denis parkinson Posted April 11, 2018 Share Posted April 11, 2018 A little Hobbyking Fokker DR1 that I finished this morning..A bit fiddly and the instructions leave a lot to be desired, but it was fun to build..I just need to find a wooden prop to replace the out of place plastic one. Edited By denis parkinson on 11/04/2018 10:30:34 Quote Link to comment Share on other sites More sharing options...
Chris Barlow Posted April 14, 2018 Share Posted April 14, 2018 Bought for £40 & fitted with some new servos and a lightly used Irvine 53. Seagull Ultimate .46 Maidened today. Very sensitive and elevators not in tune with each other. second flight much better but still needs the elevators matching better. Very happy with it. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted April 15, 2018 Share Posted April 15, 2018 A bit of real nostalgia. My first Veron Deacon was build and flown in Aden in 1961. Last seen going up in a massive thermal Just finished my new, electric R/C version in time for the first perfect day of the years. I spent ages just floating around in lift and even the first landing was perfection with never a bounce. Photos by fellow club member Michael Morris Edited By Peter Miller on 15/04/2018 08:31:47 Quote Link to comment Share on other sites More sharing options...
cymaz Posted April 15, 2018 Share Posted April 15, 2018 Finally got my grubby little mitts on it.... Will need a really good look over and check....will post more here Quote Link to comment Share on other sites More sharing options...
Giuseppe Saroli Posted April 16, 2018 Share Posted April 16, 2018 Playboy Senior os 26fs probably the best all timer ever My Savage Boobber asp 160 twin now with a pilot Savage trainer with asp 30 fs Quote Link to comment Share on other sites More sharing options...
trebor Posted April 16, 2018 Share Posted April 16, 2018 I like the framework, whats it made from ? Quote Link to comment Share on other sites More sharing options...
Giuseppe Saroli Posted April 16, 2018 Share Posted April 16, 2018 Thanks Trevor, is all carbon tube 7mm for the Savage Bobber and 4mm for the Savage Trainer using JB Weld You can see the building blog on here by typing Savage Bobber on the search for. Quote Link to comment Share on other sites More sharing options...
Keith Berriman Posted April 16, 2018 Share Posted April 16, 2018 I made a maiden flight with this on Saturday, Very lively on the ground will have to drop the prop size. Great glide in so now I will have to find/make/build a cowl Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted April 26, 2018 Author Share Posted April 26, 2018 Bought 3 x Venus's and a HK Mini Sonic. all cheap. also the 3 Venus's came with loads of props, other esc's and motors and two of the Venus are BNF, the third just needs a motor/rx/battery to fly. Edited By Paul Marsh on 26/04/2018 18:46:52 Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted April 26, 2018 Author Share Posted April 26, 2018 Posted by RC Plane Flyer on 16/04/2018 18:47:06: I made a maiden flight with this on Saturday, Very lively on the ground will have to drop the prop size. Great glide in so now I will have to find/make/build a cowl Getting the Cof G is going to be tricky, with that short nose and a light motor in the front. Are you sure it is not too tail heavy? You must need about a KG of lead to balance it... But you said it did glide, though... Edited By Paul Marsh on 26/04/2018 18:55:10 Quote Link to comment Share on other sites More sharing options...
Peter Christy Posted April 26, 2018 Share Posted April 26, 2018 Frog Jackdaw - one time rival to the Super 60, but more suited to multi-channel control! Power is an ASP30 4-stroke. Radio gear is FrSky. It will eventually be flown on a "giga-ised" Grundig "reed" outfit (non-proportional), but I'm still building that, so test flights will probably use my Taranis. Hope to test on Saturday - weather permitting! -- Pete Quote Link to comment Share on other sites More sharing options...
Keith Berriman Posted April 26, 2018 Share Posted April 26, 2018 Hi Paul M yes the Spacewalker looks out of balance with short nose but the balance is as the book says and it does glide in smoothly. Lively on the ground was partially caused by the long grass at our strip and small wheels, the grass has been cut now and a second test flight should see better ground handling Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted April 28, 2018 Author Share Posted April 28, 2018 Mini Sonic. Quote Link to comment Share on other sites More sharing options...
