Ebay sellers...
47 minutes ago, Jon - Laser Engines said:
only one of these images?q=tbn:ANd9GcTbCBhVdQpYUWHIi9Dp2qa
One of our club members uses one of those to build his models.
He also uses these (and I am not kidding either).
Last time he broke a wing he fixed it with a wing bandage. Literally, halfway down the wing.
He doesn't understand why we won't let him fly off the buddy lead on his own !!!
I am glad that Jon has bought the Spitfire and will no doubt ensure the spar etc is done properly,  However I wonder why the model was used only for display - surely any model shop would fit the spar.   Perhaps it was on display somewhere else using other models too - if so what happened to them?
Today was a busy day.
6.5 hours, 283 miles (inc a full circumnavigation of the M25), and a few quid later i now have two new models....
Fitting it all in the car was a challenge as TF decided to use a big big enough for me to actually sleep in
First thing i looked for when getting home was the elusive wing joiner...its not exactly hard to miss
I then looked at the awful wing join..
Stress testing resulted in immediate failure
A jimmy with a multi tool later....
I then started fantasising
I then found something unexpected. I know full size spitfires had armour plate but i did not expect to find two massive chunks of 3/8 inch steel plate bolted to the engine box. This is a factory fit and comes with the kit!
Its probably needed to balance the overkill tailwheel bracket
Anyway its all back in its massive box now and waiting for me to decide what to do with it.
As for the other model....
  • Like 2
IMO The lump of steel is there because everyone wants to put a petrol 2 stroke up front...when will they learn....
Eurobat has a FT200 plus 1/2 lbs of lead
Dual Ace two 70's no lead and the RX batteries behind the canopy
SG Mossie needed more weight up the nose
Tigercat RX batteries in the nose, no lead
Jon, Nice engine you have there 😉, another install thread please
I had an HB61 which could have reversed rotation but as Paul says the crankcase should be rotated 90° axially to the crankshaft not 180 to the cylinder. Someone has had it apart and not reassembled it correctly, would you buy an engine off this person?
The picture has not been printed mirror fashion as the carb is still the right way round.
Edited by Andy Stephenson
  • 2 months later...
  • 1 month later...
