Servo Mounting
Me too!
Personally I think it still holds true.
If a servo is screw mounted 90 degrees to the direction of the drive (pushrod direction), it only has a small mounting foot - the width of the servo.
With a servo mounted in line with the drive, the mounting foot is the length of the servo so it is therefore better supported with less give so more accurate surface deflections.
There's a vertical distance between the underside if the lugs and the servo horn. This will cause the servo to lean when it is acting against any sort of resistance. Obviously degree of lean is kind of proportional to said resistance.
You cannae change the laws of physics.
I prefer the mounting of the Seafury servos to the Hanger 9 Corsair.
I always try to mount the servos sideways in the wing and have never had any problems doing so.  They were mounted upright for many years when we used torque rods with a single servo which made a very neat installation but not so efficient.
   Bit of confusion with this one I think, servo lying on its side as in the Seafury wing fine. Servo as mentioned by Andy mounted upright but turned 90 degrees not good. Having said that I do have some mounted that way due to space available but they are just doing throttle.
Personally I agree entirely with what has been said so far . I'll always mount my servos in-line with the pushrod axis for all the reasons previously stated.
However, back in the day(1981) R.H.Warring no less was suggesting either method was OK. Photo from his book "Radio Control for Modellers".
When servos were 3kg the forces transferred to the mountings were negligible, however power could now be far greater and those mounted at 90' will have a very small distance between the mounting screws greatly increasing the twisting load compared to the wider spread of longitudinally mounted. Situation would be exasperated if they were single lug at each end possibly inducing a rocking motion.  Just my 2p worth.
  • Like 2
We may be using more powerful servos now but that is largely irrelevant - it is the aerodynamic forces on the control surfaces acting back through the control linkages that will act on the mountings. As long as a servo has not stalled that will be the same whether the servo is rated at 1Kg or 100Kg.
Whilst there is a theoretical advantage in mounting longitudinally I would defy any normal (as opposed to World class) modeller to detect a difference in practice on any small to medium (say 7kg) models. I know I can't.
Noting that the sideways mount used to be the easiest, neatest fit for a small (20 size) model using 3kg servos of the day. And a four lug servo would likely not twist much on a small model.
Bigger fuselage, 3 abreast would be easiest. And mechanically better under the  higher loads.
Nowadays we have tiny servos for small stuff anyway.
Conversely, any angular servo movement due to the flexible mounts (I would hope my airframe mounts don't deflect to any meaningful degree!) will be less in the unconventional direction.
While we're on the subject of flexible mountings, how many people put the top hats in the wrong way?  Virtually every second hand model I've had has them the wrong way up, which destroys the designed pre-loading of the rubber grommets by allowing the tube of the top hat to dig in to the bearer - for avoidance of doubt, the rim of the top hat is NOT designed to fit under the screw head!
6 minutes ago, leccyflyer said:
That's right Martin - quite a few pre-owned models that I've had have had the servos mounted with the top hats upside down. Some have had servo lugs broken off - how do you break the lug off a standard sized servo?
I also found that 90% of servo are not properly mounted,
 And how do you break a servo lug, I have included an illustration,,,?
