David Davis Posted September 27, 2018 Share Posted September 27, 2018 I fly off this strip. It's eighty metres long by ten metres wide. To the left as we look at it is a "glider strip" of well-mown grass at least twenty metres wide. Beyond the runway the fields are sown to various crops, this year both fields were sown to wheat which has recently been harvested. My landings have never been my strong suit but my approaches have improved partly with the advice received from fellow forumites. I have a problem with depth perception or is it spatial awareness? Twice this season I have landed a model in the ploughed field when I thought that it was going to land on the tarmac. In the first instance I broke the fuselage of my Baron 1914 and yesterday I ripped the undercarriage mounting plate out of my SLEC Fun Fly. Is there anything I can do to improve my spatial awareness? Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted September 27, 2018 Share Posted September 27, 2018 Depth perception, is probably our weakest human asset, and we all suffer this one. What we can do is improve something you mentioned, the approach. Every single time, come wind, rain or shine Keep your downleg at a steady height and loose your speed and more height in the turn, so as your approach is more in control, Whereby you are not fighting to loose speed or height coming towards yourself. Coming towards yourself, maintain the controls gently just to keep the wings level and come in. Also, don't give yourself too much to do by going miles downwind buying you time. Try a shorter downwind leg to give you less time flying back up to the strip Quote Link to comment Share on other sites More sharing options...
Chris Walby Posted September 27, 2018 Share Posted September 27, 2018 Don't wear varifocal glasses or rush your approach to land, at worst come in slightly high and do a low pass to check where about the aircraft actually is compared with where you think it is (as it flies in front of you). I have miss interpreted the "scale" of the odd model and thought it was much closer that it actually was! Another club flier has two models that are near identical apart from one that is twice the wingspan of the other. Doing his low circuits around the field with the larger model he clipped the hedge/put it in. He thought as it looked large thus it was closer than it actually was! I have a PZ Habu EDF that has a quite large speed flight envelope and the advice given to me that works is to do a circuit and 1/2 throttle to bleed the speed off and importantly become accustomed to the low speed to get a nice landing. Again there is pressure as flight time is 4 minutes which does not give me many go around to get it right! Might be worth practicing a few touch and goes with each model just to get your eye in on the size and position of the model. Hope that helps. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted September 27, 2018 Share Posted September 27, 2018 Now I’m glad you’ve brought that up DD, as it appears to be a common problem affecting, not all, but a lot of us! We too fly off a tarmac strip with a grass one running alongside it which the full size boys use. When I first started flying I was always landing too far out, on the grass until a club member gave me some reference points to line up with on finals. I now, very rarely, miss the tarmac but, and here’s the rub, trying to land down the middle of the grass strip is a big problem, in fact on the 3rd flight of my new Radial Rocket I was right on the far edge of the grass strip, so much so that one wheel caught in the rough, spinning her round and pulling one leg out. The further away we fly, the more we lose the sense of the relationship between the model and the ground. When I was being tested for my CAA drone flying, one of the things the instructor told me to do was to fly 200m away by my judgment (without looking at the screen) then to hover and look at the screen. It was interesting to see how accurate, or not, my judgment was. Ditto height. We then carried out the same exercises but much further away and the difference was quite considerable. My suggestion would be to look for reference points, as per above, and use those to help line up etc. Quote Link to comment Share on other sites More sharing options...
David Davis Posted September 27, 2018 Author Share Posted September 27, 2018 Thank you gentlemen for the immediate and helpful replies. As for reference points if you look at the picture you can see a very tall dead tree in the distance. This lines up with the white lines in the centre of our runway. In the opposite direction there are a pair of pine trees which provide a similar refernce point. I think that Denis may have nailed my problem. I fly too far on the downwind, then having turned crosswind and then onto finals, spend ages approaching the strip at slow speed. Frequently I am at the point of a stall and have to push in down and give a blip of throttle. I'll try turning sooner and keeping the speed up. Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted September 27, 2018 Share Posted September 27, 2018 David, where do you stand and where was this ploughed field? I ask because I can see no hint of a ploughed field in the photo which might suggest you were miles off? BEB Quote Link to comment Share on other sites More sharing options...