Chuck Plains Posted April 29, 2018 Share Posted April 29, 2018 New and old models. New one in front. These are 2.5 and 1.5 mtr span. Pod and boom obviously. Oh yeah, and as some will note, the wing is from a Hifly Precedent. (Precedent HiFly?) And the reason I'm still calling the 1.5 new is that I haven't had a flight with it yet, a few "chucks"yes, but then it's on the ground a few seconds later. I've yet to meet other fliers when I've had it with me but haven't gone up to fly for nearly a year anyway. But it doesn't seem to want to fly, in my opinion, so hopefully I'll find someone, one of these days, who knows more about 2 channel gliders who might give me some pointers. The only thing I can think of right now is that maybe I could shorten the tail boom, but to me anyway, it looks ok. Edited By Chuck Plains on 29/04/2018 14:46:14 Edited By Chuck Plains on 29/04/2018 14:47:26 Quote Link to comment Share on other sites More sharing options...
Andy Horsman Posted April 29, 2018 Share Posted April 29, 2018 How much dihedral does the problematic model have? It'll need quite a bit to turn well without ailerons Quote Link to comment Share on other sites More sharing options...
Nigel R Posted May 3, 2018 Share Posted May 3, 2018 A Chilli Wind! Gift from my dad, who has stopped flying it (although he is still flying a Rival, by the same designer). "Maiden" today in the sunshine. Flies lovely. Take off weight, 4.75lb. It's electric, juice supplied by 4S 5000mAh lipo, via a 60A ESC to a 3548 900kv motor with APC 11x8. About 800W. Did two 8 min flights today, and used 50% of a charge on each flight. Needs a few tweaks to control throws and sidethrust. Internals, the usual stuff, standard size gear, Spekky RX, lipos on a ply tray, ESC tucked behind the lipos. Air in via scoop under prop, air out via hole behind wing. 1 Quote Link to comment Share on other sites More sharing options...
PeterF Posted May 3, 2018 Share Posted May 3, 2018 For those of you who have not followed my Tiger Moth Build log, here it is after 3½ years since I first started and closer to 4 years since I bought the kit. It is the Falcon Models kit, which is now no longer available. The kit is one of the closest to scale kits for the Moth and a lot of the functional details mimic the full scale quite closely, for example, the wing attachment method and absolute requirement for flying wires. I have added a lot of scale detail onto the some bought as parts, some hand built. During the build, I swapped over to all electric powered flight, so this started out as Laser 150 powered and is now powered by an electric motor drawing some 1500W. More info can be found on the thread Peterf's 1/4 scale Falcon Models Tiger Moth. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted May 3, 2018 Share Posted May 3, 2018 Beautiful Peter. Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted May 3, 2018 Share Posted May 3, 2018 ... yes Peter, indeed... absolutely gorgeous. Cheers Chris Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted May 3, 2018 Share Posted May 3, 2018 Superb work. Quote Link to comment Share on other sites More sharing options...
KiwiKid Posted May 4, 2018 Share Posted May 4, 2018 Have really been enjoying your build thread Peter, particularly as I have a two thirds built Tiggy on the go. Your problem solving and scale building has been inspirational - totally amazing project. You do realise that there is only one job left now - making it fly. Good luck and don't forget the vid Quote Link to comment Share on other sites More sharing options...
Ace Posted May 4, 2018 Share Posted May 4, 2018 Fascinating to follow to a superb end result Just need to see it flying. Quote Link to comment Share on other sites More sharing options...
Russell Hawkes 1 Posted May 4, 2018 Share Posted May 4, 2018 A very different kettle of fish. The Phoenix Models Stage 2A Mk2 slope soarer kit. After five months in the workshop it's ready to go. All-up-weight turned out to be 10% more than suggested, possibly because of the two-piece wing adaptation and Solartex covering. Quote Link to comment Share on other sites More sharing options...
KiwiKid Posted May 5, 2018 Share Posted May 5, 2018 I like that Russell, very sleak design - similar to some of the '80s slopers. Don't worry about the weight, it will just go faster. You do realise that when flying such a model it is traditional to wear the appropriate period dress I am not sure the world needs another Vulcan, but we have one here. It's a semi scale slope design I built from plans and converted to a park flyer to gain a bit more stick time. It has a 50% thinned wing and slim vertical stabilizer to reduce drag for sloping. I have fitted a folding prop so she should still do a passable job as a slope soarer. I flew her for a couple of months nekkid and she has just come out of the paint shop and done a couple of remaiden flights which went well. Edited By KiwiKid on 05/05/2018 02:20:17 Quote Link to comment Share on other sites More sharing options...
Mark Kettle 1 Posted May 5, 2018 Share Posted May 5, 2018 Nice Kiwikid, is the Vulcan the Benson plan one? Quote Link to comment Share on other sites More sharing options...
