The Gov't, CAA, BMFA & UAV legislation thread
Nigel R
Posted by leccyflyer on 18/11/2019 06:40:13:
Another example of over-thinking. If you've used a screwdriver to fit your hatch then clearly that isn't a special tool. If it's a TORX or star driver, or similar then it probably is a special tool.
Screwdrivers have been classed as 'special tools" by the CAA and are not permitted. Hatches should be removable without any tools.
Posted by Chris Berry on 18/11/2019 08:31:23:
No tools of any kind are allowed. Label can be accessed via a hatch or must be on the outside.
Do you have a reference for that?
If that is the case it would mean having to put some battery hatches retained by magnets on half a dozen models, which would be a pain.
Posted by leccyflyer on 18/11/2019 09:07:24:
No link as yet. Had feedback from the LMA AGM that I couldn't attend.
However, is a wing just a glorified hatch covering a cavity in the fuselage and by using finger tightening bolts you're not using a specialist tool?
Just a thought?
As has already been said by others, aren’t we in danger of overthinking this? My thoughts are that I will comply with the spirit of the law which may actually not be the letter of the law. In other words, my ID will be in the ‘plane but a screwdriver may be required to get to it. Personally, as long as my ID is in place then I don’t think that a prosecution would be brought to bear on the basis that it needed a screwdriver to get to it!
Posted by Chris Berry on 18/11/2019 09:16:45:
Just a thought?
I've always said that a wing is a glorified dual purpose battery hatch when asked about the lack of a hatch on the Balsacraft funfighters.
Posted by Ron Gray on 18/11/2019 09:24:52:
That would seem to be the position that a reasonable person would adopt on reading the text stating that a hatch which does not require the use of a special tool to access the number is permitted. However when some "special tool" seeks clarification of such a term then the outcome may not be what is desired.
not been cheeky to everyone---But a lot of song and dance about putting a set of numbers on a model aircraft---I believe the numbers have to be 4mm high?... probably not much bigger smaller than what i'm typing in front of me ….. fair enough the scale model lads wont be 100% happy- but I think we can all live with the fact....whether they are in the model or outside I don't think will be any big deal long term- as long as the owner can be id'd should the occasion arise which I don't think will be very often - if at all.. so back to more important things(Santa) is on his way...
ken anderson...ne..1..important things dept.
Edited By ken anderson. on 18/11/2019 09:42:53
Posted by leccyflyer on 18/11/2019 09:30:15:
From an earlier post within this topic, page 18. This is me copying the text from the previous topic which was not mine, I am quoting someone else's conversation with CAA.
I have had an email exchange with the CAA in which I asked for a definition of 'special tool'. Their response -
"... we will be updating the service with the following:
Where it is not possible to display your operator number on the outside of your drone or model aircraft, you may instead attach it on the inside- within a compartment that can easily be accessed by anyone, without the need for ANY tools or specialist equipment."
Edited By PeterF on 18/11/2019 10:13:46
This is all so unintentionally funny it would've made a great piece for the old TV series 'That's Life' that only a few of us oldies will remember.
To be more practical - in the case of a lovely competition scale model, what about having the operator number attached to a suitable part of the airframe only when flying? A small and unobtrusive clip on type widget with the regulation sticker, that can be easily removed for judging and simply attached before flying i.e clipped in position  by hand. Just check it's in place as part of preflight checks. Don't think that falls foul of any rules, but you never know.............laugh
Edited By Cuban8 on 18/11/2019 10:39:54
Posted by Cuban8 on 18/11/2019 10:35:54:
Edited By Cuban8 on 18/11/2019 10:38:09
Cuban,
see my suggestion above.
Don't see why not.
Posted by ken anderson. on 18/11/2019 09:42:19:
My issue is that when you fly a normal IC aircraft, say a WOT4 or Acrowot or Bullet type sports model that's 10 years old, well flown and oil covered. It has no hatches or canopies etc, then how long will a label last?. Its flown all year, winter and summer, is sprayed with cleaner and wiped down at the end of every session. I can't see it lasting long and will probably change every year or in a few months time.
Edited By Chris Berry on 18/11/2019 11:01:20
Posted by Chris Berry on 18/11/2019 10:47:01:
My issue is that when you fly a normal IC aircraft, say a WOT4 or Acrowot or Bullet type sports model that's 10 years old, well flown and oil covered. It has no hatches or canopies etc, then how long will a label last?. Its flown all year, winter and summer, is sprayed with cleaner and wiped down at the end of every session. I can't see it lasting long.
Apparently in Germany the number has to be on a stamped metal plate fixed to the model, that would be fuel proof.
But in reality you could always just stick the number on this type of model and replace as required, or even stamp /engrave it on the undercarriage.
