Winglets
Fly Boy 3
It rather depends on what you want or expect winglets to do.
A GG suggests they can be useful to create side area at which they can work well but If you are trying to improved the aerodynamic efficiency of a wing by controlling the tip vortices then they most unlikely to make any practical difference at model sizes and speeds.
After all such winglets benefits are only measurable, and then only by a few %, on airliners on long duration accurately controlled flights.
12 hours ago, Andy Stephenson said:
 it can bring down the time between runway movements where lingering turbulence is no longer a safety risk.
That's not true as ATC do not know which aircraft have Winglets added or not. ATC Separation is either based on time or distance and has not changed. And there is nothing to enter on a flight plan saying winglets added or the type of the winglets.
In the case of full size gliders the vertical wing tip extensions control the airflow at the wing tip and in doing so improve the performance of the outer sections of the ailerons considerably. Also the overall wing tip drag is reduced, and thus it follows that the overall glide angle is improved.
With regard to models one might debate this at length, but perhaps it is permissible to say that the bigger the wing span the bigger the effect will be.
