Peter Miller Posted August 8, 2019 Share Posted August 8, 2019 I haven't weighed it but not heavy 4-Max 3542 1070 motor, 40 amp ESC, 10 X 5 APC prop. 3S 2200 battery. All actually salvaged from Miss Deeds after my stupid accident. Some one asked if I had my Swiss Army Knife on me just after I had taken off. The idiot pilot took his hands off the controls to reach in his pocket Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted August 9, 2019 Share Posted August 9, 2019 Airwave Clubstar. More data. Wing area 430 Sq. in. Weight 2 lbs 8 ounces, Wing loading 13 ounces per sq foot. Span 48" Chord 9" Very close to the Ohmen. but this uses a flat bottom section with positive incidence and the CG further back than I like. Quote Link to comment Share on other sites More sharing options...
Geoff S Posted August 9, 2019 Share Posted August 9, 2019 Posted by Peter Miller on 08/08/2019 21:20:01: I haven't weighed it but not heavy 4-Max 3542 1070 motor, 40 amp ESC, 10 X 5 APC prop. 3S 2200 battery. All actually salvaged from Miss Deeds after my stupid accident. Some one asked if I had my Swiss Army Knife on me just after I had taken off. The idiot pilot took his hands off the controls to reach in his pocket Thanks, Peter. Perhaps another idiot was the one distracting a pilot who had just taken off? Sorry about poor Miss Deeds; she must have been devastated Geoff Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted August 9, 2019 Share Posted August 9, 2019 To be very fair, the other "idiot" did immediately offer to rebuild the model. but it was THIS idiot who didn't say "ether wait or you can root in my pocket among the snotty tissues etc to ge the knife" They only wanted the screwdriver onthe knife. That will teach them to bring their own tools!! Just started to design the replacement. Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted August 9, 2019 Share Posted August 9, 2019 Long way till it’s finished but it is my first Spitfire and I wanted to show it off ! No build log as it all been done before. It’s the Cambrian 55 inch converted to electric. Got the last one off the stand at the Weston show. Quote Link to comment Share on other sites More sharing options...
martin collins 1 Posted August 9, 2019 Share Posted August 9, 2019 Very nice, what retracts are you using?........... Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted August 9, 2019 Share Posted August 9, 2019 Martin, I decided the Flightline 1200 spitfire retracts would be about right so ordered the retracts/legs ( along with steerable tail wheel) and doors from the Motor RC spares shop. all seemed to drop in nicely. Tim Edited By Tim Ballinger on 09/08/2019 19:22:24 Quote Link to comment Share on other sites More sharing options...
Kevin Fairgrieve Posted August 14, 2019 Share Posted August 14, 2019 Maidened this yesterday. Goes like stink on a TT42GP. Ran out of elevator on finals (dead stick) and it landed flat in a field of sugar beet. No damage. CofG amended and it awaits its second flight. I am sure I saw a post a few days ago where someone was looking for this plan or something very similar to convert to electric, blowed if I can find it though. Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted August 14, 2019 Author Share Posted August 14, 2019 I made one years ago, OS 25FP so enough. still got it and gets flown every now and then. Called Mini Whizz, I think. The one pictured was a new photo, though not as new, still looks the same. Might build a new one, as it's so simple to build and use lighter gear. Quote Link to comment Share on other sites More sharing options...
Old Geezer Posted August 15, 2019 Share Posted August 15, 2019 Many many years ago I put together a somewhat similar flat plate wing - the Stratos - a Hanno Prettner design, 1&1/2" thick foam sheet covered in wrapping paper, a sliding servo set-up to give elevon mixing and an unemployed cooking 40 on the front. I had the same problem with running out of up elevator, but not only dead stick but also rounding out from a dive under power - the only remedy ( if you were far enough off the ground ) was to push the stick forward to regain some control. Dead stick you are losing the prop' wash over the elevons that give control authority when the air flow has been stalled or the airflow masked by the high angle of attack that you progressively apply to keep the thing flying - in fact the same thing could happen if it was well and truly stalled under power and there wasn't enough height to dive out of the stall, as in slowing down on finals. R.I.P. ! Despite the above I built another 4-5 years ago, this time one with a big Axi on the front and a 4S 4000 LiPo driving it, same problems but still enormous fun but at least I now know enough about the idiosyncrasies of flat plate deltas to avoid ( most of the time ) the "E" Stratos biting me. Edited By Old Geezer on 15/08/2019 07:54:47 Edited By Old Geezer on 15/08/2019 07:56:27 Quote Link to comment Share on other sites More sharing options...
Reno Racer Posted August 15, 2019 Share Posted August 15, 2019 1/4 Scale Nieuport 17 built from a Balsa USA kit Quote Link to comment Share on other sites More sharing options...
