starter is based around an XL4015 regulator as suggested this topic - 12 hours ago, GrumpyGnome said: some planes have on-board-glow units Once the prop size gets to 13", my glow planes get an onboard unit. Edited March 31, 2023 by steve too Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted March 31, 2023 Share Posted March 31, 2023 (edited) I used to use a simple ammeter, at the time a 2v 10ah lead acid battery. I only use an onboard heater when the engine doesn't run properly, as most do ( OS, Enya and Saito ) especially the bigger engines don't need one, and it's only something else to go wrong. Edited March 31, 2023 by Paul De Tourtoulon Quote Link to comment Share on other sites More sharing options...
steve too Posted March 31, 2023 Share Posted March 31, 2023 11 minutes ago, Paul De Tourtoulon said: I only use an onboard heater when the engine doesn't run properly I use onboard starters to minimise the amount of time my body parts spend near spinning props. 1 Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted March 31, 2023 Share Posted March 31, 2023 I think in the event I should ever want a large petrol engine powered model and onboard starter would be a requirement. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted March 31, 2023 Share Posted March 31, 2023 (edited) I think we've scared the OP off... he only came here for a battery recommendation... Edited March 31, 2023 by Nigel R Quote Link to comment Share on other sites More sharing options...
Cuban8 Posted March 31, 2023 Share Posted March 31, 2023 (edited) Hands up who's forgotten to disconnect their glowstick and then proceeded to fly off? Inverted engines can especially catch you out........guilty as charged, I'm afraid - but only the one time to the best of my memory. 😖 Edited March 31, 2023 by Cuban8 1 Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted March 31, 2023 Share Posted March 31, 2023 ✋ Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted March 31, 2023 Share Posted March 31, 2023 Never made it to flight but I’ve come close. I’ve used the twist lock versions extensively and never had a glow plug come loose. I gave up on commercial flight panels after experiencing - and seeing numerous examples of - circuit failures putting out unregulated 12V onto the glow output (this excludes a number of my clubmates using the wrong output terminals) which invariably costs 2 (and often more) glow plugs before the light dawns. However, I did build a glow unit utilising a very cheap regulator module and digital volt/amp meter which is useful for monitoring the fuel mixture in the cylinder as well as providing reliable ignition. 2 Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted March 31, 2023 Share Posted March 31, 2023 (edited) 1 hour ago, Martin Harris - Moderator said: Never made it to flight but I’ve come close. I’ve used the twist lock versions extensively and never had a glow plug come loose. I gave up on commercial flight panels after experiencing - and seeing numerous examples of - circuit failures putting out unregulated 12V onto the glow output (this excludes a number of my clubmates using the wrong output terminals) which invariably costs 2 (and often more) glow plugs before the light dawns. However, I did build a glow unit utilising a very cheap regulator module and digital volt/amp meter which is useful for monitoring the fuel mixture in the cylinder as well as providing reliable ignition. I too use the twist and lock and starting up my Laser powered Chipmunk as it was warming up a bang then the engine stopped with the prop still turning. fearing the worst, no compression and the prop still in place I thought the crankshaft had snapped. on further examination the glow plug had come out. after that I still use the twist and turn glow stick but check the plug regular for tightness. A friend of mine blew two gold plated OS four stoke plugs due to a faulty flight panel, not literally gold but at £15 each not far off. I keep my field box as light as possible as I fly all year weather permitting, and now 87 yrs walking across a muddy field carrying a large aeroplane and field box is getting no easier so no flight panel no lead battery, a glow stick a hand pump, a starter with a 3s 3000 lipo and a few tools and a half gallon of fuel is enough for me. Having said that I only live 3mins drive from the field so it's easy to go home and get another plane or whatever I need. Edited March 31, 2023 by Eric Robson 3 Quote Link to comment Share on other sites More sharing options...
Cuban8 Posted March 31, 2023 Share Posted March 31, 2023 22 minutes ago, Eric Robson said: I too use the twist and lock and starting up my Laser powered Chipmunk as it was warming up a bang then the engine stopped with the prop still turning. fearing the worst, no compression and the prop still in place I thought the crankshaft had snapped. on further examination the glow plug had come out. after that I still use the twist and turn glow stick but check the plug regular for tightness. A friend of mine blew two gold plated OS four stoke plugs due to a faulty flight panel, not literally gold but at £15 each not far off. I keep my field box as light as possible as I fly all year weather permitting, and now 87 yrs walking across a muddy field carrying a large aeroplane and field box is getting no easier so no flight panel no lead battery, a glow stick a hand pump, a starter with a 3s 3000 lipo and a few tools and a half gallon of fuel is enough for me. Having said that I only live 3mins drive from the field so it's easy to go home and get another plane or whatever I need. I haven't used a flight panel for years, but back in the day I used leads and banana plugs to make the connections both to the 12V starter output and 2V glow on the panel. Yes, you know what's coming.............. Probably blew a couple of glowplugs by mixing up the connections - not so bad when plugs were only a couple of quid a time. Hard wired it all in the end. Panel still sits in my flightbox for ornamentation. Had the box for my 40th birthday 26 years ago - nice, sturdy fold up type thing that you can use as a seat when closed. Kit built from 'Somebody or Other' (can't remember) Aviation. Quote Link to comment Share on other sites More sharing options...
