toto Posted March 30, 2023 Share Posted March 30, 2023 I'm looking at putting a field box together and at the moment I have electric models ..... but I know I will be using nitro as well. I'm looking for a suitable battery for the field box that willpower the pump, glow started if necessary and also a J'EN 4:1 geared starter. The panel purchased is a Prolux Ultra Panel LCD multifunction w / 5A 1-8 NIMH peak charge. What is the best kind of battery ..... sealed lead acid ? Or what. It needs to fit in a typical area under the power panel. If someone can give me the low down with exact technical spec, I would be grateful. Also .... what type of leads would I require to connect battery to panel. Many thanks Toto Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted March 30, 2023 Share Posted March 30, 2023 My field battery used to be the lead acid 7amp 12volt one now a lipo, I use a 4S 5000mah 40c which the starter is coupled to as I still fly 10cc methanol Helicopters and in winter the 12v ( 3s ) isn't enough, the 12v is taken from the balance plug for the glow driver and fuel pimp . Quote Link to comment Share on other sites More sharing options...
Nigel R Posted March 30, 2023 Share Posted March 30, 2023 One old, cheap, 3S2000 lipo, strapped to the starter. Another old, cheap, 3S2000 lipo, running the glow driver and fuel pump. I can run the starter through the panel if one lipo goes flat. Ditching the SLA was the best single improvement I made to the field box. 2 Quote Link to comment Share on other sites More sharing options...
toto Posted March 30, 2023 Author Share Posted March 30, 2023 So .... if using a lipo, do you have to discharge if not using for a week or two. I suppose I could also strap a lipo to the started to keep that separate from the panel. More flexible I suppose and means I dont have to lug the whole box up onto the field starter bench. Choices choices. What was the gripe with the lead acid battery. Was it purely weight or are there any other disadvantages ? Cheers toto Quote Link to comment Share on other sites More sharing options...
Cuban8 Posted March 30, 2023 Share Posted March 30, 2023 (edited) I always used to use sealed 12V gel batteries, but go for a reasonably sized 3S Lipo now. Easier to charge and a hell of a lot lighter. Don't leave it in your flightbox when not in use and make sure you can easily and quickly disconnect and remove it in case of an emergency (usual lipo safety advice) - also, make sure you don't over-discharge it, little likelihood but easy to forget if you do a lot of flying or have a recalcitrant engine when it comes to starting! Plenty of lipo discharge voltage alarms on Ebay for three or four quid or so. Edited March 30, 2023 by Cuban8 Quote Link to comment Share on other sites More sharing options...
John Wagg Posted March 30, 2023 Share Posted March 30, 2023 (edited) I've got a 12v/9A battery in my field box but it is a bit heavy when also loaded with 1/2 gallon of fuel. (12 stone weakling!) https://www.ebay.co.uk/itm/231568304738?var=530806014137 Because of the weight I would certainly consider a 4s Lipo now. But I've gone for a manual fuel pump :- https://www.rapidrcmodels.com/jp-deluxe-hand-fuel-pump-5183-p.asp I've had an electric pump but it did give problems now and again. and a 1 x cell Ni-mh plug - similar to:- https://www.rapidrcmodels.com/glo-start-clip-s-2400mah-nimh--charger-3pin-5793-p.asp The drawback to these is if the plug is hidden. I have other connectors which run of the panel on my box. P.S. I run my starters off the 12v battery but again I would consider a LiPo on the starter. I've seen 2 version. 1 - LiPo fixed/taped to the starter. 2 - The LiPo seoerate from the starter but connected via the starter cable using clips. Edited March 30, 2023 by John Wagg Quote Link to comment Share on other sites More sharing options...
Nigel R Posted March 30, 2023 Share Posted March 30, 2023 14 minutes ago, toto said: if using a lipo, do you have to discharge if not using for a week or two. in a word, no Quote Link to comment Share on other sites More sharing options...
Cuban8 Posted March 30, 2023 Share Posted March 30, 2023 (edited) Be careful of a 4S lipo, some starters might be rated for over 12V but I know for sure that my Pro-lux example isn't. Electric fuel pumps are posh but i've never had one that didn't leak after a short time or simply just burn out. Bought a Dave Brown Six-Shooter hand pump twenty years ago, possibly more, and never had to open it up - still on the original rubber tube.. Don't think they're available now, sadly. Edited March 30, 2023 by Cuban8 Quote Link to comment Share on other sites More sharing options...
Richard Wills 2 Posted March 30, 2023 Share Posted March 30, 2023 (edited) Manual pump, nimh glow stick, and an align starter with it's own internal lipo for me. Much simpler, lighter and no dangling cables to get caught in anything. Edited March 30, 2023 by Richard Wills 2 2 1 Quote Link to comment Share on other sites More sharing options...
Cuban8 Posted March 30, 2023 Share Posted March 30, 2023 Well, it just goes to show..................https://www.sussex-model-centre.co.uk/products/dave-brown-six-shooter-fuel-pump-gas-petrol-diesel Quote Link to comment Share on other sites More sharing options...
