Former Member Posted August 2, 2020 Share Posted August 2, 2020 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted August 2, 2020 Share Posted August 2, 2020 It's excellent for cleaning matt finish plastic motorcycle panels. It doesn't keep rust at bay as well as ACF50 which is actually designed to resist corrosion. It's not as good as a penetrating oil as - dedicated penetrating oils! Quote Link to comment Share on other sites More sharing options...
Pete Collins Posted August 2, 2020 Share Posted August 2, 2020 Oddly enough, according to an old lady i know, it DOES cure arthritis! Or, at least, she sprays it on her knee and insists that it helps her mobility. Perhaps someone should conduct some proper scientific tests? Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted August 2, 2020 Share Posted August 2, 2020 It sorts the locks on my sheds in Winter, and degreases stuff, I accepted the Fish Oil one, that's not true then ? Quote Link to comment Share on other sites More sharing options...
Michael Barclay Posted August 2, 2020 Share Posted August 2, 2020 Posted by Pete Collins on 02/08/2020 11:06:32: Oddly enough, according to an old lady i know, it DOES cure arthritis! Or, at least, she sprays it on her knee and insists that it helps her mobility. Perhaps someone should conduct some proper scientific tests? Someone I used to sail with claimed exactly the same thing. Quote Link to comment Share on other sites More sharing options...
J D 8 Posted August 2, 2020 Share Posted August 2, 2020 I have heard it is very good for shining leaves on plastic plants and if you spray the base of your tree's it will keep the beaver's from chewing them. Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted August 2, 2020 Share Posted August 2, 2020 Be careful if spraying it on control surface linkages, not that one would normally, as it makes solarfilm sag and wrinkle. I don't know if it has that effect on all film but you don't want to find out the hard way! Quote Link to comment Share on other sites More sharing options...
Phil Green Posted August 2, 2020 Share Posted August 2, 2020 Any serious Jimi Hendrix fans will know of the British band, the Hamsters a fantastic live band, sadly retired. Throughout a gig their guitarist Slim would spray WD40 down the length of his guitar neck every three or four numbers. Didnt wipe it off, he just played it 'wet' Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted August 2, 2020 Share Posted August 2, 2020 Posted by Phil Green on 02/08/2020 12:46:26: Any serious Jimi Hendrix fans will know of the British band, the Hamsters a fantastic live band, sadly retired. Throughout a gig their guitarist Slim would spray WD40 down the length of his guitar neck every three or four numbers. Didnt wipe it off, he just played it 'wet' That was because it left a Purple Haze. Quote Link to comment Share on other sites More sharing options...
Andy Stephenson Posted August 2, 2020 Share Posted August 2, 2020 WD40, I use it all the time especially to remove Evostick and similar sticky contact adhesives. Good as a lubricant when drilling and tapping hard aluminium alloy. A. Quote Link to comment Share on other sites More sharing options...
Peter Christy Posted August 2, 2020 Share Posted August 2, 2020 "If it doesn't move when it should, use WD40. If it moves when it shouldn't, use duct tape!" Also: "Duct tape is like the Force. It has a dark side and a light side, and it binds the Universe together!" -- Pete Quote Link to comment Share on other sites More sharing options...
Andy Ellis 1 Posted August 2, 2020 Share Posted August 2, 2020 Whilst WD40 smells lovely, GT85 smells lovelier. But does work as well. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted August 2, 2020 Share Posted August 2, 2020 i'm a Serious Jimi Hendrix fan...have been for all my life(long time) I can assure you that JH used lots of different substances etc... ken anderson...ne..1..serious stuff dept. Quote Link to comment Share on other sites More sharing options...
paul d Posted August 2, 2020 Share Posted August 2, 2020 Good thread Doc, for the life of me I can't remember where Brian said about not using it on phosphoru bronze, sadly a bit late to ask him now, what magazine did write under the name of "the wizard of oz"? At the time it made sense to me to the point of never using it on bronze, oilte etc. I only ever use it to silence squeaky door hinges although I do agree about the smell. Quote Link to comment Share on other sites More sharing options...
Tosh McCaber Posted August 2, 2020 Share Posted August 2, 2020 Hmm- Read on YouTube that it removes bird poop from your car. Sprayed it on, waited a few minutes, rubbed it off. Result- bird poop still there, but nice and shiny! Quote Link to comment Share on other sites More sharing options...
Ronaldo Posted August 2, 2020 Share Posted August 2, 2020 Good for squeaky hinges {stopping the squeak that is} Frees locks, I squirt some on the key then work it into the lock. Freeing rusted nuts on bolts. Also very good as lubricant when drilling and tapping metal. Quote Link to comment Share on other sites More sharing options...
Former Member Posted August 2, 2020 Author Share Posted August 2, 2020 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted August 2, 2020 Share Posted August 2, 2020 Doc, I used to blast everything under the fairings which areas are traditionally prone to oxidation. Especially useful on Aprilia wiring! When maintenance was needed everything came apart much more easily. It was very effective for winter protection of alloy frames too as I used to ride throughout the year in days gone by. Quote Link to comment Share on other sites More sharing options...
Stuart C Posted August 2, 2020 Share Posted August 2, 2020 It knocks out fire ants. Quote Link to comment Share on other sites More sharing options...
cymaz Posted August 2, 2020 Share Posted August 2, 2020 I found THIS . I can’t vouch for the findings though Quote Link to comment Share on other sites More sharing options...
dave windymiller Posted August 6, 2020 Share Posted August 6, 2020 Re the bird muck thing, my understanding is when you wash away the muck and find the paint surface has been damaged by it, wd40 is used to soften the paint allowing it to polish easier and quicker (using t-cut or similar). I know wasps in jars dont like it from the "experiments" we did as kids! They'd rather sting themselves to death! Quote Link to comment Share on other sites More sharing options...
Geoff S Posted August 6, 2020 Share Posted August 6, 2020 I used to spray it on the magneto of my motorcycles when they wouldn't start after standing out in the rain. I think WD stand for Water Displacement. Geoff Quote Link to comment Share on other sites More sharing options...
