DB Sport and Scale Auster J1 Autocrat
Danny Fenton
On 06/03/2021 at 11:57, Dwain Dibley. said:
It's not too late to redo Mate, in hindsight I should have had the join more over the upright too, but that was as per the plan. There is a ply doubler that covers this area anyway, so no worries really.
D.D.
Just spotted this one you posted a while back, you have really done well to figure this out, much of this is not on the plan!
Maybe I have just been spoilt with Brian Taylor plans.....
They do indeed sir, thank you.
What I cannot quite see is did you taper the three side stringers into the tail. If I do that would make them very thin over the last few open bays??
The other areas where it simply says "tapered" I think I understand having seen your pics DD
Remember click on the pics if you need full size/res
Hi Danny
It may not be the laser cutting, I have found on occasion that the printing of the plans is not always of the standard you would expect. Paper stretch and the quality of the printer is a factor and we do tend to assume the printed plan is gospel.!!!
Keep taking the pills?
6 minutes ago, alan p said:
Hi Danny
Thanks Alan, I know this only too well, I have been building a Brian Taylor P-51 off and on for 11 years, and the plan was really badly printed. The laser cut parts were no where near, which was the first clue. and what made me realise it was the plan was when you measured the rib outline chord it was 4mm different to the plan view of the wing. What was worse it wasn't consistent! as if the paper had slipped in the printer.
I know Brian's plans are spot on, and others had built this model with the usual Taylor accuracy. It has spoiled the model for me, and is probably why I have put it away three times now over the 11 years.
I think Boddo used that fuselage structure on a lot of his designs, Danny.
This is the tail of my Sea Stormer which has stringers running the full length of the fuselage and then tapering onto a 1/16" sheet support under the tailplane. I broke one of the stringers while planing in the taper so added a strip of balsa behind to restore the strength.
  • Like 2
On 27/02/2021 at 13:34, Danny Fenton said:
Hi David, I think that you seeing a flat screen on Jacqui's Auster is an optical illusion. I think its still curved but in three sections?
I hadn't noticed it until you pointed it out.
Even Grangers three view shows the screen as in three pieces.
Cheers
Danny
I can confirm that the front screen on Jaqui's Auster is flat .. it surprised me when I first saw it, too.
Edited by Andy Sephton 1
Thanks Nick, I sanded it too, and as suspected it is a bit weak, especially as that may be an area that will be held to retain the model. I will do as you have and add something behind.
Thanks for your support much appreciated
When offering up the side pieces it became apparaent that more "packing" pieces were needed, one specifically is marked X here and supports the ply at the back of the window. Scoured the plan but no mention. Anyway simple matter to add some stock and sand to shape.
I have included pictures here to just act as a guide should anybody take this model on and need a bit of a hint as to what goes where.
Not sure if it is visible, but packing pieces are behind the upper and middle stringers where they are unsupported as Nick pointed out. The lower stringer is unsupported over a very short distance so doesn't need any help
X is the additional part omitted, but it is obvious there is no support for the ply otherwise.
Adding the ply sides/window surrounds, took almost all my clamps!
Cheers
Danny
Edited by Danny Fenton
  • Like 2
The sides have come out well, no gaps and nice and flat.
Next was to put some shape into the area behind the firewall. The panels are basically flat I believe, so careful sanding has been done to replicate this.
A quick trial of the cowl looks pretty good. The cowl is cracked, and in two parts, so will need joining and repairing. It flexes like polyester, but the scratch and sniff has been inconclusive.
Cheers
Danny
Fitted the two bulkheads (instrument panel) and combing shaper. I accurately measured from the plan to position the mid bulkhead and made a small jig to get the panel angle as per the plan. However when the mid bulkhead was trued using a straight edge along the top of the cowl, it was clear it would need to go further to the rear. I positioned it so there was a straight line from the top of the cowl through the intermediary bulkhead to the panel.
Moved on to the engine mounts, these were again cut very accurately, but a trail fit showed a slight amount of fettling was needed to get everything to fit snugly. Clamps were used profusely ?
Cheers
Okay as I have already confessed to being an electric flyer and not really do the IC thing. How would you seasoned IC peeps deal with the engine mounting rails being too narrow for the chosen engine?  In the distant past I recall paxolin or aluminium adaptor plates, but the centre line of the engine is the rail face, so that wont work.
I could epoxy additional wood to the insides of the rails to fill the void, as the holes are close?
Suggestions??
Cheers
Danny
I had a 1/5 share for a while in a 1946 Auster AOP6, kept in its original squadron markings, silver with yellow bands. I managed to ground-loop it at Tatenhill once, no damage fortunately! Very smooth and stable plane to fly. Always fancied making a model of it. I was told once that the famous Auster test-pilot, Ranald Porteous, said that nobody ever managed to do three consecutive good landings in an Auster. I tended to agree.
Sorry Danny, I'm such a dyed-in-the-wool engine man that I nearly burned my house down while charging a LiPo on St Valetine's Day, but I don't understand the your phrase, "...the centre line of the engine is the rail face."
I don't think that adding plywood to the inside of the engine bearers will work. Once you've drilled the mounting holes I think that the plywood will start to seperate from the original bearers but I'm willing to be proved wrong.
I would probably mount the engine on a paxolin or metal plate even if it means that the thrustline is slightly altered. I doubt that you'd notice much difference with a model like the Auster, it's not a pattern ship after all. You could always shave a bit off the surface of the engine bearer if you're worried about it.
Just my three pennorth, not that I'm an expert in aerodynamics of course.
Thanks for all the advice chaps, but i cannot see a way of accurately routing out the bearers to allow for a plate to be let in.
The engine bolt holes will be in the main bearers just a bit close to the edge.
I will go with Johns suggestion as its fairly straightforward, and should be adequate.
You can all say told you so if the engine falls out!
As a scale modeller i would be very unhappy to have the prop centre in the wrong place!
Cheers
Danny
