Electric Cars.
Cuban8
8 hours ago, Erfolg said:
Now that is a really interesting video.
The process does seem pretty time, procedure, equipment and skill/knowledge driven. In other word it will come at a cost, the question then become how much.
I am not knocking what was done, it helps putting into context, what is possible, a problem that can affect a battery pack.
Many years ago I saw a rolling chassis of a Model s at a Knutsford show room, next door to a Supercar Sales outlet. The car seemed more in keeping with Kit Car or a Traditional build, being a ladder chassis (the battery was inserted between the rails), with body work mounted on top. I wonder are the established car producers using unitary/monocoque type shells (being stiffer normally).
I suspect that servicing costs being higher than originally suggested as a combination of equipment and trained people. Will they come down with time, or now established, facing resistance to reduction, to maintain income similar to IC?
Yes it's facinating - 7000 Vape batteries ! I understand that some manufacturers prefer lots of little 'uns and others go for fewer but larger cells, I believe the BMW Mini follows the second method.
Third party specialist repairers will gradually gain a foothold and give the manufacturers' main dealers a run for their money. As with IC, very many TP specialists may well begin to offer a superior service to customers over the main dealers, both in terms of quality and pricing. Not sure if manufacturers are permitted to withhold specialist 'intellectual property' such as technical literature, software etc from third parties - independant garages seem to manage perfectly well with new tech, but not ever being in the motor trade I don't know how things work between them and the main dealers. Lots of very clever and resourceful people out there who can get around most things. I had the instrument cluster in my Mondeo refurbished by a third party specialist who did a superb job repairing it compared to the main dealers solution of a replacement that came to four times the cost of the repair. £240 compared to near a grand from Ford.
Should you ever need a similar service I can recommend these folks https://www.actronics.co.uk/contact
Only as a satisfied customer, no other connections. They don't deal directly with the public but the device to be repaired is removed by one of their panel of nationwide garage partners and couriered to them. Local garage charged me fifty quid to remove/courier/replace the cluster. very reasonable.
Edited by Cuban8
53 minutes ago, Erfolg said:
With IC it will be about regenerative devices, emissions etc.
The electronics also control, the fuel injection, ignition, temperatures, catalytic converters, particulate filters etc etc and they log any faults, so the "mechanic" can plug it in and see if the car has developed any faults. Big problem on many modern diesels is the EGR valves getting clogged up if they are only driven on short journeys. My ICE car has already been in for an EGR cooler safety recall, apparently they could leak and cause a fire in extreme cases.
Years ago before all these fancy electronics a workmate had a Lancia Beta, the indicators had a mind of their own, she took it back to the dealer several times and eventually they just shrugged their shoulders and said we don't know what the problem is............................
Well toyota been holding off on producing electric cars due to the fact thay can see the failings of current battrey tech, and are betting on ammonia power engines.  no carbon in ammonia  so no carbon emissions.
it's the future! or just one part of multiple solutions of getting energy with out carbon emissions
3 hours ago, MattyB said:
Technically viable? Maybe, but with  no other company doing it and Nio have crippling year on year losses, overall long term viability is a long way off being proved IMO…
https://www.cnbc.com/amp/2023/08/29/nio-earnings-q2-2023.html
If no other company does it and adopts their “standard” then my guess is that battery swapping for cars will not be viable in the future.
It is by no means new this battery swapping tech either. As this gently amusing 20 minutes of EV history shows…
Fully Charged - Early ev
enjoy
idd
BZ4X?
Or https://newsroom.toyota.eu/toyotas-advanced-battery-technology-roadmap/
Also interesting article in the Telegraph on Goldman Sachs review of BEV battery developments, https://www.telegraph.co.uk/business/2023/10/10/world-ev-battery-revolution-through-eyes-goldman-sachs/, basically the technology is developing at a rapid rate, improvements not only in battery tech but also lithium refining will see energy density increase while charging times and costs will tumble. Bit annoying that one of the new break throughs, developed at Imperial College, first factory is being built in South Korea.
