RX wire 'Aerials'
Basil
The idea that twin aerials are fitted at 90° to each other Bas, is that both are not in a weak position at the same time.
The strongest reception is at 90° to the wire
And the weakest reception is end on to the wire although some signal can be detected.
A set up of parallel aerials will act as a single aerial with fades and drop outs at that time when the aerials are end on to your tranny.
Twin aerials really do double reliability of set at 90°.
As Bob says, while I was typing.
Edited by Denis Watkins
The transmitter aerial should be parallel and not collinear with at least one of the receiver's antenna(s). That means for most the aerials should be positioned 90 degrees apart (or thereabouts, the exact angle isn't critical). Of course that's not the end of it - should both aerials be aligned along the length the fuselage, one vertical and one along the fuselage, or both vertical? The answer depends on the model type; if it spends most of its time flying horizontally place both along the line of the fuselage and have my TX aerial horizontal; if it's an aerobatic type I go with one up, one along (and again the TX aerial horizontal).
 As Don says above it is the last bit of bare wire at the end that's the aerial, the rest can be curved to make them be as near as possible 90 degrees to each other.
   Leccyflyer got there first
Edited by J D 8
more info
2 hours ago, leccyflyer said:
Bear in mind that the aerials should be at 90 degrees to each other, but that doesn't mean that has to bear any relationship to the datum on the aeroplane.
That is true, but if you have both along the fuselage length then the TX aerial should be in the same plane i.e. horizontal. Similarly if both aerials are pointing upwards (I.e if you looked from the front you could see them in a V shape) then the Tx aerial should be vertical.
My TX aerial is horizontal, as in the manual.  That definitely is not varied for each model. My aeroplanes tend to adopt different orientations when they are in flight, probably averaging towards the horizontal during the course of the flight. Typically I'd have one rx aerial along the fuselage length and the other aerial up or down in a vertical plane.
Whats been said , that its only the bare /silvery bit thats the aerial put things in a whole new light. I have been under the impression that it as all of the wire, insulation and all.
There are 4 plus inches in to total, difficult to find the room for that at 90degs. Now I only need say about one  inch at 90degs oppossed makes things a whole lot more easy.
One more point what about proximatey to servos etc.I to have been trying tubes to guide/support the aerial, plastic straws seem good.
Many thanks to all those that took the time to reply.THANKS.
Bas
  • Like 2
Whilst it is true that it is only the end of the 4" 'antenna' that it the active part it is still important to get that active part away from the electronics of the receiver and, in fact, everything else as well -  as much as possible -  so sticking it out of the fuz isn't the worst idea but it is vulnerable to damage there.
My solution was to knock up a design for my 3D printer which ensures my aerials are always in ideal orientation to each other. A small cable tie holds the feeder cables and it can be screwed or fixed to the fuselage with velcro.
The only drawback is if you are mounting aerials in something which has a large amount of signal blanking - big engine, large motor, areas of carbon fibre etc. then rather than this method it’s better to use the length of the feeder cables to diversify the position of each “whisker” to remote locations.
               Lost control of a park fly type the other day. Its receiver was of the short range single aerial type. Never had a problem with it in many flights, but inspection showed the aerial had come unstuck from its normal place and dropped down between the carbon rods to the tail surface's.