David Davis Posted September 27, 2018 Author Share Posted September 27, 2018 Posted by Biggles' Elder Brother - Moderator on 27/09/2018 08:05:52: David, where do you stand and where was this ploughed field? I ask because I can see no hint of a ploughed field in the photo which might suggest you were miles off? BEB The club's flying field extends perhaps two or three metres beyond each end of the tarmac strip. After that there are fields which are worked by two different farmers. It's not obvious in the photo because the ground slopes away downwards from the runway in this direction. As for where we stand, if you look at the photo you will see a tarmac footpath running from the runway to the right. There is another one about thirty metres further on. These footpaths converge at the pit area which is out of shot, but they encase a grass triangle. We stand in the grass triangle about two or three metres away from the edge of the runway. Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted September 27, 2018 Share Posted September 27, 2018 Posted by Chris Walby on 27/09/2018 06:57:06: Don't wear varifocal glasses or rush your approach to land, at worst come in slightly high and do a low pass to check where about the aircraft actually is compared with where you think it is (as it flies in front of you). I have miss interpreted the "scale" of the odd model and thought it was much closer that it actually was! Another club flier has two models that are near identical apart from one that is twice the wingspan of the other. Doing his low circuits around the field with the larger model he clipped the hedge/put it in. He thought as it looked large thus it was closer than it actually was! I have a PZ Habu EDF that has a quite large speed flight envelope and the advice given to me that works is to do a circuit and 1/2 throttle to bleed the speed off and importantly become accustomed to the low speed to get a nice landing. Again there is pressure as flight time is 4 minutes which does not give me many go around to get it right! Might be worth practicing a few touch and goes with each model just to get your eye in on the size and position of the model. Hope that helps. Hi Chris I'm curious, why shouldn't you wear varifocal glasses? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted September 27, 2018 Share Posted September 27, 2018 We have a square of mown grass about 100 meters square. While landing on the grass is not much of a problem as we have a lot of width it is suprising how many times people land a fraction short and just clip the edge of the field and tip over. This is much worse when the crops are fully grown. Sometimes they actually touch down two or three yards short. I blame my cataracts but that excuse is being taken away Quote Link to comment Share on other sites More sharing options...
Nigel R Posted September 27, 2018 Share Posted September 27, 2018 Back to basics, how do we get better at things, practice practice practice. Pick a handy trainer, your Baron would do it, and fly nothing but takeoff, circuit (or maybe two), landing, and I mean nothing but that, for the entire day. Over and over until you are literally beyond sick of doing takeoffs and landings. Get the pattern burnt into your brain with that model. I'd accept the odd low pass if you abort the landing! Come back next week when the wind is in the other direction and do it all again. Next, bring your Acrowot, and do it all over. Yesterday I took my trainer to the patch and flew almost nothing but touch and goes for five flights. So I do do what I'm suggesting! As I was on my own I was able to wander about, in order to practice different direction approaches (right to left, left to right), and use both runways to practice crabbing in with crosswind. FWIW my patch - two strips at right angles, pick the best one for the wind, they're both about 30m x 4m, if that. Hedges about 10m beyond the long direction on one runway. I can't afford bad landings - anytime but summer the ground and grass mean a bad landing sends me home to fix damage! Edited By Nigel R on 27/09/2018 09:27:39 Quote Link to comment Share on other sites More sharing options...
Broken Prop Posted September 27, 2018 Share Posted September 27, 2018 You have my sympathy David. Many a time I have landed on the runway threshold, thinking my plane to be closer than it actually was. There is a small trick that can help. Clench your fist and stick the thumb up. Hold out your arm and place the top of the clenched fist along the horizon line. The tip of your thumb is then at about 6 degrees above, which is the best angle of approach. The plane should stay at this 'height' all the way in to touchdown, which should be close to you and hence on the runway. It sounds a bit crude but it does work. Incidentally, if you want a 3 degree flat approach, the knuckle of yuor thumb is about right. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted September 27, 2018 Share Posted September 27, 2018 The worst case for depth judgement is when you're standing close to the runway. I remember flying quite a large model for a clubmate, with him standing alongside me, along with the experienced original builder/owner. I had been flying some small models beforehand and all three of us were quite happy with the approach which was, of necessity, aiming to maximise the length of the runway. All three of us had a sudden shock when the model stopped abruptly as it hit a wire cable in the hedge line! Happily the model wasn't seriously damaged and some years later, I was happy to become its current owner. The incident was witnessed by "the gallery" sitting 20 yards behind the flightline and I was told that, with the benefit of triangulation, it was "obvious" that the model was undershooting... Is there any possibility of standing a little further back from the runway? Quote Link to comment Share on other sites More sharing options...
