Martian Posted May 8, 2018 Share Posted May 8, 2018 my recently completed Spitfire Quote Link to comment Share on other sites More sharing options...
Max Z Posted May 16, 2018 Share Posted May 16, 2018 Radio-assist free flight model for an upcoming "Dutch Old Warden" event: It is a 150% version of Walter Musciano's PeeWee Pal from the '60s, suitably adapted to RC and sporting some design alterations of my preference. Quote Link to comment Share on other sites More sharing options...
martin collins 1 Posted May 16, 2018 Share Posted May 16, 2018 Very nice, looks nicely finished and very unusual............. Quote Link to comment Share on other sites More sharing options...
Chris Barlow Posted May 16, 2018 Share Posted May 16, 2018 Finally the successful maiden of my Vic Smeed Popsie bought at the Deanwater swapmeet. Built as a 3 channel RC model the first attempt to fly was with the supplied geared, brushed motor on a 2S LiPo which was woefully under powered. 2nd attempt was with 3S which had more power but burnt the brushed motor out on the take off run! Despite wanting to keep the old geared unit I succumbed and fitted a brushless motor, mounted to a 20mm motor box glued to the firewall. 3rd maiden attempt tonight was interesting. 9mph wing and quite tail heavy made for some erratic flying but ended with a safe landing. A chunk of lead in the nose and attempt No 4 was much better although the wind was way too much for her and attempting to maintain control by increasing the throttle resulted in a hefty torque roll towards the ground. Landing on idle power and she was light as a feather touching down. Another 2 more successful, although untidy flights in the wind and I decided to put her away and save her for some calm summer evening flying. Looking forward to flying her on the trims and just sitting back, watching her go. Quote Link to comment Share on other sites More sharing options...
Old Geezer Posted May 17, 2018 Share Posted May 17, 2018 All my pictures are taken with an iPad or an iPhone, stored on them (both) and iCloud. How can I convert these to the jpg format that you require for downloading onto the site? Thanks - Gurth. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted May 17, 2018 Share Posted May 17, 2018 They will upload fine as they are. All of mine are taken using my iPhone. Quote Link to comment Share on other sites More sharing options...
Old Geezer Posted May 18, 2018 Share Posted May 18, 2018 Thanks Ron - but I'm completely ignorant as to how I go about uploading - and any results from a Google search are pretty unhelpful as they all seem to assume a lot of basic knowledge. I really need a step1, step 2, step 3 / join part a to part b type instructions - don't need to know how it works - just how to do it! Any help of that sort will be muchly appreciated. Cheers Ron - Gurth. Quote Link to comment Share on other sites More sharing options...
onetenor Posted May 18, 2018 Share Posted May 18, 2018 Re the St 3250 not running Check or replace the plug and clean out the carb jet holes etc. and make sure batteries are charged and connections are good. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted May 18, 2018 Share Posted May 18, 2018 @ Old Geezer - have you looked at this thread **LINK** Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted May 18, 2018 Share Posted May 18, 2018 I posted these in the ‘Powered by Laser’ thread, should have put them here as well, a Great Planes U Can Do powered by a Laser 80: Quote Link to comment Share on other sites More sharing options...
Martyn K Posted May 18, 2018 Share Posted May 18, 2018 Posted by Martian on 08/05/2018 20:18:22: my recently completed Spitfire That's nice Martian. How big and is it a kit, artf. plan and how big? Quote Link to comment Share on other sites More sharing options...
Nigel R Posted May 18, 2018 Share Posted May 18, 2018 Martyn Martian's Spit is (I would guess) a Warbird Replicas: http://www.modelflying.co.uk/forums/postings.asp?th=132160 Quote Link to comment Share on other sites More sharing options...
Old Geezer Posted May 18, 2018 Share Posted May 18, 2018 Precisely what I was after Ron - many thanks. Gurth. Quote Link to comment Share on other sites More sharing options...
