What’s this called?
An abomination.
VQ's instructions for a model that I have simply refer to it as a connector.
I bought a model 2nd hand that did something similar with a hardwood block.
My recommendation would be to use two mini servos, e.g. HS-82s (which is what I did in the VQ).
Edited by steve too
  • Like 3
  • Haha 1
I use the 3-way metal terminals from an electrical celing rose (see pic). Cheaper to buy than special 'dual push connectors', and more solid than using plastic terminal blocks. I then encase the whole assembly in epoxy once adjusted and tested.
Edited by EvilC57
  • Like 3
  • Thanks 1
3 hours ago, kc said:
Aerobatic models often use a ' forked pushrod '  made by bending both wires  in to meet the central pushrod then binding and soldering.    Less chance of an elevator failure due to a loose screw?
That makes sense or the suggestion of separate servos, this is for a small plane (25) so not expecting too much stress.  My soldering is pretty bad so the risk may be worse that way.
I'd probably bend the ends of that wire over at 90 deg, glue / bind them to a hard balsa block or short length of hardwood dowell, then bind a third short length to go to the servo. Nylon thread, epoxy, some scrap wood, would take only a few minutes to do.
Certainly permanent enough for a 25 size airframe.
Effectively, a (very very short) dual pushrod - which were common (as kc noted) on old 60 size aerobatic airframes in 70s/80s/90s.
Two micro servos also works fine, but the single standard servo install is already there.
  • Like 2
This looks a pretty practical option and your explanation is much appreciated. getting two elevators to be perfectly aligned might be very difficult though, any suggestions on how i might go about it?
If you get the connector close ennough any fine adjustments can be made at the clevise on the elevators ?
  • Thanks 1
  • 10 months later...
While I agree with the sentiments of most of these posts. That device is called a tie bar. Well, in some of the more polite engineering circles I run in. It does have its uses and should be kept in the back of ones mind as a valuable concept to solve a problem.
17 minutes ago, Don Fry said:
Wot device. I do Roman engineering. Explain.
??? I did a search and didn't find a definition for "Wot" or "Roman Engineering" ???
The OP asked for the nomenclature of the device shown. I didn't see one given.
I'd like to caution against calling a device by its application (elevator or flap joiner). Rather the nomenclature should describe the function; Tie Bar, Joiner or Splitter.
As this is under engineering I'm a bit surprised that the short coming of the way this is shown in the OP's and other posts hasn't been discussed.
As shown the rotation of the servo arm, side to side, will bias (favor) one push rod over the other. This is why some many of the post are using some form of derogatory name for the device. These tie bars have historically caused all sorts of rolling issue with the elevator or flaps, that use these tie bars, are actuated.
The proper way to orient the servo output shaft is to rotate the axis  90°. In the proper orientation for a split control surface the servo arm arc will move the tie bar up or down while NOT biasing any one push rod.
Time and time again I'm shocked at how often designer/builder forgo solid engineering mechanics. Some might say that this was often done out of expedience as the cost of servos or mixing circuits was far too expensive at the time of the design.
Unfortunately I've just built a new 2022 design 4 meter alpine glider where the designer has shown total disregard for solid mechanics. This cripples the design!