Nigel R Posted March 30, 2023 Share Posted March 30, 2023 13 minutes ago, John Wagg said: and a 1 x cell Ni-mh plug - similar to:- I did have a glow stick, but the battery has died. I just reverted to using the panel again. I might pick up another stick, they're more convenient than a big cable. Safety? Jury's out. Glow sticks can wobble a bit when they're on the motor. 1 minute ago, Cuban8 said: Electric fuel pumps are posh but i've never had one that didn't leak after a short time or simply just burn out Mine is quite old now, but I do run it with a 6V (ish) supply, maybe that helps. It's one of these: https://www.makeitbuildit.co.uk/prolux-6-12v-electric-fuel-pump-25807 Quote Link to comment Share on other sites More sharing options...
kc Posted March 30, 2023 Share Posted March 30, 2023 A 12volt 6 amp Sealed Lead acid battery is cheaper now than a 3S2200 Lipo and has other uses - it can start your car if it's battery is low ( after holidays etc or just old ) it can be used on my lawnmower or to start someone elses car in emergency. But it's real advantage is that it can recharge your Lipos at the field - several recharges of the 3S2200 seems practical. So a cheaper , more useful option that is probably a bit safer than a Lipo. Quote Link to comment Share on other sites More sharing options...
Alan Gorham_ Posted March 30, 2023 Share Posted March 30, 2023 Manual pump, Cyclon 2V lead acid cell and long set of glow leads and a glove for me. Much easier to carry any distance from car to pits. Don't even take the Cyclon cell if flying diesel or spark engines! Quote Link to comment Share on other sites More sharing options...
Cuban8 Posted March 30, 2023 Share Posted March 30, 2023 3 minutes ago, kc said: A 12volt 6 amp Sealed Lead acid battery is cheaper now than a 3S2200 Lipo and has other uses - it can start your car if it's battery is low ( after holidays etc or just old ) it can be used on my lawnmower or to start someone elses car in emergency. But it's real advantage is that it can recharge your Lipos at the field - several recharges of the 3S2200 seems practical. So a cheaper , more useful option that is probably a bit safer than a Lipo. I've seen someone jump start their car at Old Warden when they left their car lights on from a Lipo..................lipo or small sealed lead acid, you're pushing your luck using them for a car jump start. Depends how flat the main battery is, I suppose. Carry a small lipo in my motorbike's topbox to power the miniature, but very effective tyre airpump I have. Easier than faffing about with taking the seat off and getting to the awkwardly placed main battery. Quote Link to comment Share on other sites More sharing options...
Jon H Posted March 30, 2023 Share Posted March 30, 2023 Just to be completely different i use a small 10cell nimh for my field box as this is man enough for the fuel pump, glow drive (when i need it) and my small starter for small engines (50 4 stroke or smaller). I then have a 6s lipo for my big daddy 6.5:1 geared starter used for all my big lump engines. 1 Quote Link to comment Share on other sites More sharing options...
Nigel R Posted March 30, 2023 Share Posted March 30, 2023 4 minutes ago, Jon - Laser Engines said: i use a small 10cell nimh for my field box heresy 😀 Quote Link to comment Share on other sites More sharing options...
PDB Posted March 30, 2023 Share Posted March 30, 2023 (edited) 32 minutes ago, Nigel R said: I did have a glow stick, but the battery has died. I just reverted to using the panel again. I might pick up another stick, they're more convenient than a big cable. Safety? Jury's out. Glow sticks can wobble a bit when they're on the motor. I've been using https://www.nexusmodels.co.uk/j-perkins-micro-glo-start-1800mah-nimh-4444530.html which twist and lock onto the glow plug, rock solid and easy to remove. Edited March 30, 2023 by PDB 1 Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted March 30, 2023 Share Posted March 30, 2023 Used to use a SLA, but now use a manual pump,, single cell glow stick and a 4s LiFe battery for the starter (an old one with the A123 cells) 1 Quote Link to comment Share on other sites More sharing options...
Zflyer Posted March 30, 2023 Share Posted March 30, 2023 Manual pump, align starter (with internal Lipo and charge state gauge) glow stick, job done. 1 Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted March 30, 2023 Share Posted March 30, 2023 Bought every gizmo known to man when I started, waste of money and room and a pain in the rear to carry, manual fuel pump, lipo on your starter if you don't like flicking, less is more. 4 1 Quote Link to comment Share on other sites More sharing options...
Andy J Posted March 30, 2023 Share Posted March 30, 2023 47 minutes ago, PDB said: I've been using https://www.nexusmodels.co.uk/j-perkins-micro-glo-start-1800mah-nimh-4444530.html which twist and lock onto the glow plug, rock solid and easy to remove. Would not recommend the twist and lock glow battery devices as it has a tendency to unscrew the glow plug. Result was a lost glowplug during flight. Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted March 30, 2023 Share Posted March 30, 2023 3S lipo cable tied to the starter (20cc max engines); NiMh glow stick (don't tell Jon but some planes have on-board-glow units..); manual fuel pump. I'm a heathen and have NEVER put a LiPo into storage - but I use cheap packs and fly year round. Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted March 31, 2023 Share Posted March 31, 2023 (edited) 13 hours ago, Andy J said: Would not recommend the twist and lock glow battery devices as it has a tendency to unscrew the glow plug. Result was a lost glowplug during flight. I would never use one of those they were developed for nitro cars, I did see a couple( both types with the battery on the end ) go into the prop when started, d,,, frightening,,,🤢 Edited March 31, 2023 by Paul De Tourtoulon Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted March 31, 2023 Share Posted March 31, 2023 Only use a glow clip ( any type ) with a wire on it, if it does vibrate off it won't or shouldn't go into the prop, but beware they can get caught up in the undercarriage when picking your plane up. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted March 31, 2023 Share Posted March 31, 2023 indeed... drape the wire backward over TE, i.e. away from the prop, it tends to pull/drag a stray clip in the same direction i.e. away from prop. Quote Link to comment Share on other sites More sharing options...