Manish Chandrayan Posted May 18, 2018 Share Posted May 18, 2018 Ron, is that a 40 or 60 U can do ? Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted May 18, 2018 Share Posted May 18, 2018 Hi Manish, here are the specs: Wingspan 65 in (1650 mm) Wing Area 1072 in² (69 dm² Weight 7-7.3 lb (3.18-3.35 kg) Wing Loading 15-15.9 oz/ft² (46-48 g/dm² Length 69.5 in (1765 mm) Engine Required 2-stroke .61-.91 cu in or 4-stroke .70-.91 cu in Edited By Ron Gray on 18/05/2018 13:24:45 Quote Link to comment Share on other sites More sharing options...
Manish Chandrayan Posted May 18, 2018 Share Posted May 18, 2018 Thanks RonSo that's a 60. How does it fly on the 80? I have one in box waiting to be assembled Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted May 18, 2018 Share Posted May 18, 2018 Sorry Manish, yes, it’s the 60. I’ve only had 1 flight with it and that was made shorter due to a dead stick. The engine is not running right and will need more time to resolve the issues so I’ve swapped it out for a new 80 I had sitting around and will try it out next Tuesday. So, it’s a bit early to pass a verdict on the engine but I think that it will be good but my long term plan was always to run a 100 in it. Tuesday should tell me if I need to make the change! Quote Link to comment Share on other sites More sharing options...
Manish Chandrayan Posted May 18, 2018 Share Posted May 18, 2018 Hmm, a 100 Four-stroke is what I had been contemplating, but since I do not have either a Laser 100 or a Saito 100 most probably I will install a 91 or 95 Four-stroke. Thanks for all the explanations Quote Link to comment Share on other sites More sharing options...
Martian Posted May 18, 2018 Share Posted May 18, 2018 Posted by Martyn K on 18/05/2018 09:11:28: Posted by Martian on 08/05/2018 20:18:22: my recently completed Spitfire That's nice Martian. How big and is it a kit, artf. plan and how big? Martyn it is indeed a Warbirds Replica Quote Link to comment Share on other sites More sharing options...
martin collins 1 Posted May 20, 2018 Share Posted May 20, 2018 Here is my Jamara Gee Bee, ready to go and hopefully will be in the air by the end of this week, bought at a bring and buy with just the motor in it, i am sure it hasn`t been flown before..............Wish me luck! Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted May 21, 2018 Share Posted May 21, 2018 Finished my "The Ohmen" electric aerobatic design. Test flown yesterday 47" span, weight 2 lbs 10 oz. Doese everything in the book and will not bigte, just release the contgrols and it is back to straight flight Aerobats happily on half throttle, only uses 2200 Mah 3 cell batteries Stuart PIckett who flies my models for the camera was doing low level inverted within a few minutes of taking over. He loves it. Quote Link to comment Share on other sites More sharing options...
Tim Flyer Posted May 21, 2018 Share Posted May 21, 2018 Here is my Warbird Replicas LA7 I started last September!its powered by a laser 80 Edited By Timothy Harris 1 on 21/05/2018 19:50:58 Quote Link to comment Share on other sites More sharing options...
PeterF Posted May 24, 2018 Share Posted May 24, 2018 Here is something completely different from me after I finished my Tiger Moth. I have had this for about 15 motnhs, did some work in Autumn 2017 but then it sat idle until now. It is the Blackhorse Mig 29 and is a larger sized ARTF EDF based around 2 x 90mm high output EDF fans. The model is 1.45m wingspan and 2.0m long and weighs about 8kg (17.5lbs) in flying condition.Mine runs off 4 packs of 4S 5,000mAh battery packs in an 8S, 10,000mAh configuration with just under 100Amps per fan giving just shy of 6kW in total. Not yet flown, but ground run, the fans are the newer higher blade count type and sound very good. Quote Link to comment Share on other sites More sharing options...
Manish Chandrayan Posted May 24, 2018 Share Posted May 24, 2018 Fantastic looking MiG 29 Peter. Quote Link to comment Share on other sites More sharing options...
Dave Cunnington Posted May 24, 2018 Share Posted May 24, 2018 Does a resurrection count as new ? I salvaged a stripped damaged Flair Cub fuse/tail, have mated an old Thunder Tiger Trainer wing to it, and fitted an OS Max 40FP PS I'm still looking for another Flair Cub wing for another project if anyone has one to dispose of .... Quote Link to comment Share on other sites More sharing options...
