Ron Gray Posted January 21, 2024 Author Share Posted January 21, 2024 Chapter 17 - the wing bandage, nice and short vid this time. 3 1 Quote Link to comment Share on other sites More sharing options...
Jonathan S Posted January 22, 2024 Share Posted January 22, 2024 Ron, What size esc are you planning on using? Thanks Jon Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted January 22, 2024 Author Share Posted January 22, 2024 It's probably going to be one I have in my 'spares' drawer and hopefully I have one rated at 60a. 2 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted January 22, 2024 Author Share Posted January 22, 2024 Chapter 18 - wing fixings and root fillets (done differently than I usually do them - a technique that even ham fisted builders can use!) 6 Quote Link to comment Share on other sites More sharing options...
Jonathan S Posted January 23, 2024 Share Posted January 23, 2024 Ron, Fantastic videos - really loving the videos. Thanks for the hint on the ESC amps. I have one on its way this week. Where did you get your 3d printed wing shapers from. I was looking at thingyverse but could not find one. Could you share either a STL or just a couple of photos / dimensions so I can re-create them in Fusion. Thanks Jon Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted January 23, 2024 Author Share Posted January 23, 2024 I’ll dig out the STLs Jon 2 Quote Link to comment Share on other sites More sharing options...
Murat Kece 1 Posted January 23, 2024 Share Posted January 23, 2024 (edited) Here are some from https://www.thingiverse.com/ (You can search them with the file names): Leading Edge Sander -Clip.stl Leading Edge Sander -Body.stl Divinity_II_48_Leading_Edge_Sanding_Block.stl 9andhalfinchradiusblock.STL BT50_Sanding_Block.stl BT-20_Sanding_Block.stl 76mm_Sanding_Block.stl ST20_Sanding_Block.stl BT80_Sanding_Block.stl BT60_Sanding_Block.stl 0.63_Inch_Radius_Block_Mk_1.STL Edited January 23, 2024 by Murat Kece 1 1 Quote Link to comment Share on other sites More sharing options...
LHR Dave Posted January 24, 2024 Share Posted January 24, 2024 HI Ron Sorry if you have already mentioned this, what is the exact type of Gorilla glue you are using to join the foam wings.? I have always been a traditional epoxy resin and aliphatic glues user. What other building uses are the Gorilla glues good for ? I see there is a different bottle on your bench. Regards Dave Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted January 24, 2024 Author Share Posted January 24, 2024 (edited) Hi Dave I use 3 types of Gorilla glue - Brown (expanding/foaming), Clear and White (PVA): Brown - when bonding to foam (or foam to foam like wing halves) or where a joint needs a bit of filling (!!) and also sometimes for control surfaces hinges (Robarts) Clear - Depron to Depron, canopies, plastic to plastic, plastic to wood. It dries crystal clear but be warned it is very difficult to paint! White - wood to wood and for me it is the best PVA I've used! Edited January 24, 2024 by Ron Gray 1 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted January 24, 2024 Author Share Posted January 24, 2024 Chapter 19 - Servos and pushrods 3 Quote Link to comment Share on other sites More sharing options...
Graham R Posted January 24, 2024 Share Posted January 24, 2024 18 hours ago, Murat Kece 1 said: Here are some from https://www.thingiverse.com/ (You can search them with the file names): Leading Edge Sander -Clip.stl 431.14 kB · 5 downloads Leading Edge Sander -Body.stl 417.17 kB · 5 downloads Divinity_II_48_Leading_Edge_Sanding_Block.stl 1.02 MB · 3 downloads 9andhalfinchradiusblock.STL 9.65 kB · 5 downloads BT50_Sanding_Block.stl 64.34 kB · 2 downloads BT-20_Sanding_Block.stl 61.8 kB · 2 downloads 76mm_Sanding_Block.stl 76.84 kB · 1 download ST20_Sanding_Block.stl 64.54 kB · 1 download BT80_Sanding_Block.stl 80.55 kB · 3 downloads BT60_Sanding_Block.stl 76.35 kB · 1 download 0.63_Inch_Radius_Block_Mk_1.STL 22.93 kB · 3 downloads Just one of the l/e sanding blocks 22hrs 22mins and 6o metres of material. I'm sure Rons will be a lot more economical. Any chance of your stl's Ron Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted January 25, 2024 Author Share Posted January 25, 2024 Chapter 21 - Covering the fuselage (Chapter 20 has got stuck in the works of YouTube!) 5 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted January 26, 2024 Author Share Posted January 26, 2024 Chapter 20 - covering the wings and tail 4 Quote Link to comment Share on other sites More sharing options...