Guest Posted August 17, 2019 Share Posted August 17, 2019 My Vagabond Senior is based on Bill Winter's 75" span Vagabond 1949 plan and his redesign for RC in 1981. It is scaled up by 50% to 112” span. Powered by a 500W brushless motor and 5000 4 cell Lipo. The cerise red chiffon doped over mylar film turned out nicer than I thought it would. The videos shows the maiden flights of both the 75" and the 112" span models. The wind and ground turbulence was higher than I would normally fly vintage in but I needed a proving flight before going to a flyin. Photos show the breakdown for transport and storage. Carbon rods are used as joiners for the wings and to the fuselage. The white model is my 100" span Cumulus by Ben Shershaw. Build thread for the Vagabonds is here **LINK** Youtube videos are here. Mick Butler took the videos and more of his vintage videos can be viewed thru the links. **LINK** **LINK** Quote Link to comment Share on other sites More sharing options...
conrad taggart Posted August 17, 2019 Share Posted August 17, 2019 Posted by Mark Agate on 07/07/2013 08:51:42: Just about to head out with this for the first time: Hobbyking SPAD XIII, 700mm span LIke th elook of that ! Quote Link to comment Share on other sites More sharing options...
Mark Agate Posted August 18, 2019 Share Posted August 18, 2019 I had a lot of fun with that SPAD back in 2013/14, until it was cruelly cut from the skies in a mid-air with an IC model. Sadly the kit is no longer made. However, the top wing panels live on in my version of the RCM&E Sticky. I chopped the centre out and rejoined the panels flat to use as an aileron wing, as they were just about the perfect size and section. It flies very well. Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted August 21, 2019 Author Share Posted August 21, 2019 Bugly Ugger. Quote Link to comment Share on other sites More sharing options...
Chris Walby Posted August 23, 2019 Share Posted August 23, 2019 In a moment of weakness I went a bit electric! Anyway it turned up promptly from Motion RC EU including the heavy duty U/C which fitted a treat. Maiden was a complete non event with loads of power to get off the deck, couple of clicks on right aileron and it felt very stable. 1/2 flaps and only used 1/2 of our short runway to land. Decals to finish Summary, despite its war bird wing loading (funny that!) it flies well and landed no trouble, but might bite if allowed to run out of airspeed. Well done Motion RC for the P38L Lightning Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted August 26, 2019 Author Share Posted August 26, 2019 Couple of new models. Hanger 9 Hellcat and unknown make of P-39. The P-39 has all gear to fly. OS 48 Surpass and Evolution 61 in the Hellcat. Seemed the P39 cowl is a different colour Looks like the film has faded, as it's matched under the wing seat and cowl. Quote Link to comment Share on other sites More sharing options...
Alan Gorham_ Posted August 26, 2019 Share Posted August 26, 2019 That P-39 looks a lot like a P-40! Quote Link to comment Share on other sites More sharing options...
Former Member Posted August 27, 2019 Share Posted August 27, 2019 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted August 27, 2019 Share Posted August 27, 2019 Posted by Alan Gorham_ on 26/08/2019 22:10:14: That P-39 looks a lot like a P-40! Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted August 28, 2019 Author Share Posted August 28, 2019 It is, must be autocorrect, That's what I meant. Quote Link to comment Share on other sites More sharing options...
Ken Lighten Posted August 29, 2019 Share Posted August 29, 2019 My latest build, a Sunbird 1.6 metre wingspan electric glider from a ‘cheap’ laser cut kit, an ‘interesting’ build!, there is now a version 2 of it that seems to have removed the really bad bits of the design (think I got it on eBay), flew it today in a bit of a breeze, really nice to fly Ken Quote Link to comment Share on other sites More sharing options...
David Davis Posted September 1, 2019 Share Posted September 1, 2019 Last year I participated in "La Coupe Des Barons," a light-hearted competition for a French trainer dating from the early 1970s. Click on this link and scroll down to "Video Coupe 2018" to see the mayhem. **LINK** I competed with this model in spoof Russian WW1 colours built from a kit. I do not normally give my models names but I called this one "Boris." This year, using the kit plan but shortening the nose a bit to allow for the weight of an OS 52 Surpass, I built an inter-war RAF version, "Bertie." Bertie is 11 ozs or 300 grammes lighter than Boris but I've retained Boris in case I stuff-in Bertie whilst practicing for the event! However, the cowling on Boris needed replacing so rather than buying a cowling or modifying a food container I built my own. The front made from (6mm) ply, has similar dimensions to the firewall but I made it a few centimetres shorter. The underside is also made up of 6mm ply well ventilated with large holes, then some aluminium is bent over the structure and screwed into place. To me it looks as if I've re-engined the model with a Hispano Suiza! It's the first cowling I've ever built and I'm quite pleased with it. PS. The wing on the RAF version is not off centre but the yellow covering on the centre section is. I tend to get a bit impatient at the end of a build! I have subsequently added a little Solartex triangle to make the mistake look less obvious. Both models fly well and I'm off to La Coupe later in the week! Edited By David Davis on 01/09/2019 07:23:43 Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted September 1, 2019 Author Share Posted September 1, 2019 Put the gear in a Yak 54 I bought at the Nats for £5. Bit tatty, but good enough for a hack, and had loads of spare servos, motor and esc to use up, might as well. Tactic 6ch radio. Quote Link to comment Share on other sites More sharing options...
Erfolg Posted September 2, 2019 Share Posted September 2, 2019 I am almost there, as with so much, not quite yet. I am hoping it will fly this year. Quote Link to comment Share on other sites More sharing options...
