Brian Taylor 72" Typhoon Build
richard dalgleish
Anyone interested in a build thread?
This will be Typhoon no2 for me, the first one i lost after an engine failure 3 years ago. Pic below.
Laser 155 engine
Original BT cowl, canopy and spinner.
I salvaged the original retracts, pilot, exhaust stacks, but that was about it.
I've built a new retractable tail wheel assembly, lighter and better than the previous one.
  • Like 13
BT's advice shown on the Typhoon plan about keeping the back end as light as possible behind the CG point is so vital - and something that I took my eye off during my build of his Mk1a Spit.....been doing this long enough now so I should have known better.
Reckon I'm 2lbs over weight at 14lbs which isn't such a show stopper once up and away - the model flys perfectly well once plenty of airspeed is gained, but takeoffs and landings do need so much care and attention. I Don't expect any model of this type to fly like an Acro Wot, but it's not worth making things unnecessarily hard for yourself. The undercart takes quite a load as well.
Shaving some weight off by moving certain things forward where I can, and I also suspect that the CG given on the plan of my Spit is quite conservative. My own calculations show a possible rearward allowance of about a further 8mm back from BT's plan position and will save a worthwhile amount of nose ballast given how short the nose of the Mk1 is.
A dangerous area to be experimenting with - so I'll take great care with any rearward change in CG, although given that I found the elevator response during the twenty or so flights I've had so far with the model so far to be very benign, I reckon there's some room for adjustment and nose ballast and hence overall weight reduction.
My first Typhoon needed 2 1/2 lbs of lead to balance, all up weight was 17lbs. It still flew very well and still landed at walking pace with full flap and some power. I'm being extra careful on this build though, servos at the back of the firewall, lighter weight glass cloth and not so many coats of primer and base coats.
My Taylor Mk1a Spitfire also needed some lead, about 1lb, total weight is about 12lbs.
Interesting that your Spit came out at 12lbs - the sort of target that I was seeking but wound up a couple of pounds over. IIRC Brian Taylor quotes something like an AUW of 8lbs for his competition model - goodness knows how he managed that.
The Typhoon looks to have a nice thick wing and not too much taper - imagine a touch of washout as well, don't know, haven't seen the plan.
It is a fairly straight wing, nearly 3 inches thick at the wheel wells. There is some washout too, it makes for a good flying model.
I'll weigh the Mk1 Spit again, I've only put two flights on it so far but it flew very well.
  • Like 7
Richard, what a lovely job you've made of your Spit - very accurate  colours and detailing. It's amazing what skills within our hobby there are, yet rarely get the exposure that they deserve.
BTW, my Spit is also in the markings of Geoffrey Wellum, he of 'First Light Fame' - nowhere near as authentic as yours though.
Some work on the elevators last night, built in two halves then tack glued together for rough shaping.
I've hollowed them out as the plan shows, I'm not sure how much of a weight difference it makes though.
Will glue the halves back together tonight for a final sanding and finish off the hinging, then onto the fin and rudder.
Hi Richard,
I have the plans for the Typhoon, it's in the line to build. I could never understand Brian's logic when building tailplanes, elevators and rudders. The early plans all used solid balsa, sticking strips of paper over to simulate ribs. I always changed them to 1/16" sheet with ribs and spars, or 1/16"sheet  top and bottom on solid types.
Following your build with interest.
The Napier Saber was a beast of an engine weight 2360lbs/1070kg
Also the sister to Hawker Typhoon the RR Vulture powered 2450lbs/1111kg Hawker Tornado ( cancelled at prototype due to engine issues and need for merlin for spits,hurricanes etc).
Required short noses.
The RR Merlin weight  by comparison 1640lbs/744kg...
So models need the right amount of ballast to balance properly.
I am following with interest as I plan to start a Typhoon next. It is however the Tony Nihuis version and will be more stand off scale...
