Warbirds Replicas Winter build thread.
55 minutes ago, Silver Wolf said:
What a nice looking focke ?.
My only concern is lack of strength in F2, some of which will be negated by carbon tows or carbon tissue or may laminate some thin 1mm carbon sheet. Work the weekends so some time to ponder.
IMO the VQ models fly really well (FW 190 and Aircobra, both Laser 80's) and I would rather poke the engine out one side and have the tank in the right position than mess around with dual tanks, but then again if its only a bit of hacking of F2 its not a major job and worth the effort in the long run to get the engine inverted (not my favorite tuning location, but that's just me!).
Mod F2 gets my vote + if it adds weight its the right side of the C of G so won't make much difference in the big scheme of things.
Edited by Chris Walby
OK, question for @RICHARD WILLS and @Paul Johnson 4. I have covered my spitfire wings in brown paper for a bit of dingproofness, and I read on the mustang thread that there's no need to apply thinned  non-shrinking dope if it's going to be an electric powered model. Thing is, I gently rubbed down the brown paper with some 1200 grit and it's gone a bit "fluffy". I took Paul's advice and didn't dope it before starting on the primer (white on the underside). But it still seems very "fluffy"! Tis only the first thin coat of primer being airbrushed on at the mo, so will more coverage fix it?
How do I rescue this? And advice going forward? Will doping sort out the surface such that it can be sanded smooth? Can I apply dope over this thin coat of primer? Or do I just settle for a fluffy spitfire?!
Thanks!
On 02/02/2022 at 14:48, Silver Wolf said:
Thanks for the advice chaps and the photos Jon.
Multi tanks would work, although seems to complicate what should be a rather quick & simple model.
Proposed tank is "Du-Bro 8oz"  height 49mm could go a Slec 6oz which as a height of 47mm. If tank is raised by 10mm this will put centre line of tank 5mm above centre of carb.
Had thought about putting some carbon tissue (deluxe materials) or carbon tows on bottom section of new F2.
Regards
SW
I have an 8oz radio active tank in mine and it seems much smaller than the dubro, so that is odd. I can measure the position of my tank if you like? I wouldnt be worried about cutting away the former. Mine has been fine although i think i did add another laminate round the wing dowels.
I do not recommend fitting exhaust pressure nipples. Our exhausts are not designed for it and the nipple will eventually fall out. if this happens in flight, the engine will stop. Also, if we needed muffler pressure we would fit a nipple at the factory.
Tanks should be inline with the carb and there is no work around if you want reliability. As soon as you deviate from this and start drilling holes in things, you are on your own when it comes to tech support as i can only advise on problems if the engine is installed per the instructions. If its not, all i will tell you to do is install it per the instructions as i cant troubleshoot an unknown setup.
8 hours ago, Eric Robson said:
David, did you sand the paper before painting? Richard said to give it a rub  over with an envelope then paint, If you have got the fluff after painting give it a light sanding and another coat of paint.
Yeah I kinda did give it a light sand before painting. I think I screwed up there. I will do some paint and sand back efforts and see if it sorts it...
Another thing that makes a difference is making sure you put the PVA on the matt side of the paper. I use the car masking paper from Toolstation and as it is in a roll it is easy to tell by the way it is formed. There is not a lot of difference between the two sides visually, (could be my old eyes) so when I cut a piece off I glue the curled up side.
With any paper products like this you have to understand the manufacturing process, the finish on this paper that gives it the shine is machine finish which means when going through the mill the final process is a roller running faster than the paper polishing the surface, this seals the fibres to make the surface more moisture proof as much as it can be, abrade this and you are back to fibres, you have to seal the surface first, using the same medium over has the risk of softening the previous coat thus soaking more in, you may find you will need to use more than one or two coats to eliminate the problem.
Jon
 If you could measure your tank position then that would be grand but no rush?, can just about achieve centre of tank on carb centre line. Intend to laminate F2, certainly around wing dowels.
When using tissue I always give a thinned coat of of dope or sanding sealer. I only sand very very gently if there are any raised fibres.
SW
Thanks!
David , regarding your "fluff" . unlike some of the others . I do give my brown paper a quick brush of 50% thinned (with cellulose) dope . before painting . However I have seen others skip this stage , I would think a fine sand , wipe off and then another coat of paint , will get you get back on the track .
I am thinking of producing a batch of kits based on previous demand this time of year ,
A dozen Spitfires (which haven't been available for six months) , plus a few P51s and Hurricanes .
The lack of balsa has been a real problem , and in my opinion , I don't think we will be on firm ground for quite some time .
Richard
Richard
Richard, put me down for a Spit !!!
On 22/02/2022 at 20:55, Jonathan S said:
David, did you fix the issue as I now have it on the p51
I've been down with the covid. I'm just about to start trying to tackle it again. I think that I will just have to sand back lightly and do another coat of primer. I'll pass on my results when I've made a bit more progress...
  • 3 months later...
It's been a while since I looked at my LA-7, been busy building a 98"  Sinbad (old timer glider converted to electric).
LA-7
Can anyone show how the wings are blended in with the cowl and fuselage. Thanks in advance.
Edited by Graham R