Cuban8 Posted September 27, 2018 Share Posted September 27, 2018 Posted by Denis Watkins on 27/09/2018 06:51:03: Depth perception, is probably our weakest human asset, and we all suffer this one. What we can do is improve something you mentioned, the approach. Every single time, come wind, rain or shine Keep your downleg at a steady height and loose your speed and more height in the turn, so as your approach is more in control, Whereby you are not fighting to loose speed or height coming towards yourself. Coming towards yourself, maintain the controls gently just to keep the wings level and come in. Also, don't give yourself too much to do by going miles downwind buying you time. Try a shorter downwind leg to give you less time flying back up to the strip This is great advice. For some reason, I'd fallen into the trap of setting a too high and deep downwind leg and as a consequence was finding my landings were becoming rather erratic and stressful. Took me a while to correct things. A bit like the 'yips' experienced by golfers (mainly putting) and other sportsmen....... Wikipedia...Yips - The condition occurs most often in sports in which athletes are required to perform a single precise and well-timed action such as golf and darts. Edited By Cuban8 on 27/09/2018 10:22:22 Quote Link to comment Share on other sites More sharing options...
stu knowles Posted September 27, 2018 Share Posted September 27, 2018 it probably differs person to person, but for me, when on final approach breaking the 'fixation' on the model by two or three glances at the intended touchdown point and then back to the model gives me a much better indication of the line of approach and the depth / distances involved. rarely need to do this at my regular site but when guesting at an unfamiliar site it usually avoids embarrassment. Quote Link to comment Share on other sites More sharing options...
Romeo Whisky Posted September 27, 2018 Share Posted September 27, 2018 For reasons I have never heard explained, many clubs seem to place the pilot stance aside the middle of the runway. It is actually much better to place the pilot stance near the runway threshold, as this means the model has the full runway length to take off without having to pass a central stance (potential danger) and rudder control is most intuitive when the pilot is behind the model. With regard to David's query about landing, it is also much easier to judge the runway threshold on landing when you are near to it, and spatial awareness issues are much less of a factor. Another benefit of this on landing, (as when taking off) is that as soon as the model has passed the threshold pilot stance it is flying away from you which means that the rudder direction is intuitive and flare-out is easier to judge too. Of course this necessitates the pilot stance may need to be varied from day to day (indeed sometimes even during the day) in relation to wind direction, and there needs to be agreement between pilots as to where the stance should be, but this can easily be accommodated in Club Rules and basic field ettiquette. Quote Link to comment Share on other sites More sharing options...
Rich too Posted September 27, 2018 Share Posted September 27, 2018 Wow, you have a nice flying site This is a massive problem where I fly too - its how my Yak ended on the top of a large tree I also have a slope to contend with. I am going to try standing further back, and the practice, practice, practice... Quote Link to comment Share on other sites More sharing options...
Nigel R Posted September 27, 2018 Share Posted September 27, 2018 "rudder control is most intuitive when the pilot is behind the model" I realise this might be contentious to some, and a bit of a can of worms and all that, but, the very core of learning to pilot a model involves being able to fly it in all directions, including towards yourself. Otherwise you are a passenger for 50% of the flight and that is asking for disaster. Even if you have zero ambitions regarding aerobatic flight, you absolutely need to be in complete control of an upright model in a normal flight attitude, coming towards you. Only being able to fly going away from yourself isn't solo competent, I would contend. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted September 27, 2018 Share Posted September 27, 2018 Posted by Romeo Whisky on 27/09/2018 10:24:19: For reasons I have never heard explained, many clubs seem to place the pilot stance aside the middle of the runway. It is actually much better to place the pilot stance near the runway threshold, as this means the model has the full runway length to take off without having to pass a central stance (potential danger) and rudder control is most intuitive when the pilot is behind the model. With regard to David's query about landing, it is also much easier to judge the runway threshold on landing when you are near to it, and spatial awareness issues are much less of a factor. Another benefit of this on landing, (as when taking off) is that as soon as the model has passed the threshold pilot stance it is flying away from you which means that the rudder direction is intuitive and flare-out is easier to judge too. Of course this necessitates the pilot stance may need to be varied from day to day (indeed sometimes even during the day) in relation to wind direction, and there needs to be agreement between pilots as to where the stance should be, but this can easily be accommodated in Club Rules and basic field ettiquette. I'm not sure about this. Placing the pilots near the threshold exposes them to models passing at flying speed and quite likely head height while they are concentrating on flying their own models rather than being on the ground and decelerating as they pass. During take-off, models are likely to be in contact with the ground as they pass the pilot box and self-preservation is a powerful safety aid should an unfortunate situation start to develop! For me, I find it easier to judge aircraft attitude during the take-off run and initial climb out if I'm standing to the side. Are you saying you're unable to detect whether a model is tracking straight on the runway from such a position? Quote Link to comment Share on other sites More sharing options...