stu knowles Posted January 26, 2024 Share Posted January 26, 2024 On my past models I have found a slight tendency for the brown paper to lift and curl away from the cut edges around the servo bay for example. Anywhere where there isn't the overlap. I now iron a narrow strip of scrap solartex around the edges of the openings and try to wrap it around inside. The peel back has often not shown itself for a year or so, I guess it could be that the edges are more vulnerable to absorbing damp from the atmosphere? Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted January 26, 2024 Author Share Posted January 26, 2024 That is why the sealer is such an important part of the brown paper covering procedure. Using cellulose dope would be a good sealer, especially around those raw edges, as would Clearcoat (my preferred) but am conscious that newbies won't necessarily have these to hand, so a coat of PVA is what I will be using for this build. 2 Quote Link to comment Share on other sites More sharing options...
Basil Posted January 26, 2024 Share Posted January 26, 2024 3 hours ago, Ron Gray said: That is why the sealer is such an important part of the brown paper covering procedure. Using cellulose dope would be a good sealer, especially around those raw edges, as would Clearcoat (my preferred) but am conscious that newbies won't necessarily have these to hand, so a coat of PVA is what I will be using for this build. Ron, sorry to be such a pain but...... I have looked up 'Clearcote' but every thing from water based Acrylic to 2pack epoxy comes up. I am assuming that you were being specific in your reference to 'Clearcote', could you perhaps point to what sort of coating you are refering to. Sorry about this. If its just as a sealer what about water based acrylic?. Bas Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted January 26, 2024 Share Posted January 26, 2024 21 minutes ago, Basil said: Ron, sorry to be such a pain but...... I have looked up 'Clearcote' but every thing from water based Acrylic to 2pack epoxy comes up. I am assuming that you were being specific in your reference to 'Clearcote', could you perhaps point to what sort of coating you are refering to. Sorry about this. If its just as a sealer what about water based acrylic?. Bas Might have been better to look for Clearcoat, as in Ron's post. https://solarfilm.co.uk/products/solarlac-clearcoat-thinner-collection-only Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted January 26, 2024 Author Share Posted January 26, 2024 Thanks Brian you beat me to it! Note that, as I said above, I am not going to be using Clearcoat on this build as most beginners will not have access to it and it is quite difficult to get hold of (collection only). Cellulose dope would also be a great choice but it has to be used in a well ventilated space (I know that back in the day we didn’t bother about that!) so I’ve ruled that out too. So it boils down to water based products, floor varnish, EzeKote, PVA or acrylic primer/undercoat all of which are easy to get hold of and are easy to apply albeit the primer/undercoat still needs a well ventilated space. 2 Quote Link to comment Share on other sites More sharing options...
RICHARD WILLS Posted January 26, 2024 Share Posted January 26, 2024 As you say Ron . Keep it simple , use PVA . If any "flappy bits" develop , get some pva under it then iron it down . When you think about it , Solarfilm is just a covering material , coated with a heat reacting glue . Brown paper coated with PVA is the same . The main difference is that you have to create that "composite " yourself . However that does mean you can fix it if it stops working by adding more adhesive . You can also spend the money you've saved on crisps and beer ..... 2 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted January 26, 2024 Author Share Posted January 26, 2024 Yes, PVA for the flappy bits and at the moment I’m coming down in favour of the primer/undercoat as the sealer. I’m planning on doing the sealer on Sunday as we have family around tomorrow so I won’t be allowed out to play and I can’t leave Gary (Elmo) on his own with an aerosol can! 1 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted January 27, 2024 Author Share Posted January 27, 2024 Chapter 22 - Hinges and horns 4 Quote Link to comment Share on other sites More sharing options...
mightypeesh Posted January 27, 2024 Share Posted January 27, 2024 Hi Ron, great videos, thanks for the ones on covering esp 👍👍👍. Cheers, Simon Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted January 27, 2024 Author Share Posted January 27, 2024 Thanks for your kind words Simon, if anyone gets something out of these vids then it’s a result! 2 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted January 30, 2024 Author Share Posted January 30, 2024 A slight delay in getting this vid out but here is Chapter 23 0 Starting on the painting 5 Quote Link to comment Share on other sites More sharing options...
Adrian Smith 1 Posted January 31, 2024 Share Posted January 31, 2024 Lovely job there, Ron. An education for us all 😀 Quote Link to comment Share on other sites More sharing options...
