Futaba Receivers - any alternatives ?
Posted by Tom Sharp 2 on 02/10/2018 11:46:19:
Buying Futaba and then using cheap brand receivers, that's like buying a Rolls Royce and fitting Ford Escort seats.
Complete nonsense. The FrSky multi-protocol RXs are hugely well proven in the field; if the buyer follows the instructions for installation and binding and range check as normal there will be no issues. Remember this is digital equipment; it's the software that defines the performance more than anything, so if it passes the first range check there is no reason to think it would not be as reliable as an OEM RX for the lifetime of the equipment.
Edited By MattyB on 02/10/2018 11:55:56
Martin
You have raised an issue that has troubled me for some time, particularly with respect to Futaba.
The EU is now well recognized as a protectionist market, that masquerades as free market. Where outsiders have multiple hoops to jump through, legislation slanted to facilitate there own in EU producers. Where some standards are about making it near to impossible for some to export to the EU, masquerading as maintaining standards or even health related legislation.
It seems that changes to firmware often as a consequence of changes by the EU regulators, are used by some manufacturers as a means to undermine and limit competition. In a truly free market, competition would be encouraged, and practices which limit competition would not be permitted.
I did understand that some of my older Fasst receivers would not work reliably with the later upgrades, to the Tx if installed.
Posted by Erfolg on 02/10/2018 19:50:48:
Martin
Party political broadcast, on behalf of ?
I use some Frsky Fasst Rx also cymaz, every bit as good as the Futaba units, at a fraction of the price. I have just resisted the temptation to undertake the firmware upgrades. I have been lead to believe that some who have had issues with both the Futaba and Frsky Rxs.
John, not meant to be political, beyond stating how the EU operates.
Posted by PatMc on 02/10/2018 23:06:35:
Posted by Erfolg on 02/10/2018 20:25:29:
No, you're stating how you think the EU works. sad
Completely agree, the Frsky FASST debacle had nothing to do with EU standards but a manufacturer not paying attention to changes in standards. Bit like saying that EU emission standards on cars stifle competition.
Are you really sure that the transmitting changes were due to the manufacturer getting their original product specification wrong. If so would not the CE approval process picked up the fact? I understood that the EU changed the regulations, which then required the manufacturers to change their transmission protocol if possible or withdraw the product.
If on the other hand you are referring to Fasst as opposed to the other Futaba current systems. Yep, that is all a self inflicted debacle.
Futaba were forced to change FASST because it did not comply with the EU regs that were updated in Jan 2015. They released a very late firmware update in Dec 2014 in order that they could continue to sell FASST TXs like the 14SG and 18MZ, though some (like the 8FG) had to be pulled, presumably because they had not been designed to be user updateable. At that point many of the reverse engineered FASST compatibles from FrSky, Corona etc would not work with an updated FASST TX, but FrSky released updated firmware for their FASST compatibles in January that addressed this problem. There is lots of detail in this thread I started on RCGroups if you want to read more about it.
PS - FrSky actually made more of a mess of updating their own protocol to be compliant (it which was revised twice because the first ETSI EN 300 328 v1.8.1 compatible version demonstrated reduced range) that they did with the FASST compatibles, which had their software updated in a few weeks. Spektrum orphaned DSM2 completely; they did not seek to modify the protocol (they already had the compliant DSMX in the marketplace), DSM2 RXs cannot be updated to DSMX and they no longer sell DSM2 RXs or TXs in the EU. Why am I telling you this? Because it shows that blindly stating "use the OEM RXs and you'll never have a problem" can't be true; there are no guarantees for the future of your gear in the situation that regulations change.
Edited By MattyB on 03/10/2018 14:36:23
