Close call!
Neddy
I had an old 1.4mtre foam wing from a crashed plane. So I made up a fuselage and tail section to suit from foam board. It was a successful build and flew well. I took it out for a flight yesterday. It flew for about three minutes then I lost radio contact.  It was still under power no matter what I did it would not respond. It did a big loop and finished up behind me and was headed straight at me. Then it did hit me in the back of my head and shoulder. Fortunately it was only the wing which broke into three sections. I had the fuselage with motor running fly past my left ear. I wasn't hurt but it did give me a scare. The transmitter and receiver were very basic and old and I won't use them again. It did not have a fail safe function so I don't know what would have caused this. I was by myself in a remote area if I had been hurt I would have been in trouble. I was lucky!
  • Sad 1
Thanks for sharing!.
Many years ago, I was flying my Hanno Prettner "Stratos" foam based deltal
OS 40 FSR powered.
All went well until flying inverted at height, the battery fell out of the hatch, dangled for a few seconds and then dropped out.
I was flying on my own at our remote patch, but adjacent to a road.
As there was NOTHING I could do, I watched it do what seemed like hundreds of loops before it destroyed itself on impact.
Luckily, there was nobody about and very light winds, so it did not drift to far away.
Note to self........make sure the rx battery cannot jump out on its own!.
Many years ago I used to fly with Maurice Tait , Morley Helicopters at a few trade shows. Our caravan was used to provide a show stand. At Ledbury one year I was trying to sell a Hughes 300 kit when there was an enormous noise and an SE5 went straight in behind me brushing my back !😱😱 Later a stag pushed its hooves down my back. Every blood vessel broke the surface of my back.  A very dangerous hobby !😂😂😂😂Colin
Flying my Kyosho Majestic It took off and felt very heavy and sluggish on a low fly by all became clear . The glow stick was still attached and hanging from the inverted engine ! . On the final go around to land... you guessed it the glow stick came off ! Sit its still many years later languishing in a field in Kent 😊. Worse thing was that it was a brilliant small  twist on type glow stick that had a really good battery on it . Now use remote glow clip where the glow stick is VERY noticeable .
If we are honest we have all done silly things and got away with it ... most of the time. We wont mention the one we never got away with.... will we 😉.
IC or electric? You mention the motor,  so does that suggest electric?
Rare for an ESC to continue if it looses the input from the Rx unless a failsafe has actually been set to keep the throttle open.
Is the radio a Futaba 2.4 by any chance? By default they have the throttle reversed.
I have had to jump out of the way more than once when my plane was on approach flying directly towards. Its only when the plane gets really close does it dawn that it is actually going to hit me!
  • Confused 1
The nearer it gets it seems to get much much faster 😉
I take it you don't fly in a club and haven't a pilot box away from strip?
Edited by Learner
11 hours ago, Neddy said:
I am an oldy.  The motor electric. The plane hit me from about a 45deg angle coming down from a tight loop.  I had no time to jump out of way.
You say that the model continued under power but with no response to the controls. A far as I'm aware even without the tranny failsafe activating, all brushless ESCs will cut off when they  lose the throttle signal from the RX. If the ESC to RX plug had disconnected the servos would have frozen in postion (no BEC supply now) but the motor would have stopped so I doubt if it was that. Very odd.
BTW, I flew a large thermal soarer between my feet on a fast and misjudged landing approach towards myself (intended to land off to one side) and bashed my shins very badly years ago.
36 minutes ago, Neddy said:
I have repaired the plane and have changed the receiver with a new one and  a new transmitter to suit. I will give it another flight during the week hopefully I won't need to wear a crash helmet.
Don't to forget a range check before flying.
On 08/09/2024 at 15:53, Paul De Tourtoulon said:
I just tried my T6ex futaba on 41.000, no failsafe, I just turned the Tx off as stated reverse on channel 3 ( motor), the motor didn't do anything.
I will try one on 2.4,,,
Hi Paul. I take it you reffering to 40 meg radio ? The pre 2.4 radios , from memory, only had fail safe on selected rxs. The 35 meg as far as I can remember only had FS on the top of range PCM rxs . Hence the BMFA guidance then or words similar to " if fail safe is available it must be working" . The fail safe is built into the Rx and nothing to do with the TX , although some fail safe systems were set via  the tx it  is the Rx that does the deed .
