Struggling to get this connector needed for motor
shepeiro
Micron used to stock them from memory. The motor looks like an AP ** variant.
www.micronradiocontrol.co.uk
Alternatively as mentioned solder direct (once motor direction  is established) or use a servo plug and socket instead. It can easily carry the current for that motor.
Edited by 2.4g Shaun
Typo
  • Like 2
  • Thanks 1
The receiver I got has the connectors presoldered on and personally I hate soldering straight onto rx think I have early soldering career ptsd rom a few micro receivers melting under my inexpert hands
dont get me wrong I will do it but if I don’t have too…
Edited by shepeiro
  • Confused 1
If it’s an indoor ‘all in one’ receiver the ESC will be built into it. And there will be an on-board female connector for the motor connector (that he doesn’t have) to plug into.
I quite understand him not wanting to solder directly onto the pcb if he feels that his soldering skills aren’t up to it.
Brian.
  • Thanks 1
If you do find a matching female connector to plug into your motor, you will still have to solder it to the pcb of your Rx.
The key to painless soldering, in my view, is 1) make sure wires, pcb and your iron is clean 2) buy a quality iron of the correct size and wattage 3) use leaded pre-fluxed fine solder wire 4) practice a bit to get your hand in 5) with a hot iron solder quickly. 6) is 1) again… check everything is clean!
My 2p worth. Good luck 🙂
I think the confusion here is that he doesn’t have the motor connector. The photo in his opening posting is a generic one, to show the type of connector that he wants.
If he finds the correct male (motor) connector then he has no need to solder anything to the receiver pcb as that already has a female socket on it.
Soldering the receiver would invalidate any warranty that might have come with it. Hopefully the Micron connector will turn out to be the correct one.
Brian.
  • Thanks 1
Can't really tell from the blurry photo of the motor but you might want to check if the motor wires you have on your motor are already tinned. The motor wires might just be tails of the enamelled copper wires used in the windings so will require carefully scraping or sanding to get the enamelling off the wires before tinning........ unless they are already tinned.
RottenRow is bang on I have a rx with the female connectors pre-soldered on. Sorry photo was best I could find for what look like the male connector.
leccy Yes your right soldering is definitely something my that I need to improve and have done significantly since o got some leaded solder.  But still not keen on practising on an rx IF I don’t have to.
piers. All good advice and yes worth finding that leaded solder.  I have to it “clicked” when I did that. Learning on the unleaded stuff is a bit of nightmare. Melts too hot cools way too fast.
2 out of 5 burnt out micro rx’s later I figured that bit out…