All I can see is a lot of uptalk and marketing, but of course time will tell.  What gets me is this tunnel vision type approach to this carbon problem and the finite fossel fuel dependency, we need to have a multisolution approach and vision (we can't have all our eggs in one basket?) I do believe Toyota is taking this approach
I’ve had over 20 years working in the automotive industry.  It’s over a decade since it became obvious to me that a 100% switch to EVs was inevitable. It is in fact the opposite of putting our eggs in one basket. If you build an ICE car it is ICE powered for its entire life. If you build an EV it’s powered by whatever powers the grid - so it can get lower carbon over time as the grid shifts more to renewables. And when we start getting intelligent connections between these cars and the grid (so at times of peak demand the grid can draw power from the car batteries for a short period to cope with a demand surge) the cars actually help the grid rather than being the huge burden they might first appear. When every home has a big battery parked on the drive connected to the grid we no longer need gas turbine power stations sat at idle ready for power surges as we all turn on our kettles in the ad break…
There is a few flaws in that the grid is nowhere near renewable capable it is going to take a least 50 years and trillions invested. The cars acting like 'grid savers' is a nice idea but it's no good if you battery is not full when you need to get somewhere, especially in a sudden emergency. the best way to overcome the grid demand is to build 80,90% or more off grid house all very doable with tech as it is now.
Also every one is ignoring the eviromental distruction and carbon  produced by making current tech batteries. these batteries are  nowhere near the energy density require to power lorries and agricultural machinery. For city puttering around shopping current electric tech is ok
Still we need a multi fuel/power approach .
I totally agree Flight 1, the various ideas such as using car batteries to re-enforce the grid, is somewhat optimistic at the practical level.
The issues are real, for the committed carbon net zero, is the cost, the energy losses, from transmission of the grid.  the intermittency, With respect to the wind turbines and the real output capability of the machines (the realistic power generation, rather than max). These are the elephants in the room. That is generally why the typical gas, coal station would be built close to the conurbation's, rather in out of the way places.
No concerns seem to be voiced about the carbon releases from cement production, water consumption, nor the steel, copper and aluminium production or recycling.
I was recently disappointingly surprised to read, that some wind turbine blades are already being decommissioned, that solar panels will not (at present) generate more energy than was used to manufacture them, that in the UK it will take +100 years to pay for themselves, at the current generation earnings. I must admit, this bit does not fit with the numbers of commercial solar farms.
I do find it frustrating to work out the true costings due to the subsidies and penalties surrounding these issues. Very occasionally we do read about some of the true costs, although not often.
As for electric cars, we will see them becoming dominant, who will be able to afford them, again, a crystal ball will be needed, particularly reassuring predictions never seem to arrive. I do not worry though, as I remember that "Nuclear Power" will be so cheap and efficient, we will not meter it
cently
Erflog where are you getting that info on solar panels from, the articles I have read eg https://www.theecoexperts.co.uk/solar-panels/how-eco-friendly-are-they suggest 3 years before they are carbon neutral.
Don't forget that the development, extraction, transportation, refining and distribution of fossil fuels also have significant emissions. Old coal mines are estimated to make up around 12% of methane emissions and I have worked with US based companies that see nothing wrong with installing a cold vent (ie unburnt methane) on small production facilities rather than collect deal with low pressure gas.
Edited by Frank Skilbeck
Some good news reported by Zap Map is that we have now hit 50,000 public charging devices!
Zap Map News - 50000 UK Public Charge Points
Most importantly the rate at which devices are coming online is increasing sharply, as quoted from the article:
"Indeed, the timing of the milestone also demonstrates the acceleration in the rate of charge point installation over recent years. October’s 50,000 charge point milestone follows hot on the heels of the 40,000 mark, which the UK surpassed in February 2023. In this case, the milestone installation was part of the GeniePoint network, at Morrisons Southport.
Looking back further, the UK hit 30,000 charging devices in February 2022 (bp pulse, Botany Bay), which followed the 20,000 mark in September 2020 (Pod Point, Tesco Superstore Scarborough). The 10,000 charging devices milestone came in August 2018, with the installation of an InstaVolt device at Meadowfield Filling Station."
There is more to be done of course, there are still quite a few charging deserts out there, but with the number of home charge points now estimated at close to 1 million things are improving all the time. There are a lot more stats about charging infrastructure on the Zap Map website for those interested.
cheers
idd
cheers
idd
Are they all powered by wind and solar?