Romeo Whisky Posted September 27, 2018 Share Posted September 27, 2018 I realise this might be contentious to some, and a bit of a can of worms and all that, but, the very core of learning to pilot a model involves being able to fly it in all directions, including towards yourself. Otherwise you are a passenger for 50% of the flight and that is asking for disaster. Even if you have zero ambitions regarding aerobatic flight, you absolutely need to be in complete control of an upright model in a normal flight attitude, coming towards you. Only being able to fly going away from yourself isn't solo competent, I would contend. - Nigel R Are you saying you're unable to detect whether a model is tracking straight on the runway from such a position? - Martin Harris You both seem to be reading words into my post that aren't in there! Of course a competent pilot should be able to steer a model correctly when it's flying towards him. (I never said otherwise). That doesn't change the FACT that is more INTUITIVE when it's flying away from you, and this is undoubtedly easier for less experienced pilots (of which I am not). I also did not suggest standing BEHIND the model on take-of, or standing in the middle of the runway at the threshold end. Obviously the stance should be at the side of the runway, but at the threshold end - incidentally a principle I learnt from a very experienced club trainer some years ago. David was aksing for help in respect of landing short or misjudging the threshold of the runway. My answer - which works - was meant for David and those like him who are having this difficulty is simply to stand closer to the threshold. Sorry if that offends the perfect pilots among us. Quote Link to comment Share on other sites More sharing options...
Stuphedd Posted September 27, 2018 Share Posted September 27, 2018 Another one for questioning Not to wear Varifocal glasses , ??? why ??? worn them for years and years , and not found a problem (yet ) a bit confused Pete Quote Link to comment Share on other sites More sharing options...
Nigel R Posted September 27, 2018 Share Posted September 27, 2018 RW. I must apologise, but I found it quite easy to confuse your first post "place the pilot stance near the runway threshold, as this means the model has the full runway length to take off without having to pass a central stance (potential danger) and rudder control is most intuitive when the pilot is behind the model." with the idea of "standing behind the model." I'm not perfect or offended, nor did I mean to offend. Discuss, yes, argue in the classical sense, yes. Quote Link to comment Share on other sites More sharing options...
Bruce Collinson Posted September 27, 2018 Share Posted September 27, 2018 Well I'm glad it's not just me! Relative newcomer, flying (in this career) 3 years. Moved site after a year, both broadly similar, 120 x 30 m of mown grass oriented E/W. "New" club site has a pilot box near each end of the strip and we fly from the downwind box so takeoff is away from the box, and the pilots, and rudder in the takeoff arguably easier. My landings are still inconsistent but the consensus views/advice I have been given which are most helpful are to use landmarks for aligning the final approach, usually meaning the plane is closer to the box than I would have it intuitively, but pushing it away isn't an issue. That pretty much nails the "depth" issue. Height, I have a nasty habit of landing short and the mantra is to pass the pilot box with daylight under the wheels then land it. Or, to paraphrase older hands, there's 120 m to go at, why not use it? Varifocals; would not dream of flying without them. Although my long vision is quite good, it's better with the little bit of correction the optometrist specifies but I really wouldn't want to operate trims or glance at the timer screen without the correction in the lower part. BTC Quote Link to comment Share on other sites More sharing options...
Don Fry Posted September 27, 2018 Share Posted September 27, 2018 Another point. At the age of 60, eyes need about 4 times a much light to work. So the pupils open up. But you need small pupils to get the best depth perception. Don't wear sunglasses any darker than you REALY need. Quote Link to comment Share on other sites More sharing options...
Keith Evans 3 Posted September 27, 2018 Share Posted September 27, 2018 I'm over 70 now and have been wearing Varifocals for over 30 years .I have no problems with flying and landing using them .The only activity I used to take them off for was Squash which I gave up 10 years ago . Quote Link to comment Share on other sites More sharing options...
Geoff S Posted September 27, 2018 Share Posted September 27, 2018 There was an article several years ago in one of the mags (RCME or RCMW) about how to judge altitude on landing approaches and I've found it very useful. The idea is that on approach you select a suitable feature on the near horizon (it could be a small hill or even a hedge) and then, by using throttle or a little elevator to control speed, you keep the model at an apparent constant height above it until it's obvious you are over the runway threshold. When you think about it, if you are actually flying at a constant height, the apparent height above the horizon increases so keeping the same gap between model and horizon means you're descending and will arrive on the ground opposite where you're standing. It certainly saves landing in the ploughed field, or, in the case of our runway at Ashbourne, hitting the berm on an approach from the north. It's certainly helped me. Geoff Quote Link to comment Share on other sites More sharing options...
